NHMJXJ
    5
Everything posted by NHMJXJ
  1. Another comprehensive list brought to you by Bonkers! Thank you!
  2. I have, actually. https://comancheclub.com/topic/57071-mysterious-clunk-please-help/?tab=comments#comment-585215 I ran them for a little over a year. Made my daily driver a miserable experience.
  3. They're no good if you're expecting a quiet, quality ride on the street. However, they are apparently great for flex off road.
  4. Photo credit -Unknown-
  5. You, gentlemen, have excellent taste in motor vehicles. I wasn't fishing for compliments, but I appreciate the nod, thanks. I posted the pic to illustrate SmokeyYank's statement about prep. Mine was not an expensive paint job. The outcome was the result of quality prep.
  6. Heat will remove the decals (even with paint over them, provided the PO didn't use rhinoliner). Then there's the 30 year old adhesive. I'm no chemical engineer, but I can tell you the adhesive definitely changes the paint under it. When I had my truck repainted the guy stripped the decals and prepped those areas before shooting the primer. '88 Pioneer decals removed, you can see that where they were, required special prep as well as more sanding.
  7. I thought that two door was an RC car until I saw the last angle. Sweet.
  8. Oh Lord ... Foodies.
  9. Trolling for a whale. $13K ask. Approach with caution. Seller uses the word "original" and the phrase "rust free". And don't forget the 4.0 V6? Really? https://www.ebay.com/itm/1989-Jeep-Comanche-Pioneer/113772207489?hash=item1a7d5a1d81:g:au0AAOSw5wVc9wWS
  10. Seller cheaped out when they posted pics, but it looks nice. Currently $5500 (reserve not met). https://www.ebay.com/itm/223541322218?fbclid=IwAR2BJ8CkdHTiXWNi7p_2wcdHpwRHxyVZWJWkJOvhtykMly7syJwHYOKN8GQ
  11. I would address the surface rust forthwith! You can never do that too soon. As to the clear, there's nothing you can do about it. If the paint is checked/cracked your prep for paint will cost you as much as the paint itself.
  12. Technology is not (always) your friend. I choose to drive older vehicles. Traction control can get you killed and proximity sensors are equally dangerous.
  13. Yeah, the bed cap didn't improve the line much either.
  14. I have no doubt the cap is OEM, but that hole is sketchy. More to your question … I've never seen an opening in that position in any XJ console. Never saw window controls in the console except in later model Jeeps, like the Liberty.
  15. Mmm yeah, someone sprayed that cap and stuffed it in the hole that was cut.
  16. That thing can't move in anything other than a straight line (if at all) when slammed. Air or hydraulics will lift to clear turning the wheels. I bet it drives (like crap), but I wouldn't take it far from the garage.
  17. Merge. Like a zipper.
  18. Do not roll into the middle of traffic controlled intersection unless you can completely clear it before the opposing light turns green. Otherwise, you should hate yourself because you are now an inconsiderate a-hole.
  19. Keep right, except to pass. < --- Passing lane ... Travel lane ---- > Or, as I once read on a bumper sticker on a semi < --- Passing side ... Suicide --- >
  20. It looks like this guy used pre-97 XJ rear bumper ends on his 98 XJ. Perhaps you could make the same "work" with some finagling? You have to eliminate the 97+ bumper ends when you put after market flares on. I think it cleaned up the rear end nicely.
  21. Budget is everything. "Kits" generally aren't complete. Component sourcing is the best. Where are you and what is your access to internet, shops, fabricators?
