mjeff87
    8
Everything posted by mjeff87
  1. yeah, like I said, it's a good price for what it is. I have a HF gun, not sure what model it is but it was cheap.....I've used it for some light/medium duty stuff and the impact mechanism is getting sloppy. For what I paid for it it's not worth trying to refurbish. I figure the Craftsman model will get a bit longer life. Jeff
  2. Caught this on NAXJA, passing along for anyone interested. Today only sale on a Craftsman 1/2" air impact gun, 340 lb/ft torque. If you follow the link and add it to your basket it still shows as full price when you first add it, but if you view your cart, you get a $16 discount added. I ordered it online earlier today at work and picked it up in-store on the way home (saved shipping costs that way :D ) Pretty good deal for $20...... http://www.sears.com/shc/s/p_10153_1260 ... 0383&aff=Y ^^click me^^ Jeff
  3. That would be the compressor pumping down almost into a vaccuum and being shut off by the low pressure safety switch. I just replaced mine about 3 months ago, which had been doing that for the last 3 years. Jeff
  4. Here's a writeup with a couple of pics of when I replaced the timing chain on my 2.5......which involves pulling the HB. Considering there's a lot less clearance between the front of the engine and the radiator on a 4.0 vs. a 2.5, I'd recommend you pull the rad like I did. I didn't "have to", but I did just to be safe.....I'd think with a 4.0 you'd almost have to pull it to install the puller. HTH, Jeff http://www.comancheclub.com/forums/view ... ming+chain
  5. bang out the old ones with big hammer, and install the new studs with same hammer and a drift.....I just replaced a set on a Renix manifold recently (but the manifold is on the bench, not still in the vehicle). Pricey little suckers those studs are....mine were $5 and some change from the dealership, EACH (and just the studs, no nuts or washers either). Jeff
  6. everything from an XJ will swap for a 4WD conversion EXCEPT the rear DS. You can reuse your MJ console. Jeff
  7. IIRC the torque for steel wheels is 80 lb/ft.... When I had alloys on the MJ, I torqued them to 100, and checked them every once in awhile. Never had a problem. Jeff
  8. I did the same thing too Rick. Having a black interior, it's next to impossible to find matching interior parts, and when I stumbled across the black buckets in the 4dr XJ they were in, I snagged them. It really is a PITA getting stuff in/out from behind them, but, as you say...."I can live with it" ;) Jeff
  9. yer not gonna get a wife and younguns into a TJ....comfortably, at least :popcorn:
  10. ahhh......ya.... :eek: Fastenal, or the dealership then (and I thought PA rust was bad......) Jeff
  11. Pete, how bad off are yours? When I redid my leafpacks, I considered replacing all the mounting hardware, but I broke out the bench grinder with the wire wheel.......what I thought was bad was really only surface rust. I cleaned my originals up and reused them. The factory stuff is case-hardened, which is kinda difficult to find unless you go dealer like Don said (at least down here it is). Jeff Image Not Found
  12. Yup.....I even have trouble with the top ON if it's really windy :cry: And if you're thinking the 2.5 will get great gas mileage, that's not the case. I average a fairly consistent 20 MPG, and that's mostly highway mileage back and forth to work. Don't get me wrong, I love my TJ, and got it for a good price, but if I had to do it all over again, I'd at least opt for the X model (4.0). Jeff
  13. Who would ever think of doing THAT???? :D Jeff
  14. mjeff87
    A Drunken Rant
    It's like the "Jeep wave" that only happens if you're in a SWB Jeep. If I'm driving my BONE STOCK TJ, every TJ/YJ that I pass waves at me. But I can drive past the same people in my hopped up MJ and nothing :nuts: I've gotten a total of one wave from an XJ to date. It was pretty well built, and we passed each other going into/out of the junkyard. Jeff
  15. mjeff87
    budweiser
    I live on Bud Light..... :cry: What is really sad about it is the possible fate of what InBev is calling "non-core" expenditures. A/B owns and operates three large facilities here in VA, Busch Gardens, Water Country USA, and Kingsmill resort, all within a stone's throw of the brewery down in Williamsburg. They contribute over $1M in tax revenues to the local economy, as well as employ 3-5000 people. Jeff
  16. My wife has always had allergies, but I never had them until we moved to Virginia. Now, tree and grass pollen in the spring, and mold spores kill me. When I get a flareup, I steal a couple Loratadine (Claritin) from her, and they clear me up within an hour or so. I'll go into sneezing fits in the evenings that last 15-20 minutes....drives me crazy. Jeff
  17. Do what I did.......see sig line :D Jeff
  18. when Pat and I SOA'd my MJ, we set the new perches parallel to the factory ones....that keeps the same pinion angle relative to the TC output. Lookin' good bigD :cheers: Jeff
  19. Pat, Just stumbled across this....it ought to help you. It only lists collapsed lengths, but it's better than guessing. Check the second page for XJ/ZJ driveshaft lengths: http://www.crownautomotive.net/catalog/ ... afts1.html Jeff
  20. I booty-fabbed mine......stuck a small piece of 2X4 in the bottom of the door that keeps the window from rolling the whole way down. It stops it right as the top of the glass is level with the window felts :D Jeff
  21. it was snapped off inside the head.....neither of us noticed it when I picked it up :oops: No worries, I'll just add a head gasket and VC gasket to the parts list.... Jeff
  22. I just put new freeze plugs in a 4.0 block that I'm rebuilding. There were chunks of crud inside the block between the middle cylinder walls (between #3 and 4 especially) that I guarantee would never come out with a regular flush. I ended up loosening them up with a screwdriver and sucking them out with a small shopvac..... not suggesting you pull all the freezeplugs to flush the block, but that would be the most effective way (although probably the most pain in the #&$#^ way) ;) Jeff
  23. brigarpeon, the 2WD beam axle is exactly the same as the 4WD version, less the gears and axleshafts, and the outer C's have spindles bolted to them instead of unit bearings. Brake rotors on the 2WD incorporate the inner/outer wheel bearings. All of the bolt points (control arms, trackbar, sway bar links, shocks, coil buckets, drag link/tie rod) are the same. It's a 100% "take the 2WD axle out and bolt the 4WD one in" deal for a 4WD conversion. Jeff
  24. Negative……broke one punch and bent another one. I’m probably gonna pull the head and let my neighbor take it into work. His shop can drill the rest of it out and retap the hole Image Not Found Did manage to replace all the freeze plugs, though. It wasn’t a totally wasted day :D Image Not Found
