8
Everything posted by mjeff87
I got them thermostat blues...
mjeff87 replied to mjeff87's topic in MJ Tech: Modification and Repairs
every living-breathing fiber in me says "therm-o-stat", but I can't come to terms with that diagnosis..... I'm gonna run it some more and cycle the 'stat, mebbe it just needs to find it's happy place after a few heating/cooling cycles. I dunno :dunno: -
Is rear u-joint at axle a 1310 size?
mjeff87 replied to 91coMANche's topic in MJ Tech: Modification and Repairs
unless you have a swapped-in axle of a different make (i.e. Ford 8.8, D60) yes. Spicer 5-153x (greasable) Spicer 5-785x (non-greasable). I'd opt for the 153x. Jeff -
Been having a problem with the coolant temps in the MJ (for about the last year, actually)....it's running too cool. Changed t-stat last year, no difference. Put another new stat in over the weekend, refilled the coolant and ran it to purge the air out.....it came right up to 190-ish, stat opened and it plunged back down to 120-140 and stayed there. If I let it sit and idle, it comes up to about 180, then drops back down to 160-ish and back up. As soon as i start driving it though, it drops like a rock to the first hash mark on the gauge and stays there, even dips under it if I turn the heat on. All t-stats have been Stant 195 deg superstats.....I can't believe I got three bad ones in a row (???) And I've put two different sending units in it too, same results with either. The only thing I can think of, and it's a longshot, but back when I was rebuilding this 4.0 I pulled the welch plugs and noticed a good deal of crud (chunks, actually) built up between the cylinder sleeves. I spent a decent amount of time cleaning out the inside of the block with scrapers/screwdrivers/brushes and a shopvac. Mebbe I should left all that junk in there :nuts: I've got a heat gun I'm gonna shoot temps with (again) to confirm the gauge reading, but if it's like last time there won't be any difference. For reference, my rig (and swapped in 4.0) are '87, converted to open cooling system with stock radiator and fan clutch, no electric/aux fan installed. I've only ever seen it hit 210 once, and that was back last summer when I was stuck in traffic and it was about 100 degrees out..... Thoughts? Jeff
HBD Pete :cheers: Jeff
Stranded MJ...... (Recently identify this part)
mjeff87 replied to ComancheKid45's topic in MJ Tech: Modification and Repairs
knock sensor..... -
I want to say it's right around 43.5" or so, but don't quote me on that. If noone else can confirm, I've got my stock 'shaft down in storage and can go measure it for you. Jeff edit: on second thought, that may be the measurement between the spring perches on the rear axle.....I confuse easily in my old age after about 10 beers or so :D
pwned :cheers: Nicely played. I've bought entire vehicles for less than my missus has paid for certain pairs of shoes. And I'm not kidding, either. Jeff
If you're disk-ing it Don, hang onto those drum parts, especially the backing plates. Them sunsabeotches ain't cheap......you might could help out a fellow Jeeper with them. Jeff
brake light on and won't go off
mjeff87 replied to duane300z's topic in MJ Tech: Modification and Repairs
If you replaced the rear lines because of a blowout, there's a switch in the prop valve in front of the MC that probably tripped...you may need to reset it. Push down on the pedal, steadily and hard, until you hear a "click". That will be the switch resetting, and the light should go out. Jeff -
weenie............ :rotf: Jeff
Needed a new radiator for the TJ, and on a suggestion from NAXJA I checked radiatorbarn.com as well as the local usual places. HOLY FAST SHIPPING BATMAN!!! I ordered a rad from them online yesterday afternoon, around 2 PM....the big brown truck dropped it off a bit after noon today (I took a sick day 'cause I had to rebuild the front driveshaft before it exploded :D ) Kudos to rad barn, if anyone needs a new rad I would highly suggest them. Free shipping and a $5 discount if you order online Jeff
they did....the gearing was a feeble attempt to make up for the lack of OD in the tranny. Many, many moons ago when I first decided to convert mine to 4WD I bought a D30 from a local guy who had an 86 2.5L. I never checked the ratio, just ASSumed it was 4.10 :oops: 87-89 2.5's got the AW4, not the 904...and came with 4.56's. Jeff
x2. :thumbsup: comes in 4x8 sheets and can be had with the reflective aluminum on one side. That's what I used in mine a couple three months ago (foil backed). 2 sheets @ $15/ea and some duct tape to seal the seams. I added them moreso for the summer because my door has a SW exposure and catches sunlight from about 1PM until sunset, but it's working out quite nicely in the cold. My garage stays right about 20-25 degrees above ambient. Of course, the extra insulation I installed whie it was being built helps alot too :D Jeff
Holy Hanna....the dead have risen.... how ya been James? Good to see ya ;) Jeff
I was gonna help her, but...... I was laughing to myself so much I didn't think I could keep a straight face. The register attendant gave her the only thing she could think of, which was an extra winsheild squeegie thingy. Hillarity then ensued :D
I've yet to find one in any junkyard I've been in....not saying they don't exist, but they're kind of a rare bird. Advance Adapters now offers a "kit" to mate the two together. Not cheap, but readily available. Jeff
not to offend, but are you sure that TC has an actual SYE installed, or is it just the newer style case with a (stock) sealed output? If it does indeed have an SYE you'll have to build or have made a new rear driveshaft. If it's just a sealed output you can reuse your existing shaft. Jeff
I swear I'm not making this up. Stopped by the local gas station to pick up the newspaper on my way into work this morning, and noticed a TJ at the pump and a smoking hot blond walking from it toward the door of the station. I hold the door open for her, she goes in and right up to the register as I get my paper. When it's her turn, she asks the attendant if he has anything she can use to get her keys out of her LOCKED Jeep outside.......she says she has the window open but can't reach the keys in the ignition. The TJ had a soft top on it. I giggled as I got in my TJ and drove away. Jeff
they're about 1.5 quarts each, give or take.....I just buy a gallon jug which is usually enough to fill both. Odds are that I have a leftover bottle from a previous change that has a little in it if I need more :D Jeff
yeah Don, I'm wondering too..... :roll: Jeff
saw that over on PBB the other day.....effin hillarious :rotf:
I was just askin' about you and where you've been...... Merry Christmas :cheers: Jeff
^^^WTH???????^^^ (I woulda said "WTF" but this is a family place, ya know......) Oh, and cool by the way ;) Jeff
