MiNi Beast
Everything posted by MiNi Beast
  1. wheres your sense of adventure?
  2. yeah however i have had this setup before i did driveshaft and pulled the yoke out and it binded up the driveline and broke the yoke slip while i was all flexed up over some electrical poles obstacle. no problem since driveshaft mods.
  3. I'm at 8.5" of lift and still run a stock slip yoke setup just have the built in tcase drop from the RC long arm setup. still had the driveshaft made for proper length.
  4. mini van doing work
  5. can't argue with that decision. good project trucks. keep us updated.
  6. ive driven across the swamp yea.
  7. i stick trump stickers on random bumpers. is that wrong
  8. flat rate boxes are great.
  9. about time. ready to see it playing. i wanted the tnt kit but couldnt wait for the back order. tell me it was worth the wait..?
  10. 8.8. with better gears and disc brakes and maybe a limited slip diff and non c clip is a solid upgrade axle and a great time to swap during a lift. leaf perches is all you need with shock mounts. unless you want a trussed setup then artec offers some options with decent price. you can source builder parts at barnes or ruffstuff. you could also run ube perches and take advantage of adding .5" to 1.5" lift and run without ubolts, ( i ran this setup on last rig). i ran a 8.8 with 4.10s with a d30 non disco on my rig with 33 to 37s. only broke with 35s. light foot and knowing your rig you can have less carnage. good luck mate.
  11. 6.5" lift long arm set up. run 33s now and still be good to run 35s later. pretty much only difference in parts is a bigger spring. soa is common for rear lift and this is good time to swapout axles. but its more then just lift for them bigger tires, axles and gears are the unseen parts that makes all the differences. whichever idea is a complete list of parts and have on hand before swapping. do research based off your end goal with rig, build for 2 sizes bigger then the tire you want now. unless dead set on tire now.
  12. yes 3m tape was used and it holds up like tape does. clean surface and it will be adhere good.
  13. they still work. I went with pop rivets in mine cause i wanted the detail. but really any hole in the hood will help keep temps down. I see about 15* drop. little bit helps on hot days but i know live in a desert.
  14. hooked for life. thats what happens then you find yourself looking back 14 years and remember when you first joined and how big you thought 31s were.
  15. always trying to upgrade.
  16. 3 days? i need atleast tuesday through friday to get front page regularly.
  17. got the rig out for a bit been kinda blah with the rain. dropped off the injectors and contemplating a ls swap with the ax15. idw. but had a good day to get out on the water. so fishing buddy had day of school so the 5 hr river fishing was on. he had all the luck again. was a great day on the water and was much enjoyed.
  18. you gots gumption. bad seal?
  19. accidently you say.
  20. 135 little much for me. ill find one local.
