Strokermjcomanche
    6
  1. There's one a daveys jeep 100k miles no rust southern truck 4x2 auto 2500 nice truck needs paint though it's a 90 btw
  2. Sorry I was on my phone and don't know how to do it but I wasnt lazy enough to let everyone know
  3. Oldseddie that is too old to have z key made that way . Oddmodman if you can take out the cylinder just get a new cylinder that comes with keys roughly 20 bucks at any parts stores but if you lost the door key you gotta take the door cylinder to locksmith or dealer to get a door key made
  4. I think eBay had a couple
  5. Davey jeeps has a dark blue grey interior unmolested Comanche needs headliner paint is faded but it's clean ! Search daveys jeep. Com and it's the 4.0 auto 2wd crank windows southern truck
  6. Jerseyjeeper bought it it went to a good home you should see his other Mjs
  7. You can run the additive along with your choice of oil and it doesn't hurt to run it longer
  8. Mike is going to look at it today he live in nj he's supposed to tell me what condition it's in
  9. The two big lines are the ones that go to the air intake
  10. Btw is the housing bent or just the axle ? If the axle is bent just change the axle because you have to factor in the price of new bolts / hardware diff fluid ( if drained ) and labor .
  11. Is it 2wd or 4wd ? You of course would have to stay with the same gear ratio if it's 4wd . Even if it's 2wd changing the ratio will effect gas mileage and power
  12. He's had it posted for 8 months he started at 4500 and now it's down to 3k in the past he's posted the mileage I'm only 40 minutes away from him I was thinking to go look at it
  13. Did you see the one on Akron canton craigslist? 3k 82 thousand miles no rust
  14. What part of Ohio?
  15. What year is it ? Does it have a cable ? If it's a electronic speedo it won't factor in the mileage (unless the key is on ) if it's cable it will rack up the miles
  16. Your right, also check the main connector at the core support for corrosion
  17. Do you still have the tail lamps I'd like to purchase them ?
  18. Check the turn signal sockets for power and ground and also the main connector at the drivers side core support fir corrosion
  19. I think it's 52000865 mopar depending on bed length
  20. I forget how it was mounted but you just need comanche rear cables and the only problem will be locating the front cable I might be able to get you a number but do some double checking to make sure it's right
  21. They made Mjs with hand brakes in them . My 86 had it before I converted to a foot brake
  22. Youngstown oh I have an 88 and 89 mj
  23. Maybe he has the 3.4 swap out of the camaro?
  24. Yeah if it's the smaller one leaking
