Led lights
I've been happy with the Auxito brand led bulbs I've using in more modern cars (turns and brakes).    I get them off ebay.
you can ditch the sealed beams by upgrading to aftermarket housings that take replaceable H4 halogen bulbs. :L:  (I'm not a fan of LED headlights).
also get this so you can get a full 12v+ to your headlights:  https://www.ebay.com/itm/185254776653
  • 4 months later...
On my last MJ, I used sylvania 1157 led bulbs from oreilly’s in the stock housings. They were drop in replacements. As long as you have some incandescent bulbs in the turn signal circuit, it’s normally enough for the flasher to operate. Otherwise you may need to switch to an LED flasher if you experience rapid or no flash.
Would this harness be much benefit with stock (well stock spec-ed) headlights?
Do the Sylvania 1157 led bulbs work for the backup lights?  Did they make a noticeable difference in the backup light coverage/output?
this harness was made explicitly for helping the stock headlights give their full potential :L:  worth every penny!  (also prevents your headlight switch from catching fire!)
cannot remember the brand, but did use some LED bulbs for backup... or tried...
I had trouble with fitment in the socket,  seemed like the pins were too shallow to engage,  you just could not twist in the bulb to lock it...
the solder "point" on the end of the bulb seemed like the place to modify,
ruined one bulb trying that tactic...  :doh:
this was last fall,  just  cannot remember what I finally did...
I was also repairing the housing from a broken tab holding the clip nut on the tailgate side of the housing...
I made an entire metal clip to sandwich the plastic and allow the screw to bite...  so far so good on that....  was cheeper  than a housing!!!
some others applaud the illumination difference
22 hours ago, AnotherOldJeepGuy said:
Awesome, I will order it today!
@Pete M, if you get time would you snap a pic of where you mounted the relays and routed the cable?  Thanks in advance!
18 hours ago, pizzaman09 said:
These LED lights for the reverse lights are a phenomenal upgrade compared to stock. From my build thread: https://comancheclub.com/topic/68921-1990-comanche-eliminator/?do=findComment&comment=745859
Upgraded reverse lights with these light bulbs based on someone's recommendation on the forum.
Amazon Link
I'll see how the harness goes then move on to this!
My experience is that the harness will give about twice the light. Also, the H4 housings will give about twice the light (with out the harness). With an Autopal, Hella, Bosch and CIBIE, and harness, I'd say 4X. Daniel Stern use to sell the CIBIEs. He now sells a Japanese made ones. He rates them better.
I'll try, but the truck I installed them in isn't mine and lives about an hour away.  essentially the relays live over by the battery and the wire is run next to the factory harness.
For the B-pillar lights, I went with
Qasim 3000k 240 lumen festoon leds
They were the brightest easiest to acquire leds I could find in that color temp.
I simply just bent the metal loops back 90 degrees and they fit into the stock festoon holder.
I really hate the 5000k+ color temperature aftermarket LEDs. It looks like a blue-white to me.
The 2700-3000k color temperature more accurately represents the incandescent - halogen color temperature range and to me, and its easier on the eyes.
It's also more period correct hehehe :laugh:
Hanging around the Mercury Cougar forum, I stumbled upon Plasma LEDs that people swear by. I haven't put any in mine yet, but I know somebody that has installed PLEDs in the reverse lights on his XJ, and boy oh boy.
Also, Off-Grid Research offers an LED turn signal flasher relay. I have one in my MJ, works well.
If anyone that has this harness installed can post a few pics of the finished job that would be great.  I see I can squeeze the two relays in beside the battery and RF connection is just below that.  But I don't really see a great path over to the LF.  The harness seems to be long enough to get to the LF if it was straight across, but you can't go straight across unless I am missing something.
I removed the grill and ran along the bottom of the radiator with zip ties to hold in place.  I had to take off the LF head light cover and fish the wire behind the light bucket.
  • 4 weeks later...
Thought I'd post the status of this job I finally took on today.  I did remove the grill and light trim.  I have not put the bulbs in yet because of the light side story here, but for the benefit of others that might want to do this I snapped a few pics.  Do not start this if you are in a hurry, or if you don't like puzzles, cause routing the harness is a nontrivial task!  The routing opportunities are limited, and in some locations a tight squeeze.  But if you do go for it perhaps these pics will help.
Here is where I ended up mounting the relays and the initial route from there out to the light housings.
Here is the routing to the RF and across to the LF light housings, in front of the radiator as suggested by @87MJTIM.
Here is the final power connection.  I am not crazy with this end result, and I may revisit this, possibly adding a power block somewhere or maybe taping in someplace in the covered area just behind the battery
