Pete M
Administrators
    114
Everything posted by Pete M
  1. have you cleaned all the grounds? what are the condition of your main cables?
  2. boom
  3. not ready to part her out yet, sorry.
  4. 2dr doors are a few inches longer than 4dr doors. :thumbsup:
  5. I pretty much stopped selling everything until the house is closer to getting done. haven't even listed it locally yet.
  6. mine are 16s
  7. don't pull a leaf. our trucks have enough issues with spring-wrap as it is :(
  8. wheel diameter doesn't matter as long as the tire diameter remains the same. :thumbsup:
  9. spring sag matters too. perhaps even more.
  10. you guys are awesome! :cheers:
  11. the annual website fee is due at the end of the month and will be about $80. also I'll be needing to buy more masking material (about $40) for the decals before the end of the year (I do all the weeding/masking so as to cut down the price). if anyone would like to chip in a couple bucks to help out that'd be awesome. :cheers: paypal ID is: comancheclub@hotmail.com send a PM for my home addy.
  12. http://comancheclub.com/topic/35519-55-600-mj-lift-cheap-high-quality-100-complete-lift/
  13. our trucks rot from the inside. washing the exterior really doesn't do much unfortunately. :( you have to clean the inside of the doors, rockers, frame, etc. to get the salt out. :fs1: try to spray up inside the bedsides to get that shelf above the rear wheelwells. :thumbsup:
  14. awesome :D after two paint jobs, how did you know it was her?
  15. I wouldn't condone that kind of thing...But what I don't know... I'm not condoning it either, I'm just saying that it's super easy to cheat around that rule since craigslist ads are free and easy to manufacture, so why make that rule? :dunno:
  16. and they like to snap right off when your truck has lived its life in the rustbelt. :(
  17. that's a weird rule. how hard would it be to get friends around the country to put up fake ads?
  18. :rotf:
  19. it's what I remember from the dealership brochures
  20. the 4banger could be backed by either the ax4 or ax5 but in the case of the metric ton package, I do believe only the ax5 was offered (to accommodate the 4,10 gears.)
  21. the metric ton package was available with the 4banger and/or 2wd. chances are REAL GOOD that your AMC-20 (regardless of the engine/trans combo) has 4.10s. only way to know for sure is to check. either spin the axle shafts or pull the cover and count teeth.
  22. for that kind of money you should be able to get a decent XJ. :yes:
  23. nope. that costs money :( good to hear your truck is coming along :D
  24. very slick! might have to attempt that myself for my nephew :D
  25. did you replace the rear axle when you converted? if not, you likely have 3.55 gears and are burning a bit more gas while the little engine is struggling to push the bigger tires around. and if you didn't install the proper speedo gear in the t-case, your speedometer/odometer is off and throwing off your calculations. :thumbsup:
