Gjeep
3
Everything posted by Gjeep
Plugging along finishing lots of details to the MJ's underside...Drilled a 1 3/8" access hole on either side of the frame so I can put a nut on all the bolts for the sway bar end link mounting bracket. Took my time measuring and all came out well. Once the brackets are mounted/ nuts in place I'll use these 'caplugs' to fill the holes. Mounted all hardware since chassis paint -- front and rear shocks, attached brake lines, bled system, etc.
55002368 Know that what Team Cherokee sells as this is not correct. Don't think this part is available any more, so wrecking yards it is.
Looks good, but FYI it looks like a repaint area. That's why the difference. You also can see it it the photo you posted. topside above bodyline is original paint. Below is repaint area.
Looks good...I’m running those on my 2001 xj, but know those are 96-98 grand Cherokee zj rims. Tj rims are 15x8 and the slot is more of an angular cut-out.
Exactly. These amps need just under an inch breathing space all around to keep cool. Kick panel isn’t a fully enclosed area fortunately. Should be a-ok.
Thanks...I do what I can to make those sound system additions visually subtle. I want my enclosure set up to appear 'factory' Comanche somehow. Finally got the fuel, brake and breather lines in place. Came out nice and clean. I know most people do'n't notice chassis side, but I do. Nuts I know. And axle brake line attached.
Chipping away and changing a few things as I go...Since I'm going to be running subs behind the seats now, I needed to go in yet again to the PDC and modify things so I could get 60W fused power to run the Rockford amplifier that will power these. With that, I need to bump the IPF relay harness power to just outside the PDC -- about where the cruise control servo cable attaches to the PDC/overflow reservoir bracket -- in a weatherproof fuse holder. Diagram and photo below. The Mega fuse holder for the 270A alternator now resides in front of the coolant jug for easy access (use to be in the mounting area of the DirtBound battery tray -- a nightmare to access). I also added a hose off the overflow so if coolant does flow out, it won't wet/damage any of the electric. With those changes engine-side, I was able to run the wiring inside and install the subwoofer amp opposite the main 4-speaker amplifier -- on the passenger side footwell panel. I needed to move around the power window relays and connector that powers the harness for the inner door passenger side to makes things work, and make sure the amp has enough breathing room. Eventually all loose wires will be organized here too...
Also been freshening the fuel tank with new hoses, clamps, and roll-over safety valves. I was surprised to find both the seals on mine were cracked. Chances of fuel actually leaking out of these are slim, but while they are sill available from dealers I'm replacing both the seal and valve of both.
My 6.5" Rockford woofers came today...they're about 2.5" deep and heavy as the 8" sub going in my '97 XJ. Looks like I'm going to need to rethink my subwoofer area. Either going to build a MJ specific fit-to-the-backwall enclosure and/or adapt the first gen XJ separate sound bar to hold those speakers, as that sound bar is plenty deep (unlike the '99+ XJ integrated sound bar). A little project to get to.
Broken leaf spring...Standard longbed 4.0 1987
Gjeep replied to DC3's topic in MJ Tech: Modification and Repairs
For what it's worth, my '89 MJ has NOS metric ton leafs installed and my '92 MJ new General Spring metric ton leafs... same amount of lift on each 3.5". -
It depends what kind of condition your current sockets are in...AC Delco# LS7 if you need the entire socket and it's about $25 per socket. Gray in color like OEM. https://www.carid.com/acdelco/gm-original-equipment-side-marker-lamp-socket-mpn-ls7.html?view=236082&gclid=EAIaIQobChMI0NeB8vup6QIVTOztCh3c8g5jEAQYAiABEgIV3fD_BwE Or if you just need the backing, the less expensive way to go is through Wiring Depot. Their socket# 2583F is cream/ yellow color, but only $7 per socket. https://www.wiringdepot.com/store/p/494-JT-T-2583F-3-Wire-GM-Chrysler-AMC-90-Double-Contact-Back-Up-Stop-Tail-Turn-Light-Socket-Pigtail-1977-Newer-1-Pc.aspx Removing the terminals of your current MJ sockets are easy to remove and pop into a new connector.
Project CRD MJ is born:
Gjeep replied to Sir Sam's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Nice attention to detail on in the engine bay/ chassis. Looking good. -
Cleaning crud today -- Tail light sockets are always a mess on MJ's. Disassembling and cleaning them out. The terminals come out easy enough. The clear back side I'm just going to replace versus cleaning... Fill it back up with dielectric grease and replace wire loom with a new. Also, for those who haven't noticed, the turn signal socket gaskets all around on the '97+ XJ are worth swapping over to your MJ. They're a high quality gasket, unlike the foam gasket MJ's and early XJ's.
Front fender wells are painted. Currently drying so loose parts and missing shocks. General clean up to do, but the chassis paint is done. The bump stop tower will be body color.
More detail work...Since I removed my axle load sensing valve a while back (because I'm running an XJ brake proportioning valve and have a camper shell with additional weight on the bed) my MJ second chassis brake line was deleted -- so I can run one less channel brake line clips all the way back. Since the XJ/ MJ clips are no longer available, the closest option for a 4-channel frame rail clip is off the Liberty. Only difference is, the newer (OBD2) vehicles don't have 2 fuel lines coming from the tank, so one of the slots needed to be enlarged for my other chassis fuel line (at right in photo). Also, cleaned and painted the bracket for the rear brake line support at the 'X' member under the bed. A new drivers side brake line has been bent for 'T' split on the rear axle so to not get in the way of the sway bar. Currently degreasing the front fender openings so I can spray it satin black as the rest of the 'frame'...
Nope -- GooGone Pro Power soak, terry cloth towel scrub/ wipe, then red scuff pad soaked with GooGone Overspray Remover, wiper down, hit with brake cleaner, GooGone ProP Power spray and brush with small soft steel brush, towel wipe down...repeat I don't know how many times until clean. And then cleaned again one last time to be sure.
Finally finished detailing all the fuel and brake lines on the truck. The coiled armored ones were the biggest pain, but look the best when clean. As I'm seeing this MJ come together, I'm thinking about a non-metallic silver. Either the factory 1992 Jeep Silver Star color minus the metallic flake...or the newer Toyota Cement color. I've seen both in person and they are surprisingly close to the same color. For the sake of this forum, I grabbed to similarly lit photos of the 2 colors. Will see.
Since I got good at cleaning off excess undercoating this week -- I decided to clean up the fuel, brake, and breather line running down the frame of the MJ. I've got about 75% sparkling...just the bed length of the coiled brake line to go. As you can imagine, cleaning 250K worth of road grime off this particular line is a good time with liberal use of a stainless steel hand brush. A bit nuts, but with the chassis looking good, I know I'd regret not putting this detail time in. And yes, a new inline fuel filter and hoses will be installed. The frame bracket for the filter is being detailed and painted a cast silver.
Clean '91 MJ AW4 2WD 122K
Gjeep posted a topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
If I didn't think my wife would leave me, I'd buy this... https://sfbay.craigslist.org/sby/cto/d/san-jose-1991-jeep-comanche/7117300131.html -
Good eyes...that’s just a rough mock up of how it will be set up. There will be 2” between the bar and axle.
