I just got my new TPS today, and I got all the volts right and how its about 3 thousand rpm and will not go down at all. when I unplug the TPS the rpm drop to normal then when I plug it back in the rps go to a thousand and it stays there...
I need to know how to a just a new TPS, Mine has 3 wires the top wire is yellow and the middle is black or brown and the bottom is blue with a white strip. I know I need to get 0.5 volts and 4.8 or close to that at wide open throttle..Can any one help!!!
This subject is old, but I was wondering if a 96 Grand Cherokee booster will work on a Comanche, and were do I get the aluminum spacer at thanks. There is a guy that is parting out 96 Grand so I can get all I need to do the swap..
The fan switch does nothing at all, I jumped the blower to the battery and it came on, a friend said it is ether fan resister or the fan switch, the fuse is good, its become a pain in the @$$
I was wondering if a 95 Cherokee auto trans will work in a 87 Comanche with a manual trans, and is 200$ a good price for trans, transfer-case, shifter, let me know if I need any thing else.
