8
Everything posted by mjeff87
it's a 1/8" bit, and the tip (about 3/16") snapped off deep inside the middle of the stud. I'm gonna go work on it some more with a set of small punches and see if I can break it up any. Jeff
up to 536..... ;) Jeff
swb 4.0 auto 44 rear SYE rear driveshaft ???
mjeff87 replied to JeepcoMJ's topic in MJ Tech: Modification and Repairs
not sure on the exact length, but a V8 ZJ has the longest front DS of all. It may be close. Jeff -
Woring on a 4.0 rebuild (on a stand, not in the vehicle). The front exhaust manifold stud was snapped off inside the head, and I tried to drill it out. Things were going along well until I snapped the tip of a 1/8" bit off deep inside the stud, and I can't get the piece out. I've got the stud mostly drilled out, about 1/2" deep into the head, but can't get any furthur than the piece of broken drill bit. Any ideas beside pulling the head and taking it to a shop (or replacing it)? TIA, Jeff
voted.... :USAflag: Jeff
Should I buy this Engine Puller and Stand - $100 Craigslist
mjeff87 replied to SuperWade2's topic in The Pub
If you pull/hoist the engine from the side, you won't be able to roll the truck back....the legs on the hoist will be in the way. Or are you thinking something else? Just trying to save you from one of those "oh #$(&@%^" moments, we've all been there..... ;) Jeff -
first mod was replacing the crapped out factory shift knob with a pool cue ball, then wheels/tires, then a 4WD conversion :D Jeff
"you know that's bootleggin' boy......and that's illegal" :D Jeff
almost the same part # too.... CTS - 3300 2383 (dealership) TS82451 (aftermarket, Neihoff, $22.99) MAT - 3300 2382 (dealership) TS81351 (aftermarket, Neihoff, $35.99) Careful if you try to swap the MAT, I snapped mine off clean with the manifold surface. I ended up pulling the guts out of it (luckily they didn't fall into the intake) then used a small fluted extractor to back out the threaded part stuck in the manifold. What I expected to be a 10 minute replacement turned into an all-afternoon affair :headpop: My CTS is still original, and I have to assume it's still working. Jeff
you probably have a big air pocket in the circuit now. Is this an internal slave, and if so, did you leave the little plastic bands attached to it when you put it in? If you did, you should have heard/felt them "pop" at some point in the process. I'd try the standard bleeding process as Brent mentioned (you'll probably displace about 2X the MC volume of fluid to fill the slave until all the air is out. You might also try gravity bleeding (open the bleeder and pop the cap on the MC, and keep an eye on the fluid level). Jeff
*sniff* *sniff* That's what my MJ looked like when I first got it (minus the huge azz sign in the bed, but the PO was an old man who made his own "tonneau" cover out of 2X4 and blue poly tarping). Brings back sweet memories....I wish I would have taken a pic or two of it way back then. ;) Jeff
edit: here's the writeup I did on it.....HTH :cheers: http://comancheclub.com/forums/viewtopic.php?t=3432
Tom, The one on the top of the manifold is the MAT sensor, has nothing to do with temp. The one in the side is what feeds info to the ECU. The sensor in the back of the head only sends signal to the gauge (or idiot light) in the cluster. :cheers: Jeff
yes, they are the exact same skid....but there are differences between a 231 and a 242 skid. They both bolt in the same, but the 242 is bent a tad differently, to accomodate the larger case. You can use a 242 skid under a 231 no problem (it'll just hang a bit lower), but you may have issues trying to use a 231 skid under a 242. I did a writeup when I installed the skid on mine, I'll see if I can find it and post the link. If yours didn't come with a skid initially, the holes for the mounting bolts will be there on the tranny Xmember and the framerail, but the nutserts won't be installed. You can use a self-tapper on the framerail and conjure up something for the tranny crossmemeber bolts if you want. I opted to swap crossmembers and installed a nutsert in the framerail when I did mine. Jeff
they're T-55 if I remember correctly. Jeff
Violent Shake? Any help?
mjeff87 replied to mknherhappy's topic in MJ Tech: Modification and Repairs
:roll: -
positive...negative....I get confused every time I think about it (too much fruit in the beer will do that to ya, you know 8)?) Mine's rotated in the same direction as yours is, just not as much :D Isn't the factory spec something like 7-8 degrees? You're just about spot on, CW. Jeff -
I shoulda mentioned that I readjusted the caster with longer fixed lowers and adjustable UCA's. When I first lifted it, I only used the fixed lowers with stock UCA's and had to remove the front DS due to horrible pinion angle. Adjustable uppers solved that problem, but I had to dial in the best length......it's a delicate balance between pinion angle and caster (which can only really be solved completely by rotating the knuckles). I ended up at around 4.5-5 degrees negative caster, and the driveshaft doesn't bind. Steering feel is a bit "vague" with the little caster, but it's livable. The only issue I have now is a small camber issue due to the axle tube being rotated more forward than stock. I'm considering offset balljoints. Jeff -
I'm rebuilding the engine on a stand at the moment......it's all clean ;) I don't even have the manifolds on the block right now, and want to pop the injectors and fuel rail on while it's on the bench. When I drop it in, all I want to have to do is plug up the harness and fuel lines. Jeff
ayup....thanks :cheers: Jeff
I need new injector o-rings for my 4.0 build. Does anyone sell a whole kit, or do I have to buy them individually (at like $1.50 per injector :nuts: ) Jeff
X2 on checking toe. I had basically the same issue with mine, and finally got the tape measure out. I was toed in an extra inch :oops: Reset it to 1/2" and not a wiggle since.... Jeff -
Wear good eye protection, regardless of what you use :cheers: The flares are held on by metal strips sandwiched between them and the fender (with studs that go thru the fender). If you cut with the flares still attached, you'll feel the metal strips when you get to them. Just keep everything level and take your time. Jeff
