8
Everything posted by mjeff87
buy it, also check out this month's JP mag for a list of common problems that you may need to address. Jeff
Eagle, I'm no help on your current quest but I'll keep my eyes out for ya. If in your search you happen to run across a 99-01 XJ Sport, 2-door BLACK 5-speed though, and you pass on it, let me know. I want one of those (specifically), but that's not something you can order up at a used car lot/dealership, ya know? :yes: Jeff
As I recall all of those C4C vehicles have to be moved out of junkyard inventory within a certain time period (6 months or something similar). There was a huge glut of all makes/models in my local yards when it first started but they're all gone now. Idiots (that designed the stupid C4C program), every last one of them..... Jeff
WIfe and I are taking a long weekend and heading up to NYC. A couple of friends of ours from PA are driving up, we're flying up and meeting them, staying in midtown. Don't really have anything on the agenda other than making it down to ground zero (I've got pictures from up inside the towers from the last time we were there). If anyone local wants to meet up for lunch and/or beers shoot me a PM and I'll give ya my cell #. The only meal that is set in stone is tomorrow night, a little Italian place called Ralph's that is always the mandatory first-night-in-the-city dinner. Little hole in the wall place at 56th and 9th, but they have THE tenderest veal I've ever eaten :yes: . Jeff
ballpark, to do it right, I'd say minimum of $500 for the front end. If you buy all new shiny stuff even more. Shop around the classifieds and see what folks are selling off either moving up or out of the sport....take your time and don't half azz it. You'll be happier in the end. Figure out what it is you want out of your rig. You may end up better off with a smaller lift staying spring under and only going 2-3 inches. With that, you can get by passibly still using stock front end components and not spend as much. From your sig line, you say you want to go to 31" tires...you can do that easily with a simple AAL in the rear and some coil spacers in the front. I wouldn't consider going SOA unless you were considering 33-35" tires, and even those can work with less lift and a judicious application of a sawzall and proper wheel backspacing.
I don't have that kind of scratch lying around (nor will I ever, probably) but that is a VERY modest asking price considering what he's done to it and what he's put into it. Hope he gets it, or even more.....it's definately worth it. Jeff
you'll net at least 5" with an SOA, depending on a few things (2WD vs 4WD springpacks, condition of springs, type of perches you use, etc.). The front is a whole different can of worms. At a minimum, you're looking at longer/adjustable control arms, trackbar, swaybar links, shocks and brakelines. SOA is cheap for the rear (about $50 for perches and new U-bolts), not so much for the front end. Jeff
come income tax check time I'm thinking about getting one of these for da MJ......$219, with an additional 10% off using a discount code. It's actually designed to incorporate tabs for a link system, but I don't plan on doing that anytime soon. Discuss..... http://undercoverfab.com/truss-systems/ ... ystem.html
the maturity level on this board slips furthur away with each passing day..... :shake: (jimoshel, maddzz1, gambit4000s, dakal and akamcbird, I'm not referring to any of you) Jeff
I can't find my copy of it at the moment, but click on over to the Pirate website and navigate your way to Billavista's tech repository.....there's a .pdf of the AX15 service manual there amongst the millions of other great tech info. It covers the complete teardown and reassembly of the AX15, you can see the parts I'm talking about. There's a plug on the passenger side intermediate plate (I think) that holds the check ball/spring assembly I'm talking about. Jeff
one of the plug bolts on the passenger side holds the spring and check ball inside the tranny housing for that shift rail. Unscrew it (carefully) and remove the spring and check ball, then shift it out of gear. Reinstall everything and you should be good to go. I've got a .pdf file on the AX trans somewhere that shows an exploded view, lemme see if I can find it. I'll post it up if I can. Jeff
The uber-rare economy/fuel miser package.......I've yet to see one of those setups live and in person. About as rare as the stock 4.56 pacakge, which I've seen several of (and am running a stock D30/4.56 from one of in my MJ currently ;) ) Jeff
I'd love to take that skidder for a quick little ride.....any chance they left the keys in it? :D Jeff
That has GOT to be your house Bob.....with a garage, attached to a garage, attached to a garage, with an attached shed....... ;) where you hiding the fleet at? Jeff
I'm assuming you're the same guy who posted the same question over on NAXJA :roll: I'll repeat.....the quickest, SAFEST, and easiest solution for you is a class III hitch. don't put a D-ring thru the trailer-ball hole on the factory bumper don't hook to anything on the suspension when you develop the fab skills or can afford to pay someone who has them, build a rear bumper that incorporates recovery points. Jeff edit: welcome to CC
AW4 help needed, stuck in 1st gear
mjeff87 replied to mjeff87's topic in MJ Tech: Modification and Repairs
'twas a bad TCU......all fixxed now ;) Jeff -
Loud Tapping Noise: Help:S
mjeff87 replied to jeeplover88's topic in MJ Tech: Modification and Repairs
could be a loose speedometer cable. It's held to the UCA bolt with a small springy clip which may have fallen off. Jeff -
87+ 4.0L, with closed cooling systems, yes...pressure bottle is on the firewall. 2.5's all have/had the overflow bottle sandwiched between the driverside fender and the airbox. I've yet to run across a 2.5 with a closed cooling system (doesn't mean they don't exist, just that I've never heard of one nor seen one ;) ) FWIW, my 87 was a 2.5 originally, with the overflow on the fender. I reused it in it's stock location when I swapped the 4.0L into it and kept the open cooling system. Jeff
It's not 86 unique, but it is 2.5L unique. I've got a spare one if you can't find one locally, PM me if so. Jeff
I'd be lying if I said I didn't exercise some of that same "wisdom" at a younger age as well :oops: Jeff
the older style switches on our MJ's aren't adjustable per se, they are a funky little arrangement that attach via the through-bolt on the top of the pedal rod. It's a spring loaded switch with a small plastic shim inside of it that can become very finicky. You may need to replace the plastic shim to get yours to function better. Newer style (mid-90's XJ's) use a plunger-style contact switch at the top of the pedal assembly, which is vastly easier to adjust. Jeff
or....don't burn your tires thru a crossroad.....
Driveway Tranny Drop...any tips?
mjeff87 replied to ParadiseMJ's topic in MJ Tech: Modification and Repairs
also......get a tranny jack. Jeff -
hopefully the driveway is concrete or asphalt, not gravel/dirt. Try not to make a mess......use some old shower curtains or large pieces of cardboard underneath, or even a piece of 7/16" OSB (about $6 for a 4X8 sheet at Lowe's). Beg, borrow, or rent a tranny jack. If it were a manual tranny, you could get by with the floor jacks and whatnot, but an AW4 is considerably heavier, even moreso if you plan on dropping the tranny/TC as one unit. Think safety above all else. Ratcheting 9/16" wrench is a godsend if you plan on divorcing the TC from the trans prior to dropping it (for the 6 nuts holding it to the tranny), and you'll need an E12 socket and a boatload of extensions for the two top bellhousing bolts. 5/16" or 8mm to remove the driveshaft yoke bolts for the front/rear driveshafts, and either an offset box-end or other type of 1/2" or 10mm wrench (depending on which style of boltheads) for the four bolts holding the front driveshaft DC to the front TC yoke. 13mm socket for the tranny mount bolts, and a 15mm for the crossmember bolts/nuts. Bellhousing bolts other than the two top ones are either 18mm or 3/4" IIRC, and you'll need 1/2" for the dust cover/inspection plate bolts. Oh, did I also mention a tranny jack? Yeah, do yourself a favor and get one of those too ;) Jeff -
1987 Jeep Comanche 2wd to 4wd
mjeff87 replied to ComancheMan7893's topic in MJ Tech: Modification and Repairs
cheap, fast, good pick two of the three options listed above, 'cause you're not gonna get all three. Jeff
