mjeff87
    8
Everything posted by mjeff87
  1. yup, that's what I did..... Jeff Image Not Found
  2. mjeff87
    discos
    X2.....I scored a used set of JKS quicker disconnects (newer version) for $50 ;) and love them. Jeff
  3. Thanks all......I'm not in the 40 club, yet. Close though (38 ). I celebrated yesterday by leaving work early and putting a new steering stabilizer on the MJ 8) Jeff
  4. Pat, you can have my IAC, but it'll be attached to the engine.....in about a month :D Jeff
  5. If you do nothing else, get some steel wool and stuff it inside the lower heater vent openings (on the tranny hump), and close all your dash vents. That will keep them out of the HVAC plumbing....trust me, I speak from experience. You do not want them in there. Five years later, and I'm still picking pieces of bedding out of my vents :roll: Jeff
  6. He's still kicking it, just busy with work. I went down to his place last weekend and raided his parts pile.....came back with a whole bed full of stuff :chillin: He's DD-ing a cherry black 88 (I think) 2.5 MJ now too..... Welcome back, DC :cheers: Jeff
  7. I reused the stock plates flipped on top, and bought a set of short shocks. They work fine, but I do have a set of RE weld-on perches to put on the tubes, sometime this year... Jeff Image Not Found
  8. Throttle body injection (TBI) Sounds like a semantic difference to me.... Jeff
  9. 87-89 XJ/MJ's with an auto and 2.5L engine only. And if the rig is 4WD, you get the bonus of a 4.56 geared D30 front, too. Jeff
  10. sittin' here doing my best tonight....this is the first year in I can't remember that I'm not back home in PA doing the shamrock shuffle. I'm about 2 beers away from not making it to the bedroom ;) Martin clan, County Galway. Wife and I are going back to the Emerald Isle next year for our (belated) 15th anniversary. :cheers: Jeff
  11. If it was a 5 speed, yes. '87-90 XJ/MJ's that came with a 2.5 and an AW4 got 4.56's. Jeff
  12. If it's factory, the rear axle will have 4.56's in it..... That bellhousing is a pretty rare bird, too. Also, the torque converter is unique...the front part of it that fits into the crank end is different than a 4.0 version. Jeff
  13. mjeff87
    Howdy!
    Yeah, but I bet he's a Browns fan...... :roll: Just kidding :D welcome aboard.... Jeff
  14. FWIW, I'm using 5.5 TJ coils on mine in the front with a 3/4" spacer. It's got about a 3/4-1" rake. The coils are softer than XJ/MJ ones, and I just put new front shocks on yesterday along with a set of BPE's. Almost rides like stock again :D Jeff
  15. huh....I'll be damned. Thanks guys! Jeff
  16. OK, calling all you 4.0 wizards..... How do you get the rear fuel line disconnected off the rail? I've got the special tool, which works great for the supply line to the regulator, but there's not enough room to slip the tool over the metal line and get it inside the fitting to pop it. Is there a special-special tool? Jeff
  17. RedBull....I'll PM ya. Genovast, I see that you have two same year MJ's.....I'm'a PM you as well. Thnx! Jeff
  18. If you do, please PM me.....I need to ask you a small favor. Thanks, Jeff
  19. I don't want to put out bad information, and I don't want to come across in the wrong way JeepcoMJ, but have you actually done this swap? Reason I ask is that I've been doing serious amounts of research on it in prep for mine, and it doesn't appear you need the interior harness to make it work. I've talked with three different people who have done this swap successfully, one used the interior harness but the other two simply plugged the engine harness into the bulkhead of the 2.5 harness and everything worked. One even used an XJ harness, and both of the two used different model year engine harnesses than what their vehicle was. I've also researched thru FSM's and dealership parts catalogs, and the same interior harness p/n was used for each model year from 87-89, regardless of drivetrain (engine or transmisson, 2 or 4WD). The only difference in interior harnesses is diesel versus gas engine. On the gas models, seperate engine harnesses are listed, but each plug into the same bulkhead connector, which is hard-wired to the same fuseblock, and associated interior harness that has the same part number. Leaving the 2.8 and diesel out of the discussion, the only differences in the engine harness between a 2.5 and a 4.0 Renix are the injector circuits, cam sensor, knock sensor, and location of the EGR solenoid from what I've compared....and none of those feed thru the bulkhead connector. They only go to the ECU (which is different, of course). Jeff
  20. you're gonna need the 4.0 engine bay harness, including the ECU. Looks like this ;) Image Not Found
  21. on the TC shift rod, put the case in 2HI and loosen the trunion nut that holds the rod in position. Then, put the shift handle in the 2WD position and tighten the trunion nut back down. Also, there's three different sized linkage rods (the rod that actually attaches to the TC) depending on what tranny the TC was behind. The AX5 is the shortest, then the AX15, and the longest is the AW4. Make sure you have the correct rod for your tranny or it won't shift into all positions. Jeff
  22. they're 15X10 Cragars with 3.75 BS :chillin: Jeff
  23. yes, there's a tiny tack weld on each as well, behind the rivets. Look for a tiny little dimple behind where you drilled and you'll see it. Take a thin chisel or a screwdriver that you're not too fond of and pound inbetween to pop each one. Jeff
  24. mjeff87
    Tire Poll
    in...... ;)
