8
Everything posted by mjeff87
X2 I'm still running my stock 2.5L coil/ignition module on the 4.0. Works fine. Jeff
I've got a spare (complete) 2.5 sitting up in storage in PA that I've been meaning to do something with. Came out of an 87 MJ (75K miles) from a NAXJA buddy over in TN and it's been sitting for the last few years. By complete, I mean we disconnected the exhaust, cut the fuel lines and discoed the wiring harness and yanked it out. Still has the plugs and the oil in it :D PM me if you're interested, I could be persuaded to bring it back down to VA and meet you with it if so..... Jeff
you can use an auto TPS, you just don't plug in the seperate pigtail that normally goes to the TCU. (I'm running an auto TPS in my MJ now, so I can verify that it works ;) ) Jeff
bleeding an external slave AX15
mjeff87 replied to mjeff87's topic in MJ Tech: Modification and Repairs
well, the verdict is in......it worked :thumbsup: unbolted the slave and pulled the pushrod out of the bell, pointed it straight down and with the cap off the master started pumping the pushrod in and out. After about 10-15 short pumps I heard a "bloop" and crawled out to check the fluid level. It had dropped by about half. Filled it back up and gave it a few dozen more pumps (didn't hear any more bubbles coming from up top) and bolted it all back up. I now have a full clutch. Now if I can only find someplace in this hick town that sells Redline, and Spicer u-joints, I'll be a happy man. I decided to try running 10W30 instead of gear lube, and while it's working ok, there's no noticeable improvement in shifting, so I'm gonna treat it to some good stuff (if I can find it :fs1: ) Jeff -
Engine problem 2.5 5 speed with 4X4
mjeff87 replied to wranglercory's topic in MJ Tech: Modification and Repairs
O2 sensor unplug it and run it, see if the problem goes away Jeff -
viewtopic.php?f=9&t=20204
that's what I like about you Eagle......your eternal optimism :yes: Something about holding the slave in a downward position while engaging the pushrod, the air in it collects at the rear and you have to force it back upward. Dunno, it's worth a shot anyway. I can drive it as is, but I don't like where the disengagement point is, and there's a bit of pedal free travel from the resting position. We'll see what happens. Can't make it any worse :D Jeff -
I dunno......it fit both ways, so I decided that it being on the top was better than being on the bottom :dunce: Guy on NAXJA says to reverse-bleed it (remove the slave and keep pumping the rod until there's no more air bubbles in the master. Sounds good to me. I'll give it a shot tonight and see what happens. Jeff -
(also posted on NAXJA.....) Long story short, I swapped AX15's in my MJ to an external slave setup. Sourced a sealed, prebled master/hydraulic line/slave assembly from the junkyard but awhile ago, I seperated the slave and hydraulic line from the master because Pat needed the slave. He ended up not using it and I got it back, reattached the master and put it all in my heep. There's a small allen head setscrew in the top of the slave that I cracked open to bleed the assembly (and got showered with brake fluid in the process), and I've got a somewhat good pedal but I know there's still air in the system. Anyone ever successfully bled one of these "sealed, pre-bled" assemblies? I was thinking about replacing the setscrew with a conventional bleed screw....anyone happen to know the thread/pitch of it? TIA, Jeff
yup yup........time to update the avatar. LETS GO PENS! Jeff
Adjustable MJ Load Sensing Valve
mjeff87 replied to HOrnbrod's topic in MJ Tech: DIY Projects and Write-Ups
I vote a mixed greens salad, balsamic vinagrette, and a nice bottle of Chianti to go with that plate of spaghetti you got there Kas. Jeff -
The 2010 Federal Census For The South Last name: ________________ First name: (Check appropriate box) (_) Billy-Bob (_) Billy-Joe (_) Billy-Ray (_) Billy-Sue (_) Billy-Mae (_) Billy-Jack What does everyone call you? (_) Booger (_) Bubba (_) Junior (_) Sissy (_) Other___________________ Age: ____ (if unsure, guess) Sex: ____ M _____ F _____ Not sure Shoe Size: ____ Left ____ Right Occupation: (Check appropriate box) (_) Farmer (_) Mechanic (_) Hair Dresser (_) Unemployed (_) Dirty Politician (_) Preacher Spouse’s Name:_________________________ 2nd Spouse’s Name:______________________ 3rd Spouse’s Name:______________________ Lover’s Name:___________________________ Relationship with spouse: (Check appropriate box) (_) Sister (_) Brother (_) Aunt (_) Uncle (_) Cousin (_) Mother (_) Father (_) Son (_) Daughter (_) Pet Number of children living in household: _____ Number of children living in shed: ______ Number that are yours: ______ Mother’s Name: _______________________(If not sure, leave blank) Father’s Name: _______________________ (If not sure, leave blank) Education: 1 2 3 4 (Circle highest grade completed) Do you (_) own or (_) rent your mobile home? (Check appropriate box) Total number of vehicles you own: ___ Number of vehicles that still crank: ___ Number of vehicles in front yard: ___ Number of vehicles in back yard: ___ Number of vehicles on cement blocks: ___ Number of firearms you own and where you keep them: ____ truck ____ bedroom ____ bathroom ____ kitchen ____ shed Model and year of your pickup: 196__ Do you have a gun rack? (_) Yes (_) No; If no, please explain: Newspapers/magazines you subscribe to: (_) The National Enquirer (_) The Globe (_) TV Guide (_) Soap Opera Digest (_) Rifle and Shotgun Number of times you’ve seen a UFO:_____ Number of times in the last 5 years you’ve seen Elvis:_____ Number of times you’ve seen Elvis in a UFO:_____ How often do you bathe: (_) Weekly (_) Monthly (_) Not Applicable Color of eyes: Left______ Right_____ Color of hair: (_) Blond (_) Black (_) Red (_) Brown (_) White (_) Clairol Color of teeth: (_) Yellow (_) Brownish-Yellow (_) Brown (_) Black (_) N/A Brand of chewing tobacco you prefer: (_)Red-Man How far is your home from a paved road? (_) 1 mile (_) 2 miles (_) just a whoop-and-a-holler (_) road?
There's two different versions of the 4.0L waterpump, one for the XJ/MJ which has offset front end components and one for the YJ/TJ with centered componenets. There's about a 1/2" difference in the length of the "snout" that the pulley bolts too (the YJ/TJ one is shorter). Sounds to me like your PO installed a YJ pump and the washers you added to it, while now preventing the pulley from rubbing, are causing the pulley to be out of line with the rest of the pulleys. Jeff
I'm smelling a rat here.......how long has that dealership been sitting on that XJ? Most likely awhile, I'd imagine. Then they bait a customer (you) who gives them some hand money and signs a "contract" and mysteriously pulls it all out from under you. Hmmmm. They're probably expecting you to raise a ruckus, at which point they'll up the ante to get you to pay more for it. I'd bet there was no sale made, nor three other parties interested in the vehicle. I'd say get your deposit back and move along. It all just doesn't sound right to me as you described it. Jeff
Thrush full welded (same design as a FM40, but half the cost). Turndown tip off the back FTW. Jeff edit: see page 2 viewtopic.php?f=2&t=20546&hilit=thrush&start=15
transmission change question
mjeff87 replied to jeepaholic's topic in MJ Tech: Modification and Repairs
dragging up an old post because I decided to swap a late model AX15 into my MJ over Easter weekend :nuts: Got the 14674 bushing hammered into the crank, but NOONE has a late model clutch alignment tool for sale around here (except as part of the whole matched clutch kit). What the @#%*&! happened to parts stores anymore??? It's not like I'm working on a '37 Ford or something......all I need is a clutch tool for a friggin' mid-90's XJ fer chrissakes. Bleah............ :headpop: Jeff -
the front of the crank snout is keyed, and the HB is secured in position by a woodruff key (plus the bolt).....you won't screw the timing up any by removing it. I'd suggest an impact wrench (air powered, but a good quality electric will break it loose also). You'll need a puller to remove it once you get the bolt out, and will most likely have to pull the radiator to do this properly. Jeff
Either the hydraulic line is balooning like Bob said, or perhaps the PO had the flywheel machined when the "almost new" clutch was installed prior to you acquiring it. Jeff
MJ is Dead's 87: Operation Basecamp
mjeff87 replied to MJ is dead's topic in Member Projects: Your Comanches
*subscribed* I wanna see where this cargo top thing goes......I'm liking it. Jeff -
I've had two hard-part failures on the internal slave, with brand new parts when I converted to 4.0L. The first was two days after the conversion as I was driving the MJ home from the garage I did the swap in......one of the stupid little U-clips that hold the hydraulic lines into it fell out and rendered me clutchless. Had to limp it back to the garage and drop the tranny to repair it (replaced the clips with cotter pins, FYI). And, just as recently as two weekends ago, I noticed something metallic sticking partially out of the bottom of the bellhousing (as the clutch had been becoming more and more chattery, and worse by the day). Pulled the inspection plate and what remained of the steel washer that secures the internal unit to the tiny little roll pin driven into the bearing retainer (reference Genovast's post above) fell out. I am officially done with the internal slave POS. I have a spare external AX15 I've been keeping in storage as a backup.....it's going in on Saturday morning. Jeff
bet she could swap out a CPS in about 20 seconds flat.......
if this is the rig in your sig line, with the 2.5, go 4.88's. I ran my 2.5 on 33's with 4.56's for awhile and all was good, then I stepped up to 35's. The 2.5 did "ok" with it for the time I ran it, but it just wasn't a good setup on the highway (offroad was good, though). Just not enough engine, combined with heavy MT tires (on steel 15X10's) and increased wind resistance the 6" lift created......I was pushing the four little squirrels to the limit. I ended up swapping a 4.0 in it to solve that problem ;) My old 2.5 is still pulling faithful DD duty in pingpong's street MJ, too, 200K+ miles and counting. Jeff
PM inbound..... Jeff
Wheel rotates hard after changing front brake pads
mjeff87 replied to HOrnbrod's topic in MJ Tech: Modification and Repairs
it's those damn blasted anti-rattle clips I tell ya.....and that dumb frog sold me the wrong brake pads! :D -
therin lies the clue.... Jeff
