mjeff87
    8
Everything posted by mjeff87
  1. I have one of the E7091 assemblies (bought from a club member), new in box. It is a Cherokee pump assembly. Jeff
  2. mjeff87
    whats 4 lunch
    Wahoo, you forget (or maybe I never mentioned it), but I was a professional chef for about 16 years, up until '99 when I blew my knee up and couldn't walk for over a year.....now I'm a fat lazy state employee who buys food instead of cooking it :chillin: The best food is kept simple with good ingredients, with proper cooking technique. Let the flavor come out of the food, don't try to add flavor to it Jeff
  3. mjeff87
    whats 4 lunch
    at least we're not talking about barbecue............. :popcorn: Jeff
  4. It's a vaccuum operated valve that allows coolant flow to the heater core. When you slide the temp control on the heater control over to hot, you also are sending a vac signal to it to open up. When it's set to cold, coolant doesn't circulate thru the core. You can eliminate it, you'll just have your core active all the time. It may be a bit warmer inside the cab in the summer, though. Jeff
  5. For an auto, there are 4 nuts that attach to the studs on the booster that hold the pedal bracket to the firewall. They are 14 or 15mm. The two nuts on top are larger, 17mm IIRC. The auto bracket doesn't have provisions for the clutch pedal. The manual bracket has an extended piece at the bottom (at the firewall) that has a stud in it for the clutch master. It is a royal PITA to get all four booster studs and that stud for the clutch thru the firewall and lined up. At least for me it was.....I think an extra pair of hands holding the booster from the engine side while you line everything up would make it easier. Jeff
  6. mjeff87
    whats 4 lunch
    Never had Alabama fried chicken Don, so I can't comment ;) I had some in Tennessee a couple years ago, and it was not good. It's funny, up in PA there were two local places that did fried chicken (actually "broasted") that were the gold standard, everyone got their chicken for every event (weddings, cookouts, reunions, etc.). We all grew up eating it. After moving down here and tasting the real deal, my wife and I can't stomach the hometown stuff anymore. Jeff
  7. I used a 96 XJ booster, no spacer, and the pedal assembly from the same vehicle. I tried to mod the end of the pushrod to work with my '87 brakelight switch, but ground off too much of the end of it, and the switch couldn't make contact :oops: It was a PITA swap (the pedal assembly), but the overall mod was probably one of the best one I've done so far. I'm running 33X12.5's on 10" steelies, and I can lock them up now. Here's my writeup on it: http://comancheclub.com/forums/viewtopi ... highlight= Jeff
  8. mjeff87
    whats 4 lunch
    Had the three piece special from the local market, with collard greens and mac and cheese (with hot sauce, too), plus roll and butter and sweet tea. It may be a stereotype of sorts, but the South makes the best dang fried chicken, hands down ;) Now I'm home brewin' up dinner, and swillin' Bud Lime's..... Jeff
  9. we're not a fickle bunch here........check the "Beer Drinkers, have you tried...." thread. We'll drink just about anything ;) ('cept CW, he doesn't understand the complexity of citrus :nuts: :D ) Jeff
  10. damn....these Bud Lime's are going down too quickly...shoulda bought a 12 pack :D
  11. true 'dat.... :cheers: My beer of choice, when I'm in the local area, is Sol. Just as good as Corona, but half the price :D (yeah, it's like .50 per bottle compared to .99.... ;) )
  12. FYI....much cheaper to have a longer driveshaft shortened than to have a shorter one "lengthened"...... Jeff
  13. Glad to hear it Joe :cheers: Jeff
  14. X2, picked up a 6'er on the way home from work. I do miss the little bits 'o lime floating in it, though.....takes away from the whole effect. But it's MUCH better than the chill. Jeff
  15. you can wiggle the alt out from the bottom with the skid in place.....ain't easy, but it's doable. Either that or pull the battery and the battery tray and pull it from the top. My preference is from the bottom, though.... Jeff
  16. Welcome to the club..... there's no official dues, but new guys hafta buy the beer :cheers: Nice MJ! Jeff
  17. also, the 2.5 has a remote fluid resivoir, bolted to the front radiator support....the 4.0 has the pump and resivoir all in one unit. Jeff
  18. Quite unusual for Tidewater. There was an outbreak up here last Monday (we were flying back from Puerto Rico and flew over them at 38,000 ft). The one that hit Suffolk was an F3, damage now is up to $28M, and rising. Stuff can be replaced, people cannot. My bud and his family are o.k., that's what counts. But, I don't want to see or even hear a chainsaw for at least a month...we did a year's worth of cutting in 5 hours. Jeff
  19. Didn't need to use the MJ, there was plenty of heavy equipment down there. I got some pics, but only of houses that were vacant.... Click the full-size link: Jeff
  20. Yeah, like this. I've got the switch, and it's on the to-do list.....I've got mine shimmed over with washers currently. Jerry (tjbliley) is in the process of rigging his up with air solenoids, should be pretty slick when he's done. Jeff Image Not Found
  21. One of my best buddies (and fellow Pittsburgher!) got pretty hammered by those tornadoes down in Suffolk, VA earlier this week. He and his family are o.k. but he's got about 20 trees on his house (his chimney got ripped off, blew out 6 windows, and demolished his wife's car in the driveway, too). I'm heading out with the MJ in recovery mode early tomorrow morning (they were just allowed back into the subdivision today, but still don't have electricity) with chainsaw, generator, gas, beer, and other implements of destruction, so I might not be on the board for a day or so. I'll try to get some good pics. Plan is to get all the wood off the house, cut some of it, and drag the rest with the MJ up to the street. If anyone's around Suffolk, look for the MJ. Bring a chainsaw.....beer will be provided ;) Jeff
  22. Yeah, I'm using a factory tow bar mount on mine that I found on an XJ in the junkyard. It bolts up to the factory brackets, sandwiched between the brackets and the hooks, and runs across the lower header panel. Image Not Found
  23. My wife hates beer too, but we found one she liked when we were on vacation last week. Blue Moon, it's a Danish wheat ale.....drink it like you would a Corona or Sol, but instead of a lime, use an orange wedge. Oddly enough, it really tastes good (even I liked it). Jeff
  24. I like beer, and I like Clamato, but not together..... Beer + tomato juice + vodka= a "redeye", a classic drink Jeff
  25. I've seen two different types of nut for that passenger side tow hook bracket bolt. Older Renix's have a regular hex head nut, but the newer engines have a "sleeve" type of nut that has a very low profile head, but the shank of the nut fits inside the hole in the framerail. IIRC, the bolt is a bit shorter too. Might wanna try one of those, they give an extra 1/2" of clearance or so. Jeff
