Everything posted by Mountain Dude
I have one of those razor grilles attached to a '73 J-4000 truck. I plan to or try to shorten the grille to make it fit the front of the Comanche...maybe I will add a fake brow to the roof too.
Last fall I bought my first Comanche Image Not Found 1986 LWB 2WD, 2.5L AX-5 Today I picked up # 2 Image Not Found 1988 SWB 2WD, 4.0 BA10/5 Image Not Found With a cool (Pun intended) hood Image Not Found And Number 3 Image Not Found Image Not Found 1991 SWB 2WD 4.0 AX-15 Was damaged in the front frame area around the steering box mounts. The red / yellow one is partly converted to 4WD, front axle is in and I have the matching XJ D44 to modify and put in the back. AX-15 / NP231 combo is sitting under a 1991 donor XJ in the yard too. It is a little rusty, OK a lot rusty, so the blue truck will be donating some parts to it as well as a few parts to complete Comanche #1
Back when I worked on airplanes, my old boss was searching the hangar one moning looking for the portable phone. Could not find it anywhere. He ended up calling the guy whose airplane HE had worked on the day before. They found the phone sitting nicely on the engine baffle inside the cowling undamaged! When He got it back, he passed a rule that WE were not supposed to answer the phone out in the hangar when working on the planes.
Ya, try pulling the lever a little farther past the detent for 4 hi towards but not all the way towards neutral. This will conform that the linkage is mis-rigged.
I used a pair of S-10 Blazer / S-15 Jimmy rear cargo area lights to replace my dome lights, They work off the doors, the headlight switch and can be turned on manually, they just don't have a setting to keep them from coming on like the OEM ones. They fit in the stock holes. Image Not Found
Rear Brakes-Main Hardline Broken Above Gas Tank
Mountain Dude replied to JWARNE's topic in MJ Tech: Modification and Repairs
I had the same problem...blew 1 brake line next to the fuel tank. Fixed it by doing the load sensing valve bypass and using the other brake line which, fortunately was not rusted out. -
Congrats man, landing that first job after school is a big milestone! My daughter used to live in Oliver, hope you like the heat!
I'm sure that most of you have seen this one: Funny Taser story Last weekend I saw something at Larry's Pistol and Pawn Shop that sparked my interest. The occasion was our 22nd anniversary and I was looking for a little something extra for my wife, Toni. What I came across was a 100,000 volt, pocket/purse-sized taser. The effects of the taser were suppose to be short lived, with no long-term adverse affect on your assailant, allowing her adequate time to retreat to safety . WAY TOO COOL! Long story short, I bought the device and brought it home. I loaded two triple-A batteries in the darn thing and pushed the button. Nothing! I was disappointed. I learned, however, that if I pushed the button AND pressed it against a metal surface at the same time, I'd get a blue arch of electricity darting back and forth between the prongs. Awesome!!! Unfortunately, I have yet to explain to Toni what that burn spot is on the face of her microwave. Okay, so I was home alone with this new toy, thinking to myself that it couldn't be all that bad with only two triple-A batteries...... Right? There I sat in my recliner, my cat Gracie looking on intently (trusting little soul) while I was reading the directions and thinking that I really needed to try this thing out on a flesh and blood moving target. I must admit I thought about zapping Gracie (for a fraction of a second) and thought better of it. She is such a sweet cat. But, if I was going to give this thing to my wife to protect herself against a mugger, I did want some assurance that it would work as advertised. Am I wrong? So, there I sat in a pair of shorts and a tank top with my reading glasses perched delicately on the bridge of my nose, directions in one hand, taser in another. The directions said that a one-second burst would shock and disorient your assailant; a two-second burst was supposed to cause muscle spasms and a major loss of bodily control; a three-second burst would purportedly make your assailant flop on the ground like a fish out of water. Any burst longer than three seconds would be wasting the batteries. All the while I'm looking at this little device measuring about 5" long, less than ¾ inch in circumference; pretty cute really (and loaded with two itsy, bitsy triple-A batteries) thinking to myself , "no possible way!" What happened next is almost beyond description, but I'll do my best..... I'm sitting there alone, Gracie looking on with her head cocked to one side as if to say "don't do it master," reasoning that a one-second burst from such a tiny little old thing couldn't hurt all that bad.....I decided to give myself a one-second burst just for the heck of it. I touched the prongs to my naked thigh, pushed the button, and HOLY MOTHER, WEAPONS OF MASS DESTRUCTION!! I'm pretty sure Jessie Ventura ran in through the side door, picked me up in the recliner, then body slammed us both on the carpet, over and over and over again. I vaguely recall waking up on my side in the fetal position, with tears in my eyes, body soaking wet, both nipples on fire, testicles nowhere to be found, with my left arm tucked under my body in the oddest position, and tingling in my legs. The cat was standing over me making meowing sounds I had never heard before, licking my face, undoubtedly thinking to herself, "do it again, do it again!" Note: if you ever feel compelled to "mug" yourself with a taser, one note of caution: there is no such thing as a one-second burst when you zap yourself. You will not let go of that thing until it is dislodged from your hand by a violent thrashing about on the floor. A three-second burst would be considered conservative. SON-OF-A-*&^%$.....that hurt like hell!!! A minute or so later (I can't be sure, as time was a relative thing at that point), I collected my wits (what little I had left), sat up and surveyed the landscape. My bent reading glasses were on the mantel of the fireplace. How did they get there??? My triceps, right thigh and both nipples were still twitching. My face felt like it had been shot up with Novocain, and my bottom lip weighed 88 lbs. I'm still looking for my testicles. I'm offering a significant reward for their safe return. Still in shock, Tommy
You're welcome!
Here's another one for ya: Thought y'all should read this in case you're thinking of installing an electric fence! We have the standard 6ft. Fence in the backyard, and a few months ago, I heard about burglaries increasing dramatically in the entire city. To make sure this never happened to me, I got an electric fence and ran a single wire along the top of the fence. Actually, I got the biggest cattle charger Tractor Supply had, made for 26 miles of fence. I then used an 8 ft. Long ground round, drove 7.5 feet into the ground. The ground rod is the key, with the more you have in the ground, the better the fence works. One day I'm mowing the back yard with my cheapo Wal-Mart 6hp bigwheel pushmower. The hot wire is broken and laying out in the yard. I knew for a fact that I unplugged the charger. I pushed the mower around the wire and reached down to grab it, to throw it out of the way. It seems as though I hadn't remembered to unplug it after all. Now I'm standing there, I've got the running lawnmower in my right hand and the 1.7 gigavolt fence wire in the other hand. Keep in mind the charger is about the size of a marine battery and has a picture of an upside down cow on fire on the cover. Time stood still. The first thing I notice is my balls trying to climb up the front side of my body. My ears curled downwards and I could feel the lawnmower ignition firing in the backside of my brain. Every time that Briggs & Stratton rolled over, I could feel the spark in my head. I was literally at one with the engine. It seems as though the fence charger and the POS lawnmower were fighting over who would control my electrical impulses. Science says you cannot poop and pee at the same time.. I beg to differ. Not only did I do all at once, but my bowels emptied 3 different times in less than half of a second. It was a Matrix kind of bowel movement, where time is creeping along and you're all leaned back. It seemed like there were minutes in between but in reality it was so close together it was like exhaust pulses from a big block Chevy turning 8 grand. At this point I'm about 30 minutes (maybe 2 seconds) into holding onto the fence wire. My hand is wrapped around the wire palm down so I can't let go. I grew up on a farm so I know all about electric fences... But Dad always had those POS chargers made by International or whoever that were like 9 volts and just kinda tickled. This I could not let go of. The 8 foot long ground rod is now accepting signals from me through the permadamp Ark-La-Tex river bottom soil. At this point I'm thinking I'm going to have to just man up and take it, until the lawnmower runs out of gas. 'Damn!,' I think, as I remember I just filled the tank! Now the lawnmower is starting to run rough. It has settled into a loping run pattern as if it had some kind of big lawnmower race cam in it. Covered in poop & pee, and with my balls on my chest I think 'Oh God please die... Pleeeeze die'. But nooooo, it settles into the rough lumpy cam idle nicely and remains there, like a big bore roller cam EFI motor waiting for the go command from its owner's right foot. So here I am in the middle of July, 104 degrees, 80% humidity, standing in my own backyard, begging God to kill me. God did not take me that day... He left me there covered in my own fluids to writhe in the misery my own stupidity had created. I honestly don't know how I got loose from the wire... I woke up laying on the ground hours later. The lawnmower was beside me, out of gas. It was later on in the day and I was sunburned. There were two large dead grass spots where I had been standing, and then another long skinny dead spot were the wire had layed while I was on the ground still holding on to it. I assume I finally had a seizure and in the resulting thrashing had somehow let go of the wire. Upon waking from my electrically induced sleep I realized a few things. 1- Three of my teeth seem to have melted. 2- I now have cramps in the bottoms of my feet and my right butt cheek (not the left, just the right). 3- Poop & pee when mixed together, do not smell as bad as you might think. 4- My left eye will not open. 5- My right eye will not close. 6- The lawnmower runs like a spotted ape now. Seriously! I think our little session cleared out some carbon fouling or something, because it was better than new after that. 7- My balls are still smaller than average yet they are almost a foot long 8- I can turn on the TV in the gameroom by farting while thinking of the number 4 (still don't understand this?) That day changed my life. I now have a newfound respect for things. I appreciate the little things more, and now I always triple check to make sure the fence is unplugged before I mow. The good news, is that if a burglar does try to come over the fence, I can clearly visualize what my security system will do to him, and THAT gives me a warm and fuzzy feeling all over, which also reminds me to triple check before I mow.
1.199, I wish...its 1.329 / L here - 5.03 / US gal :fs1:
the 231C case has a 5 bolt mounting flange verses the Jeep 6 bolt one. Swapping internals is relatively easy and straight forward. If you are halfway mechanically inclined, you can probably do it...if you are unsure, there is probably another Comanche Club member near you who would be willing to help or provide guidance while you tackle the job.
The one I used from an 89 S-10 did http://comancheclub.com/topic/35760-np231j-t-case-upgrade/
Well, if its on the rear, look for a 231C out of a late 80's early 90's S-10 / S15. The rear case halves are identical and you will also get the 6 gear planetary reduction and wider front drive chain as a bonus. I posted a description for the swap in the DIY forum.
is it the front half or the rear half (or both) that is cracked?
Funniest Dam Story This is an actual letter sent to a man named Ryan DeVries by the Pennsylvania Department of Environmental Quality, State of Pennsylvania. This guy's response is hilarious, but read the State's letter before you get to the response letter. ------------------ SUBJECT: DEQ File No.97-59-0023; T11N; R10W, Sec. 20; Lycoming County Dear Mr. DeVries: It has come to the attention of the Department of Environmental Quality that there has been recent unauthorized activity on the above referenced parcel of property. You have been certified as the legal landowner and/or contractor who did the following unauthorized activity: Construction and maintenance of two wood debris dams across the outlet stream of Spring Pond. A permit must be issued prior to the start of this type of activity. A review of the Department's files shows that no permits have been issued. Therefore, the Department has determined that this activity is in violation of Part 301, Inland Lakes and Streams, of the Natural Resource and Environmental Protection Act, Act 451 of the Public Acts of 1994, being sections 324.30101 to 324.30113 of the Pennsylvania Compiled Laws, annotated. The Department has been informed that one or both of the dams partially failed during a recent rain event, causing debris and flooding at downstream locations. We find that dams of this nature are inherently hazardous and cannot be permitted. The Department therefore orders you to cease and desist all activities at this location, and to restore the stream to a free-flow condition by removing all wood and brush forming the dams from the stream channel. All restoration work shall be completed no later than January 31, 2006. Please notify this office when the restoration has been completed so that a follow-up site inspection may be scheduled by our staff.? Failure to comply with this request or any further unauthorized activity on the site may result in this case being referred for elevated enforcement action.. We anticipate and would appreciate your full cooperation in this matter. Please feel free to contact me at this office if you have any questions. Sincerely, David L. Price District Representative and Water Management Division. ------------------ Here is the actual response sent back by Mr. DeVries:------------------ Re: DEQ File No. 97-59-0023; T11N; R10W, Sec. 20; Lycoming County Dear Mr. Price, Your certified letter dated 12/17/02 has been handed to me to respond to. I am the legal landowner but not the Contractor at 2088 Dagget Lane, Trout Run, Pennsylvania. A couple of beavers are in the (State unauthorized) process of constructing and maintaining two wood "debris" dams across the outlet stream of my Spring Pond. While I did not pay for, authorize, nor supervise their dam project, I think they would be highly offended that you call their skillful use of natures building materials "debris." I would like to challenge your department to attempt to emulate their dam project any time and/or any place you choose. I believe I can safely state there is no way you could ever match their dam skills, their dam resourcefulness, their dam ingenuity, their dam persistence, their dam determination and/or their dam work ethic. As to your request, I do not think the beavers are aware that they must first fill out a dam permit prior to the start of this type of dam activity. My first dam question to you is: (1) Are you trying to discriminate against my Spring Pond Beavers, or (2) do you require all beavers throughout this State to conform to said dam request? If you are not discriminating against these particular beavers, through the Freedom of Information Act, I request completed copies of all those other applicable beaver dam permits that have been issued. Perhaps we will see if there really is a dam violation of Part 301, Inland Lakes and Streams, of the Natural Resource and Environmental Protection Act, Act 451 of the Public Acts of 1994, being sections 324.30101 to 324.30113 of the Pennsylvania Compiled Laws, annotated. I have several concerns. My first concern is, aren't the beavers entitled to legal representation? The Spring Pond Beavers are financially destitute and are unable to pay for said representation -- so the State will have to provide them with a dam lawyer. The Department's dam concern that either one or both of the dams failed during a recent rain event, causing flooding, is proof that this is a natural occurrence, which the Department is required to protect. In other words, we should leave the Spring Pond Beavers alone rather than harassing them and calling their dam names. If you want the stream "restored" to a dam free-flow condition please contact the beavers -- but if you are going to arrest them, they obviously did not pay any attention to your dam letter, they being unable to read English.? In my humble opinion, the Spring Pond Beavers have a right to build their unauthorized dams as long as the sky is blue, the grass is green and water flows downstream. They have more dam rights than I do to live and enjoy Spring Pond. If the Department of Natural Resources and Environmental Protection lives up to its name, it should protect the natural resources (Beavers) and the environment (Beavers' Dams). So, as far as the beavers and I are concerned, this dam case can be referred for more elevated enforcement action right now. Why wait until 1/31/2006? The Spring Pond Beavers may be under the dam ice then and there will be no way for you or your dam staff to contact/harass them then.? In conclusion, I would like to bring to your attention to a real environmental quality, health, problem in the area. It is the bears! Bears are actually defecating in our woods. I definitely believe you should be persecuting the defecating bears and leave the beavers alone. If you are going to investigate the beaver dam, watch your step! The bears are not careful where they dump!? Being unable to comply with your dam request, and being unable to contact you on your dam answering machine, I am sending this response to your dam office. THANK YOU. RYAN DEVRIES & THE DAM BEAVERS
The oil pump on an NP231 is driven by the rear output shaft, so if the truck is moving oil is pumping, even with the t-case in neutral.
As I once heard that story, the guy called himself the DD - designated decoy!
So Apparently It's Spring In Other Parts Of The World...
Mountain Dude replied to gogmorgo's topic in The Pub
Gogmorgo, how much snow in your back yard? I have over 6 feet where I clear the path to my work shop. Three feet in the rest of the yard. -
Bud, if you happen to drive through Prince George, BC on your way to Yellowknife, drop me a PM...I would love to meet up and see the camper too.
It may sound silly, but are you sure its a roll pin? You don't specify which axle you are talking about. A D30 has a roll pin, Some D35s and D44's have a screw instead of a roll pin. Can you see through the centre of it? If not, maybe you have a screw type lock pin and the head is busted off. No amount of pounding is going to get that sucker out. You will need to drill it and use an easy out.
Black vertical stripe near the rear end.
Mnkyboys 89 Comanche project
Mountain Dude replied to mnkyboy's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Cool, I am doing the 4.3 swap in my '86 next summer, once the TJ is back on the road. I got hold of a complete 1994 S-10 Blazer for $300 which has a 200hp Vortec 4.3. I am keeping the 4L60E and will grab a NP231C from an 89 Jimmy also sitting in my back yard.- 798 replies
- 2.5l
- supercharged
- (and 7 more)
Did you get a TBI 4.3 or a Vortec CPI 4.3? What year is it from?- 798 replies
- 2.5l
- supercharged
- (and 7 more)
