rocklaser
    Glens Falls NY
940 profile views
rocklaser's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. Looking for one in decent shape
  2. anybody recommend a good way to bypass one of the fuses in my fuse block. The fuse controls the parking lights, dash and license lights. I cannot break loose the screws on the block to pull out the block. every time I pull out the light switch it blows the fuse. any help greatly appreciated.
  3. anybody have the small trim piece that goes above the side marker and mount to the header panel? need both sides. for 87 sport truck
  4. Anyone know if you can use the end caps from a xj on the comanche? also looking to replace the license plate light bezel
  5. Anybody have a recommendation for a clutch kit? Going in a 1987 4.0 4wd Comanche Sport Truck
  6. rocklaser
    mj doors
    Got it Thanks
  7. did you ever find the keys to the doors?
  8. rocklaser
    mj doors
  9. rocklaser
    mj doors
    looking for both doors any year that fits. If new latch is required (newer XJ door) need those as well. need to be clean and functioning roll up windows. Be willing to ship to upstate NY 12804
  10. rocklaser
    tailgate
    12804 upstate NY
  11. rocklaser
    tailgate
    Need a reasonably good shape tailgate
  12. I was able to pull the inside weather stripping on the passenger window and with a very long and narrow flat tip screwdriver trip the locking mechanism inside the door. I also first soaked the hell out of it with PB blaster
  13. got the door open, appreciate all the feedback
  14. The rocker button does not move either to the lock or unlock position. I tried to jimmy the door with a coat hanger and that didn't work either. I have tried to remove the interior door handle but it has a clip that I cannot see. I have tried to get the interior panel off but with the limited work space I probably would damage it .
  15. the rocker button on the door will not function, key in cylinder turns freely and outside door hand button pushes in easily. tried to get inside panel off but because the door won't open I am having trouble accessing the locking clips. any suggestions
