3
Everything posted by yxmj
Starts then shuts off immediately (86 2.5l 4x4)
yxmj replied to Me&my86MJ's topic in MJ Tech: Modification and Repairs
Have you tried to start it by pouring a bit of fuel down the TB wait 20 secs then turn the key......will it fire up then? -
You do have an internal slave right? Sounds like that is the culprit. If so you have to pull the trans back to get it. But you might get lucky, I had one that was leaking that turned out to be a faulty O-ring.
Just a crazy thought that comes with the first coffee of the day................there is gas in the tank........right? :brows: -
No my friend.....if you are spraying carb cleaner and it is running........YOU ARE RUNNING ON CARB CLEANER....you are missing my point......you have a fuel delivery problem.....the fact that the motor runs when you manually introduce fuel to it shows that. Don't run it on carb cleaner.....probably not good for it. -
No you are running on the cleaner you spayed in.......otherwise it would keep running........it has somthing to do with fuel delivery........if you don't believe me take 2 or 3 table spoons of fuel.....dump it down the TB.....or 86 maybe you have a carb? dump a bit of fuel in wait 30 secs....try and start it.....does it fire,,,,run,,,,then die? -
Nice :thumbsup: love the floor matt in the background.... :thumbsup:
Please PM me his address and info.......were is the "vendor section" :hmm: Read my last post in this thread. ^ All the details you'll need. Got that ......thanks my order will be placed....my yj has old school 8-ball shifters.....like to improve them.......but still........were is the vendor section mentioned....am I missing somthing?
You clutch is not connected hydraulically (by fluid) to your trans....from your description I am guessing it is an internal slave.....? My last guess is that the master is worn.......this is an option since you have to pull it anyway.....http://comancheclub.com/topic/41742-clutch-master-rebuild-mod/.......
2 Wheel Drive To 4 Wheel Drive Conversion
yxmj replied to redwolf624's topic in MJ Tech: Modification and Repairs
Reddog.......since you are on here you have (access to) a computer. read this.....http://en.wikipedia.org/wiki/Jeep_Comanche_(MJ) Read it twice (that's 2 times) if you have other thoughts or questions ......make notes .....write them done......try this www.google.com Rock on :rock on: It might help you -
I need the area code......... :yes:
Here is a couple of pics to inspire you
I do not know it would make things easier.....if I remember right some 44's (maybe on Scouts) were even more off set....like (I could be wrong) 1.25"-1.5"
I think if you take a tape to it you will find the pinion is a bit off set..( not perfectly centerd)....that would make the ring off set and by defaut the carrier...so one shaft is longer. . :MJ 1: . That might not make sence but i think you will get my drift?
Sorry I should have made myself clear with the above.... the 15 is used with the motors listed the 2.5 was a 5 :D
If this is correct · Late 1989–1999: Aisin-Warner AX15 5-speed manual, used with 2.5 L I4 diesel, 4.0 L I6, 23 spline output. http://en.wikipedia.org/wiki/Jeep_Cherokee_(XJ)
Help re-installing cylinder head
yxmj replied to mjtjnj's topic in MJ Tech: Modification and Repairs
Have a look at the secound post down http://www.cherokeeforum.com/f2/cylinder-head-torque-2-5-liter-banger-32293/ This one has a pic http://www.cherokeeforum.com/f2/need-some-torque-specs-130127/ -
If you have the head off.....Get a known "Straight Edge", a carpenters square springs to mind, and check you block and your head....a gap of even half a MM can be cause for concern. On the other hand.....there is a manufacture who makesa a thicker HD gasket for the 2.5....maybe that would help...... . :MJ 1: . -
Not your Brother Call 911 and turn yourself in....your messed up
Give up .....your done.....the fact that you posted this question on this site.....and called it a "CAR" site shows she can ....and will..... do better than you.....leave her alone .....
Careful you might ask a question not asked,, :doh: ,,,since you singed up try the search bar... :dunno: ...or the Comanche tribe from the past has told me of the " Google" though I don't believe in it....
- 12 replies
- 5 speed
- transmission
(and 1 more)
Tagged with:
If we are only counting Licenced and on the Road.....7.........The spares in the back rotate :thumbsup:
I think he is asking about the trans to transfercase connection.....the motor would not be in the equation.....but your years are correct. That was when the trans to tcase spline count changed - for the 4.0. When the spline count changed for the 2.5, I don't know. If he gets a NP231 from an early 4.0, that will have the 21 splines. I think you are missing my point here partner.......They did not build specific AX15's for I 4"s and I6's.....it is the same trans (some bellhousings could be differnt)...... The OP asked about the Trans to T-case join.....adding motors into the eqation just muddy's the waters...IMHO....now if you bring the AX5 into the equation that might clear up what you are thinking. (it would be different......) Here is some info to help http://www.novak-adapt.com/knowledge/np_nvg_input_gears.htm http://www.novak-adapt.com/knowledge/np231.htm
Yes....like driving by a car wreck.... :shake: ...don't want to look.......but can't turn away..... :popcorn:
SOA Ideas and Speculation/Rambling
yxmj replied to BeenJaminJames's topic in MJ Tech: Modification and Repairs
:thumbsup: If I could add,,,, take a couple of minutes and clean and inspect the leafs.....older ones have hairline cracks that the rust hides.....if you are going to do it make sure it lasts :thumbsup: .
