114
Everything posted by Pete M
a-yup. thank goodness the truck isn't from the salt-belt and the rot is mostly just the floor and isn't in the frame or rockers.
the floor is coming apart, some places faster than others. the good news is that the inside of the frame is in excellent shape. the bad news is that it looks like I'll be removing the steering column, pedals, and harness because the rust just keeps going up the firewall. I put a box underneath to catch the particulates the rear of the cab was hiding a bunch of whole rust under the sealant. doesn't appear to be rot though.
What should I do while the carpet is pulled up?
Pete M replied to jodawill's topic in MJ Tech: Modification and Repairs
I bought some closed cell foam for the last truck I refurbed. I wanted something there, but not something that would retain moisture (though the carpet traps it anyways, so does it really matter?). it went down ok. not yet sure what I'll be doing with this new truck. -
yes, those are factory. plenty of weird things in an MJ. lol. -
dynapad type products work great on large echo-y sheetmetal like door panels and roofs, less so on small expanses that can't really reverberate. personally I'd skip it on the floors and stick with protecting the steel down the road with the aforementioned products. -
My 1990 Wiper Repair
Pete M replied to AnotherOldJeepGuy's topic in MJ Tech: Modification and Repairs
chances are better than the power wiring to the motor needs to be cleaned/refreshed before the motor needs to be replaced. -
"It's all in the Door Knob, Knob!"
Pete M replied to SGTSnacks's topic in MJ Tech: Modification and Repairs
you can try removing the interior handle trim so you can grab the rod with pliers. -
cycle the lock back and forth a bit, then leave it unlocked and push the outside button and pull the inside lever at the same time. I've had success in junkyards with that method. on my first truck I had to pull the inner door panel off to gain access to the rods. that wasn't fun. I've heard of guys taking the latch mechanism out of the door and soaking it in a thin degreaser or even gasoline over night before relubing it with lithium grease. -
$25 bucks but the current coupon is half off everything photo https://photo.walgreens.com/store/calendars you can make your own using any MJ image you'd like (image quality is always going to be a concern)
good catch! might be a T between the 5 and 9?
I imagine walgreens will make calendars.
"hey, while you've got the saw out..." beautiful work as always
of course it's the weekend I'm in michigan helping my cousin install a new furnace. got my flight and everything. oh well, promises are promises I guess...
have someone wiggle the steering wheel back and forth while you crawl underneath and see what's moving and what's not. just keep in mind that it's a solid axle with a Y linkage and old-school steering box. it'll never be as crisp as a modern IFS rank-n-pinion car.
loading up for a scrap run. turns out they were closed all week for the 4th so it sits until monday.
