10strokin
568 profile views
10strokin's Achievements
  1. When you say choose which heater hose layout I want, what are you meaning?
  2. Hi again all, I am having overheating problems with my old 89 Comanche and have decided to do the closed cooling system changeover. I ordered a 3 row radiator with twin fans already for a 93 cherokee, my question is I just changed the water pump a short time ago for the old system. Do I now have to go to a newer style water pump> What about the thermostat housing? I have an overflow tank from a 95 cherokee already to use and I will be getting rid of the valve mess under the old coolant tank and just running lines straight into and out of heater core. Thanks all!
  3. No problem. I didnt realize you had to cut the body of the truck, I thought maybe just some mods to the taillight housings themselves...
  4. What modifications need to be made to a cherokee taillight to fit?
  5. I purchased a pair from the classifieds on here. Thanks all!
  6. How about a used set of MJ Taillight lenses?
  7. Thanks all! Used to be able to order them at Autozone but thats gone I guess. I would have thought Jeep could have saved some money by using same products in their product lines where they could. So I should look in the classifieds here or Fleabay? What mods have to be made for cherokee taillights? Thanks again
  8. Hi all. New here, I just picked up an 89 Comanche 4.0 5 speed 4x2. Just a quick question. Both of my taillight lenses are busted. Will a set from a Cherokee bolt right in place? Thanks for any help! Matt
