Strokermjcomanche
    6
  1. Check to see if its routed properly, if youre not getting and marks that's about all I can think of . Also there is a problem with getting calipers at parts stores they seem to think there all the same . The bleeder ends up being on the bottom instead of the top . If there older calipers disregard the caliper portion of the post
  2. I'm not a wheeler but I think you should invest in some steel braided brake lines .all the 4wd companies sell them . Couldn't tell you a price of hand though .
  3. Hello I'm looking for both male and female plugs with atleast 6 inches of wire after each plug for the tail light harness if you have something let me know how much shipped to Ohio 44509 thanks Adam
  4. No if the CPS does not work you won't get spark therefore it's working . You wanna be carful about how much starting fluid you use also . My edjucated guess would be a fuel pump then
  5. A 1k for both sides !!!!???? Highway robbery, I'd do it for half except I'm in Ohio. you might as well buy a Dana 44 for that price. shop around see what other shops charge first .
  6. Did you check for spark ? I wouldn't go throw parts at it yet you might be replacing parts that don't need changing . The filter is something that should be changed regularly so I'd changethat but check spark first
  7. You can in 4wd it has a dry slip yoke and a 242 t case no fluid will leak
  8. Not necessarily but it wouldn't hurt to clean them . Right now make checking for spark your priority
  9. Most likely you would have a bad crank postioning sensor (CPS) and there are plenty of renix upgrades that can be done also ( cruiser)
  10. Still check for spark when you can get a friend , unless you have a timing light
  11. More of a backfiring noise or a sharp clicking?
  12. Do you have a 4.0 or 2.5 ? If you have a 4.0 located on the fuel will be a Fuel check valve remove the cap ,take a small screwdriver and press the center part of the valve with the key on you should get some pressure of fuel coming out if not let us know well go drone there
  13. Do you have a 4.0 or 2.5 ? If you have a 4.0 located on the fuel will be a Fuel check valve remove the cap ,take a small screwdriver and press the center part of the valve with the key on you should get some pressure of fuel coming out if not let us know well go drone there
  14. Do you have a 4.0 or 2.5 ? If you have a 4.0 located on the fuel will be a Fuel check valve remove the cap ,take a small screwdriver and press the center part of the valve with the key on you should get some pressure of fuel coming out if not let us know well go drone there
  15. Do you have a 4.0 or 2.5 ? If you have a 4.0 located on the fuel will be a Fuel check valve remove the cap ,take a small screwdriver and press the center part of the valve with the key on you should get some pressure of fuel coming out if not let us know well go drone there
  16. Do you have a 4.0 or 2.5 ? If you have a 4.0 located on the fuel will be a Fuel check valve remove the cap ,take a small screwdriver and press the center part of the valve with the key on you should get some pressure of fuel coming out if not let us know well go drone there
  17. Worth mentioning be sure to stay clear of the clutch / cooling fans while cranking the engine
  18. Water pump is the same , housing is the same also unless you wanted the temp sensor in the thermostat housing. on the renix there located at the drivers side towards the bottom of the block and the 91 and newer are located in the thermostat housing( to my knowledge it doesn't matter )
  19. Ok to check for spark. if you still have one of you're old spark plugs Disconnect the spark plug wire at the spark plug on any cylinder , plug an old plug into into any wire that you disconnected and ground the spark plug base to a head bolt . Have a friend handy, take a pair of insulated pliers and hold the base of the plug to the head bolt while your buddy cranks it over. You should see a bluish spark if you don't see a spark let us know then well go from there
  20. Do you remember how you changed the wires/ plugs? Do you know if you're getting spark / fuel ?
  21. The firing order would not cause a 1 click problem . When the truck was parked was anything messed with until you started working on it ? If not I would pull one plug and one wire at a time and change them all which I know you changed them but if you put them in a different order it will not run. Being you have a Haynes manual locate tdc ( top dead center ) and make sure that the distibutor is at #1 cylinder and run the firing order correctly
  22. Do you have bigger tires / lift on your truck ? If you are easy on the drivetrain may I suggest cv shafts they are constantly lubricated and are less prone to failure when used for light duty . Most manufactures also offer lifetime warranties on the cv shafts so you'll never have to buy another
  23. I have no relay behind or anywhere around my ps kick panel not sure if there xj specific or not?? Any help is much appreciated
  24. There is still the rear of the harness that needs to be integrated into the rear of the Comanche harness
  25. Yes , no real differences between the waggy and the Cherokee xj of those years except the trim , options
