Pete M
Administrators
    114
Everything posted by Pete M
  1. test fitting the new floor I'm still a long way from installation, but am immensely pleased with the fitment of the Key Parts stuff
  2. you should open that up asap and make sure the wire isn't grounding out.
  3. always nice to hear from an old friend. got some bad news though, Don passed away a couple years back do you need your password reset? send me a message and I can take care of that
  4. the soviets never made a full mockup, only models, but in the early 50s apparently they were contemplating this:
  5. 2 hour test drive on today's junkyard run and all is well. it wasn't hot enough outside to trigger the codes, but it means I didn't screw anything up.
  6. big nope. last thing I need is more power in the little car. not with this silly automatic at least. though someday I would like to find a factory turbo stickshift again. we had one back in 03.
  7. more cruiser add-ons. mostly junkyard stuff. official mat that actually fits rear mudflaps that I hadn't cleaned yet a freaking hitch!!! perfect for a rack a rear swaybar! apparently all 01-02 had them before they were discontinued. BUT all the holes and hardware is still in the later cars for some reason. rando stubby antenna because why not. and for a bit of class, the cheap chrome pipe extension
  8. pretty sure that rubber trim comes free with the 97+ glass? I don't remember there being a price difference.
  9. oh, and I spotted a fresh 05 CRD the other day and grabbed a few spare parts from it. the front shafts are unique to CRDs and now I have a spare set. (plus brakes, spindles, e-fan, hoses and some other stuff). I may go back in a couple weeks after I give other owners a chance at the engine/computer bits. I have enough of those.
  10. hopefully this junkyard oil cooler will help keep the high transmission temps at bay. the factory unit is integrated into the lower couple inches of the AC condenser and is buried down behind my bumper. less than ideal. the new cooler isn't actually in the fan's airflow, but space is at a premium and it's right there in front. I have a better plan, but it'll have to wait because it's way more involved. this was quick and dirty.
  11. pretty sure I used safelite with breanne's truck. either way it was an in-driveway experience. I told them it was a 97 XJ. I never uttered the word Comanche. no one seemed to care. that said, after removal there was rust I had to deal with but the guy happily came back a couple days later.
  12. in the last truck I glued the foam to the truck with a bead of rtv and then added a bit more to the engine side (like caulking) after the original bead had set.
  13. spotted this one in the junkyard the other day. the exhaust pipe on the left is factory, the one on the right is... only a foot long and connects to nothing. note the hitch though. that lives on my car now
  14. those are indeed some of the factory weirdness once you start wailing away at that rust with a wire wheel and chiseling up the factory seam sealer, you're going to find plenty more pin holes. dealing with that is step one, but finding the water leaks is step 2.
  15. I would leave the seam sealer alone if there isn't any sign of rust. if there's any hint of rust at the edge of some sealer, I would use a wire brush on a drill or grinder to explore how far it goes. keep in mind that preventing water intrusion is the single most important step to preventing rot. the floors are complicated and you cannot rustproof every nook and crevice. heck, if it stays dry, you can leave it completely alone and it'll be just fine forever
  16. make sure it is pretty soft so it doesn't push the plastic out. I think it's for dust prevention and vibration dampening while on the freeway more than water intrusion.
  17. are you talking about the foam tape?
  18. wow! so much history!!
  19. also got the fuse box separated and the harness pulled. still gotta get the pedals out of there. there's evidence that someone has been in here already (aside from the mice). hood cable bracket screws were damaged, the cable was routed wrong, and the upper nut for the clutch master is missing.
  20. pickin' away at the rot. this is definitely a young man's job. lol. my back is feeling this.
  21. do the HO years also have that little screw in the engine bay that hold the halves together?
  22. you get 5 rides (and only these 5) for the rest of your life, but they all have to come from a single model year. after much mulling I went with the year 2000. XJ with 4.0 as my daily TJ with 4.0 to modify Excursion with 7.3 for hauling stuff (runner up: Suburban 2500 with 8.1) Grand Caravan with 3.3 for hauling people Dakota RT reg cab with 5.9 for hauling butt not my favorite year for any of those models, but pleased they had enough overlap to get me a nice lineup
  23. I would fill the hole with a dab of seam sealer when I got to that step. I see a bit of rust that needs to be addressed.
