Maveric Posted May 26, 2008 Share Posted May 26, 2008 how do you convert a closed radiator/cooling system from a 1988 comanche to an open system like my dads 91 cherokee? how hard is it? got to replace my radiator anyway its heating up but radiator is cold as ice, tried flushing and everything, nothing else is working, figured now would be a good time for a project of this kind, what parts will i need? how hard is it to do? please any info would be greatly appriciated, i need help guys! step by step instructions as I'm not familiar with the system. thanks in advance for all your help, lets keep one more comanche on the road y'all! Link to comment Share on other sites More sharing options...
BLHTAZ Posted May 26, 2008 Share Posted May 26, 2008 I have a couple ditfferent threads on here about the change. I will tell you that had I known what a PITA it was going to be, I would not have done it this way. Here is my thread about the biggest PITA of the change... the electric fan operation... http://comancheclub.com/forums/viewtopi ... conversion Here is my thread on the conversion itself... http://comancheclub.com/forums/viewtopi ... conversion Replace your radiator with the same style and then look here for a very detailed write-up about using a Moroso Expansion tank to achieve the same effect without all of the other issues I went through... http://www.markashurst.com/Jeeps/Moroso/ Link to comment Share on other sites More sharing options...
MiNi Beast Posted May 26, 2008 Share Posted May 26, 2008 Nice write up in the Do it your yourself forum... http://comancheclub.com/forums/viewtopic.php?t=7695 Link to comment Share on other sites More sharing options...
dakal Posted May 26, 2008 Share Posted May 26, 2008 i have a 88mj with the i6. when i did my conversion, there wasn't a electric fan. i'm still thinking about which way to convert it. one fan, two fans, with removing the mechanical fan and the extra pulley crap. the conversion from closed to open or open to closed wasn't hard. i bought a new 91+ radiator. i have the old top radiator hose. would like to shorten it. any ideas along with autozone part #? engine bay looks a lot better. worth the effort just for that. good luck Link to comment Share on other sites More sharing options...
BLHTAZ Posted May 26, 2008 Share Posted May 26, 2008 i have a 88mj with the i6. when i did my conversion, there wasn't a electric fan. :hmm: I have not seen one without and electric fan. Do you have AC...maybe the ones with no AC are without a fan?? Anyway...I know there are easy ways to make the fan work with a manual switch, but I wanted it to work the way it was designed so it was a real pain to figure out and definitley not worth the effort. Link to comment Share on other sites More sharing options...
maddzz1 Posted May 26, 2008 Share Posted May 26, 2008 i have a 88mj with the i6. when i did my conversion, there wasn't a electric fan. :hmm: I have not seen one without and electric fan. Do you have AC...maybe the ones with no AC are without a fan?? Anyway...I know there are easy ways to make the fan work with a manual switch, but I wanted it to work the way it was designed so it was a real pain to figure out and definitley not worth the effort. Taz, If you don't have AC there is no electric fan. I don't have AC and just have the mech fan Link to comment Share on other sites More sharing options...
Maveric Posted May 26, 2008 Author Share Posted May 26, 2008 part one 91 or newer radiator for open system, part two over flow bottle from a 91 or newer, i got an electric fan already do i need to mess with that? it never seems to come on, and i have no AC :dunno: do i need a new water pump? i think this one still works, just think my radiator is clogged up, so all in all 1) 91 open system radiator 2) 91 over flow bottle (have to move coil?? what coil?) what else? thanks for the help so far guys, i hope to get this fixed soon, i got to move my girl down here and thats a nice 500 mile round trip fully loaded 250 of it, and its mostly nothing between there and here, id hate to get stuck and its my only vehicle. Jeep on Y'all Link to comment Share on other sites More sharing options...
BLHTAZ Posted May 26, 2008 Share Posted May 26, 2008 A new water pump is not required, but mine had a very small drip coming out the bottom so I chose to do it at the same time. If you are going to go through with it, you will need... - '91 & up Radiator - '91 & up heater hoses - '91 & up heater control valve - Some kind of overflow bottle (I chose a generic one from the autoparts store) - Some hose to run to the overflow You could also do away with the heater control valve by going with the '97+ style heater hoses that run directly to the heater core. Link to comment Share on other sites More sharing options...
Maveric Posted May 26, 2008 Author Share Posted May 26, 2008 so a trip to the junk yard is in order? for the overflow bottle/heater hoses? and skip the heater control value? this is all quite new to me, this being my first car, so bare with me, so i need to do what? i guess i could get heater hoses from an auto parts store, and whats the coil that id have to move near the bottle for the 91+ overflow bottle to work? Link to comment Share on other sites More sharing options...
BLHTAZ Posted May 26, 2008 Share Posted May 26, 2008 The pic below kind of shows it all. There would normally be a heater control valve in the area of the yellow circle, but in this pic the heater hoses go directly to the heater core with no control valve as shown by the red circle. It also shows where the overflow bottlwe mounts, but on your Jeep there is some electrical stuff there, including the ignition coil, that would hve to be relocated. Mine has the same set up so I chose a generic bottle from Discount Auto Parts and mounted it on the firewall where the old pressure bottle used to be. This is a typical set up with a heater control valve... Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 26, 2008 Share Posted May 26, 2008 The pic below kind of shows it all. There would normally be a heater control valve in the area of the yellow circle, but in this pic the heater hoses go directly to the heater core with no control valve as shown by the red circle. It also shows where the overflow bottlwe mounts, but on your Jeep there is some electrical stuff there, including the ignition coil, that would hve to be relocated. Mine has the same set up so I chose a generic bottle from Discount Auto Parts and mounted it on the firewall where the old pressure bottle used to be. Hey! That's my picture you dolled all up! But it looks much better now. :cheers: As far as the fan controller, I decided to use the Spal variable speed unit for my 2nd (main) electric cooling fan. It runs the fan either at low or high speed depending on the LOW/HIGH temps you program in yourself. Sensing is accomplised either with the existing sensor in the stat head, or the temp gauge sensor. I used the temp gauge sensor and it really works well, exactly as advertised. Link to comment Share on other sites More sharing options...
87ComancheLB Posted May 27, 2008 Share Posted May 27, 2008 i have a 88mj with the i6. when i did my conversion, there wasn't a electric fan. :hmm: I have not seen one without and electric fan. Do you have AC...maybe the ones with no AC are without a fan?? Anyway...I know there are easy ways to make the fan work with a manual switch, but I wanted it to work the way it was designed so it was a real pain to figure out and definitley not worth the effort. Taz, If you don't have AC there is no electric fan. I don't have AC and just have the mech fan My 87 came with a electric fan, but no AC. Link to comment Share on other sites More sharing options...
BLHTAZ Posted May 27, 2008 Share Posted May 27, 2008 Hey! That's my picture you dolled all up!Yea...had to do a little search, but I knew it was here somewhere ;) :D . Link to comment Share on other sites More sharing options...
dakal Posted May 27, 2008 Share Posted May 27, 2008 mine has no ac. :USAflag: Link to comment Share on other sites More sharing options...
djag12 Posted May 29, 2008 Share Posted May 29, 2008 I have no AC and mechanical and electric fan. FYI Link to comment Share on other sites More sharing options...
Vandenborg1 Posted August 15, 2019 Share Posted August 15, 2019 Ok so I'm probably going to do thus conversion but on the radiators for the new models they all come with the transmission cooler in them do i need to cap them off with the manual or just leave them be? Link to comment Share on other sites More sharing options...
Eagle Posted August 15, 2019 Share Posted August 15, 2019 You could leave the tranny cooler outlets open, but that's an invitation for bugs to nest. Just plug them. Link to comment Share on other sites More sharing options...
Vandenborg1 Posted August 15, 2019 Share Posted August 15, 2019 Perfect thank you Link to comment Share on other sites More sharing options...
PIKE Posted August 15, 2019 Share Posted August 15, 2019 Mishimoto makes an aluminium radiator that has Provision for the older-style temperature switch and a filler neck with a pressure cap for open or closed cooling systems. https://www.mishimoto.com/jeep-cherokee-xj-aluminum-radiator-1989-2001.html The expansion bottle from a 2.5 works well. Bolts right in, the holes are there. If your radiator is good you can go with the Macs aluminum tank instead of the plastic one. It has a regular radiator cap to convert to open system. Very easy. Use the 2.5 expansion bottle with this too. Link to comment Share on other sites More sharing options...
omega_rugal Posted August 15, 2019 Share Posted August 15, 2019 wait, why do you want to switch to open system? do you have overheating problems? Link to comment Share on other sites More sharing options...
Vandenborg1 Posted August 15, 2019 Share Posted August 15, 2019 Yes I have overheating problems Link to comment Share on other sites More sharing options...
omega_rugal Posted August 15, 2019 Share Posted August 15, 2019 On 5/26/2008 at 1:57 PM, Maveric said: got to replace my radiator anyway its heating up but radiator is cold as ice, tried flushing and everything, nothing else is working mmm from what i understand, the engine is overheating but the radiator is cold, then you have a coolant flow problem, maybe the water pump is dead, have you check that? Link to comment Share on other sites More sharing options...
cruiser54 Posted August 16, 2019 Share Posted August 16, 2019 NR2802 from Napa will go right in and give you open cooling system. Link to comment Share on other sites More sharing options...
omega_rugal Posted August 16, 2019 Share Posted August 16, 2019 or get one of these put it in the upper radiator hose and don't kick yourself over the overflow bottle, it can be installed anywhere but the closest to the coolant cap the better, and any bottle does the job, mine has a pepsi cola bottle and i don´t bragg about it Link to comment Share on other sites More sharing options...
PCO6 Posted August 17, 2019 Share Posted August 17, 2019 Perhaps a dumb question but I'll ask it anyway. Apart from eliminating the heater control valve, what is the main reason for converting from a closed to open system? I have a '88 MJ and a '89 XJ, both with the original closed systems. I have no cooling issues with either. The XJ has AC (2 fans) and the MJ does not (1 fan). I've driven both all day long in hot weather at highway speeds and at times in stop and go traffic. I maintain both systems (coolant changes, flushing, hoses, belts, pumps, etc.) in stock form. The only thing I don't like is not being able to pressure test them. Both run a bit different. The MJ stays at 100* (212*) and doesn't move. I'll probably be adding a stock Jeep electric fan to this one. The XJ is always a bit below 100* but it fluctuates which I take as the electric fan kicking in or the thermostat (MOPAR) opening and closing. I tow a 1,600 or so pound tear drop trailer with the XJ and all is good. A lot of what I read says "do it" but I can't see making the change when all is good. Maybe I'm living on borrowed time and should move this up on the list of things to do. Link to comment Share on other sites More sharing options...
