Hey guys, I've done some searching but came up with nothing solid so I'm reaching out.
I have a 92 MJ, with a locker in the rear. It's a Dana 35.
I also have a 98 XJ, that is also a Dana 35.
I know there is a Dana 35C, but honestly, I'm unsure of the difference.
Anyways, I want to put the locker in the XJ. I figure the easiest way to is to swap the axles.
The yokes appear to be the same, so that really doesn't concern me.
However, I went to check the gear ratio tags to try to match them up. But the one on the XJ is missing.
Also, the diameter of the XJ's axle appears to be bigger than the one of the MJ.
So, does anyone know if the gear ratio's are the same, and if this is even possible?
Any info would help me out a great deal, thanks in advance!
