8
Everything posted by mjeff87
carrying a spare D44 shaft question
mjeff87 replied to mjeff87's topic in MJ Tech: Modification and Repairs
cool, so no issues with the spider gear walking or cross pin then? I'm carrying too much stuff as it is now, trying to lighten up some ;) Jeff -
If I wanted to carry only one spare D44 (rear) shaft, would a short-side shaft work on the long side for a trail repair? Or would you have to carry one of each size? Jeff
Rear Main Seal Repair gone bad
mjeff87 replied to robfg67's topic in MJ Tech: Modification and Repairs
funny you mention that location Rob.....I noticed on my 4.0 block when I took my starter out last week to drop the tranny that there is a machined hole on the "ear" of the block casting, directly above the starter. I never noticed it when I was rebuilding the engine, but saw it when I was underneath. It's about 3/4" in diameter, and I stuck my finger in it and it seemed to be open to the bottom end of the engine, but couldn't say for sure. If you drop a new seal in and pull your starter, do me a favor and check to see if you have the same hole as mine......I'm dying to know what it's for. Doesn't seem to make much sense to have an opening like that directly to the engine. Maybe oil is coming from there, if you have the same hole (???) Jeff -
fuel pressure on a 2.5 TBI? Did diagnostics today!
mjeff87 replied to mjtjnj's topic in MJ Tech: Modification and Repairs
MAT is on top of the manifold, behind the TB. CTS screws into the side of the manifold. Jeff -
swapping 4.0 into a 2.5 comanche
mjeff87 replied to 603Redneck's topic in MJ Tech: Modification and Repairs
That's step 1, the easy part: Image Not Found It's steps 2 thru 116,498 that are the biotch ;) Jeff -
Not a difficult swap, just a lot of work and a bit time consuming. Like Eagle said, all the 4.0 stuff is bolt-in, you just have to get the right parts. I used an ’89 MJ (automatic) underhood wiring harness and simply plugged it into the bulkhead connector for the stock interior harness (did A LOT of research and pinned out each circuit to make sure it would work). In addition to the harness, you’ll need: -4.0 ECU (grab this when you get the underhood harness) -4.0 frame horns (they bolt onto the framerails and the correct holes/studs are already there) -4.0 motor mounts (2.5 ones are smaller) -4.0 radiator and hoses (remove the 2.5 radiator brackets and the holes for the 4.0 rad are already there) -coolant resivoir or some sort if you run an open cooling system (I reused my 2.5 one with some modifications) -4.0 fuel pump (2.5 may be enough psi to start it, but won’t push enough volume) -4.0 transmission (AX15), new flywheel, clutch, pilot bearing and transfer case (23 spline) -new driveshafts, front and rear You’ll also have to splice the 4.0 fuel supply and return lines to the 2.5 lines….for whatever reason the 2.5 lines have a connector where the rubber lines meet the hard lines on the framerail, but the 4.0 lines don’t. I just disconnected the 2.5 lines at the connector and slipped the rubber fuel lines over the hard lines and double clamped them. I also reused the 2.5 MAP sensor and ICM, they are the same parts for both engines, interestingly. Jeff -
definately sounds like something is heat soaking, I agree (that's why I thought of a weak relay). Did you swap ICM's to see if that helped? Jerry (tjbliley) was having the same random problem with his 2.5 rig awhile back....we ended up troubleshooting it to find out that one of the wires going to the TB injector was loose and intermittently loosing contact. That was a fun one to figure out.
weak F/P relay, or loose wire maybe? Jeff
Had a little incident last weekend, the stupid little u-clip that holds the hydraulic line into the internal slave/throwout fell out and the line popped out, rendering my clutch useless (as I was driving down the road @ 45 mph). Got it back down to the garage, pulled the tranny back out and replaced the u-clips with cotter pins ;) Got the tranny/TC and crossmember back in last night after work and got the clutch bled again. Still have to put the starter back in, hook up the TC linkages and rehang the driveshafts, but it'll be back on the road again tonight (I hope) replaced the u-bolts with cotter pins, neither line will slip out again….. Image Not Found quick shot of the new clutch package while the tranny was out: Image Not Found
Driveshaft Part #52098169
mjeff87 replied to Catatonic Comanche's topic in MJ Tech: Modification and Repairs
Had to have a shaft cut for my MJ to about 42.5", running an AX15 with D44 (SOA). The longest XJ shaft I found in the 'yard was 40" (AW4, D35). Jeff -
@#%&#! internal slaves......
well, I drug the MJ back to the storage facility on Sunday and went down yesterday and dropped the tranny. Slave is fine......but the BS little U-clip that holds the input line into it slipped out and the line popped out of the cylinder :oops: . Replaced both clips with cotter pins. I'll put it all back together tomorrow, if I get a chance. I might take a sick day from work, 'cause I have to be out of the place by the end of the month or else I have to fork over another rental payment. Jeff -
I've got a gray one you can have if you want it..... Jeff
Cleaning out the storage facility today, running parts/tools back up to my house....unloaded and was heading back down, lost clutch. Limped it home in 4th (luckily not alot of traffic out today) and parked it beside the house. BRAND NEW internal slave, blown :headpop: Anyone got an AX15 external slave setup for sale? I have the BH, need all the rest, quick..... Jeff
^^^^^^^^^^^ Gaaaahhhh!! my eyes!!!! I've been blinded!!!! ;) Wish I had a pic of mine when I first got it back in ’99, but digital cameras weren’t even invented back then :D It truly was an “old man’s” truck (and I bought it from him, sort of....he passed away and I bought it from his wife). Here’s a comparison of right after I converted it to 4WD and brought it back down to VA, to where it sits now. Lotsa stuff has changed….. Back then: Image Not Found Image Not Found Now :brows: Image Not Found Image Not Found
you won't need the bulkhead engine-side, but you'll have to pull the entire interior wiring harness because it is all hard wired to the fuseblock (woulda been nice if they would have used pigtails out of the box to some connectors but they didn't). I've got an '89 MJ interior harness that I ended up not needing for my project......I'll let it go to you for cheap if you can't find one down your way. Jeff
cam position sensor is in the dizzy, the connector for it is in the secondary harness that goes to the alternator and starter, over by the relay center. If that's an HO harness, the CPS connector is round like your third pic. The renix CPS is flat (looks like the MAP connector). Look at your CPS and see what shape your is. Jeff
What's the Canuck Conferedate flag look like? :D Same as ours except it has a moose on it drinking a beer and playing hockey..... ;)
Converting an Auto to Manual?
mjeff87 replied to 702_MJ's topic in MJ Tech: Modification and Repairs
yes, it's slightly different. I found this out the hard way recently when I swapped an AX15 into my rig......dimensionally they are identical, but in the center of it where the tranny mount bolts the AX15 crossmember is dished out by about 1". I tried using my original AX5 mount, which is the same part # as the AW4 and BA10/5 mount that wasn't dished out and the AX15 sat 1" too high. Couldn't get the TC linkage to hook up, and my cat converter was hitting the floorboard. See the bottom of page 4 of my build thread for a pic of what I'm talking about: http://comancheclub.com/forums/viewtopic.php?t=11205 Your swap worked fine, but you could probably swap the AX15 crossmember you have with an AW4/AX5/BA10/5 one and raise your tranny up a tad in the rear. But if it's all working good, I'd leave well enough alone ;) -
you can use an auto TB with a manual, just leave the second pigtail on the TPS disconnected ;) Jeff -
I'm thinking the rings need to reseat is all, like you said. Been driving it around locally and it looks as though it's starting to tighten up a bit already. Not sure if I want to go to 35's or not. I really dig the power in 1st gear with the 33's, especially in 4LO :D I was pretty twisted up when the TC jammed, had my right side in a 3 ft trench....I'm guessing the craptastic factory linkage wasn't very happy when I tried to shift it......
got it all put back together and took it on a maiden voyage Saturday night, good highway trip with some minor wheeling to a spot in the woods to watch a CJ get very stuck. Got a few minor issues......fuel pump sending unit is leaking (the o-ring slipped on install), transfer case got stuck in 4HI for a bit then popped out quite unexpectedly (lotsa scary noises there :roll: ), and I have a moderate case of blowby to diagnose. It didn't help that I forgot to connect the air tube to the airbox securely, which came loose and dumped gobs of oil all over the frame/steering box. Other than that, which I'll fix this weekend, it runs and drives great. I could very easily run 35's if I wanted/needed to. On the highway @ 65 I was taching around 2600 rpm in 5th. Gonna do an oil change this weekend, going with 10W40 (oil pressure dropped but remained steady at 25-30 psi) and add a can of Restore. Jeff
yup, keeping my original 87 assembly as a spare.....the 91 unit I pulled is alot less coroded. Jeff
probably not, but I'm not using it as a sealer in this case. The tubes are in good shape and not cracked/leaking, I just added the JB to add some rigidity to them, so that they don't end up cracking down the road.
Forgot to post this earlier……pic of the difference between the 2.5 and the 4.0fuel pumps (2.5 one is the smaller one on the bottom). I was going to try and see if the 2.5 pump would have enough psi to fire but went ahead and swapped everything out beforehand. I wasn’t sure it was going to start to begin with, and didn’t want to add a variable to the equation if I had to troubleshoot. differences: Image Not Found because MJ fuel pump assemblies have a tendency to crack where the metal lines pass through the mounting plate, and they are universally unavailable anymore, I decided to add a bit of JB weld to the lines on the new assembly before putting it in as a safety measure: Image Not Found
