as the others have said, ground clearance under the axles is one thing, but as soon as you leave perfectly flat ground, approach/departure and breakover angles are important too.
life played some pretty good jokes on me yesterday. the best was when I woke up and my computer had shut itself off and wouldn't fire back up. but later that day it was all back to its normal slow self. :dunno: or maybe the best was when I pulled the brakes off the van and pieces fell out. I had an inkling that the rears weren't doing much. worse than I thought though. :fs1:
it's so little as to be unmeasurable. (meaning that you would never be able to make up the cost of the posilok in theoretical gas saved) don't sweat it. :thumbsup: the CAD was a mistake that Jeep eventually rectified.
you could keep the metal intact, mount the flare up a bit higher, and then bumpstop it. be aware that slicing-n-dicing of the metal will bring on the red cancer in a hurry. :(
if you don't want to pop the cover, you can jack up one rear tire, put the truck in neutral, then rotate the tire around exactly twice while counting the number of times the driveshaft spins.
ha ha. :D
I'm still up for it. :thumbsup: power steering is for wusses. :rotf:
and I do have a couple of straight/rustfree bumpers if I can get them off the trucks.
That took all of 10 minutes to get used to.
Here it is, second day, and I'm STILL opening entire new windows!....Just annoying is all. :wall:
I scroll-ball click to open links in a new tab. does that still work in 4.0?
sorta. Firefox lets you go forward or back a page and the text will still be there. Explorer does not. Used to be a huge deal on the Yahoo group since posts would get eaten up instantaneously and you couldn't simply go back and resend.
pre-95 ABS axles should have the beefier U-joints. all Cherokee axles after 95 will have the beefier U-joints.
these are rules of thumb though. you gotta check for sure before buying.
