8
Everything posted by mjeff87
engine swap with tranny (easyest)?? ?? ??
mjeff87 replied to wannabeMJ's topic in MJ Tech: Modification and Repairs
niiiice....you've got Jeep style, my friend :cheers: Jeff -
I'll keep my eyes out for you in the local yards down here Greg....there was a beauty of a maroon bench in one a couple months ago.
Transfer Case Linkage Components
mjeff87 replied to Rymanrph's topic in MJ Tech: Modification and Repairs
Image Not Found #14 is the bracket that bolts to the tranny tunnel....the little heim sits about 1.5" to the rear on the AX15 part (it's centered on the other ones). #31 is the bracket that bolts to the tranny #15 is the rod that connects the linkage to the TC Jeff -
there are three parts of the linkage specific to the AX15 that you'll need..... the trunion bracket that bolts to the tranny tunnel that has the little orbital joint in it the trunion bracket that bolts to the tranny/transfer case studs the rod that connects the trunion to the range selector on the TC The floor shifter and the trunion contraption are the same for all tranny models Jeff -
a few of you guys know that I'm an ex-professional chef....... way way way back in my career, when I was still scouring pots and scrubbing floors, a very young Tiger came to play the somewhat infamous ameteur tour that the country club I worked at hosted. He was the epitomie of exuberent innocent youth, being coached along by his father (may he RIP). It truly was a wonder to see him and how his talent was evlolving. Fast forward about 10 years, and I was now working at a different private course cooking for some of golf's (and industry's) greatest names. Young Tiger has now become a legend in his own mind. He can't even be bothered to look me in the face as I am plating his dinner at tableside.......he brushes me and my dining staff off with a grunt. eff him, and the Buick he rode into town on too. He deserves everything that he got from his wife, and more. What goes around comes around. Jeff
shut the @#$%ing door..... this whole place needs to start growing the @#$% up a little bit. Jeff
air conditioning broken
mjeff87 replied to STERLING STINGER's topic in MJ Tech: Modification and Repairs
I don't want to break your heart, but it's not quite as simple as it seems.... to open up the system (which apparently, yours is already open/leaking) you have to recover all of the refrigerant correctly, and legally. Once the system has been evacuated, you can remove the compressor. At this point you have introduced moisture into the system, so you need to replace the receiver/dryer, install the new pump with the correct amount of oil in it and the dryer, and pull a vaccuum on the entire system to ensure no leakage. Then recharge with the correct amount of refrigerant, using both low and high side pressure gauges. Sure, you can ghetto-fab a new compressor in, skipping most of the above, and not care about anything else, but we here at CC don't condone such things. Jeff -
yes, and that's all I'll care to contribute to this discussion. Jeff
rest easy Mr. Babcock......many should take a lesson from his desire to serve country :Canadaflag: Jeff
yeah, but the BIG one is coming.......Feb 26-27. This one will be the grand finale of the season for the mid-Atlantic/eastern seaboard......triple phased monster. Get yer shovels ready...... Jeff
:nanner: . . . . . . . . . ;)
Me too, but I switch the feed type out when the season changes. Suet cakes go out in the cold too, but those come down when it starts warming up.
hope springs eternal..... Don, we've actually had songbirds here in my part of VA for the last week or so. I can't describe how beautiful it is hearing them start calling up about 1/2 hour before dawn in the morning. Time to switch the feed in the birdfeeders, I suppose. Jeff
Yet another issue, TC this time
mjeff87 replied to bruticus's topic in MJ Tech: Modification and Repairs
looks like the PO replaced part of the factory linkage with a piece of all-thread and a couple of heim rod ends (I'm working on a similar setup now, too). Third pic shows one of the jam nuts loose on the rod, meaning probably the all-thread spun and that part is now the wrong length. Check and adjust, then tighten the jam nuts back down to keep the length fixed. Also, is your rig at static height in those pics or is your rear suspension in droop? If that's normal ride height, I'd be worried about your rear driveshaft length. That slip yoke is pretty far out of the tailcone. Even if it doesn't fall out, you'll probably have some bad vibes going down the road. Jeff -
no, some CAD models had a contact switch with a single wire coming out of them above the vaccuum connexion. I would ASSume that the switch inside the housing is NO, and when vac is applied and the fork slides over it closes to compete the circuit and illuminate the dash light. Most likely it's a switched ground, but that's just a guess. I'm not running any of the vac or wiring on my rig (shimmed over shift fork). Jeff edit: just snapped a pic, and the wires are orange.....I'd say it's a switched positive based on the wire color. Image Not Found
nothing.....we got back from our weekly pilgramage to Walmart and she ran into the bathroom and puked breakfast up (I made french toast, fried apples w/ cinnamon and brown sugar, coffee and chocolate milk). Then I went to the bar and watched some of Daytona. I do have a nice roast beef that just came out of the oven, and am working up mashed potatoes, roasted carrots, au jus and rolls. Dinner is in about 30 mins. Jeff
already on the news up here Don.....prayers for your daughter and rest of family :shake: Jeff
location? I've got a couple 2.5/AX5 shafts but shipping might not be worth it for you. Jeff
I almost ran away with a girl back in high school that lived on the other side of the Quemahoning dam.....turned out she was a full-on nut job. Hindsight, 20/20 as they say... :D you should also check out bigrubbers4X4.com, it's a local club in that area. The club prez, bear, posts on here from time to time. Jeff
I'm from Johnstown originally.....moved down here to VA about 10 yrs ago. Still get up home every 6-8 weeks or so, though. Welcome to the club Jim. Now go sell the S-10 and get an MJ ;) Jeff
Brake fluid leaking from bell housing
mjeff87 replied to marky0140's topic in MJ Tech: Modification and Repairs
maybe the slave didn't die, but it's quite possible that one of the stupid little U clips that hold the lines into it fell out and a line popped off. Happened to me with a brand new one I installed within 24 hours. Replace those POS clips with cotter pins. Jeff -
we need to meet up the next time I'm back home.....Indiana is some of my old stompin' grounds :cheers: My mother is a retired teacher from United School district, and we have a family farm (80+ acres) up in Armagh. Jeff
We ended up with about 8-9" of snow/sleet here, plus about an inch of rain last night in the middle of the whole damn show.....our local club has spent the last two days playing taxi for med staff into and home from the local hospital. Couple shots from today, the MJ never made it out because I was chauffering multiple staff and their belongins. Gonna be back out @ 0600 tomorrow for shift change. Talked to mom at home tonight (Johnstown, PA) and they got 25" :fs1: Jeff Image Not Found Image Not Found
how to: install a factory transfercase skidplate
mjeff87 replied to mjeff87's topic in MJ Tech: DIY Projects and Write-Ups
sorry Wade....been out shuttling medical staff into the local hospitals all day today and just got home. Need dinner, shower, and several beers (not necessarily in that order LOL). IIRC the skid doesn't block the tranny mount holes in the bottom of the Xmember. But if it does block one or two of them, that's nothing a 1/2" holesaw coudn't fixx.... ;) JEff
