llhat
llhat's Achievements
Comanche Aficionado
Comanche Aficionado (4/11)
  1. thank you my liner is solid up the sides, there are fairly large head screws that seem to retain the liner and the liner covers the rail. Installation based on you image would require large cuts in the liner for that type of clamp arrangement. response is appreciated.
  2. i have a ?? Pendaliner?? bed liner in my 1989, was in it when I purchased truck in 1997, the liner covers the top ledge of the bed sides.... would the cover you link and used fit? Installation is drilling the top ledge of the bed? think i have an aluminum top edge cover on my tailgate...
  3. pretty certain my 89 pioneer has a panel back there, not tilted the seat forward in a while ( bench seat)
  4. my 89 filter vertical, have always been able to use a regular strap wrench ( thin metal band) with a lever on it. you have to take small bites and position the handle in the 'right' place to apply pressure.. My "first" 4.0 filter in November 1990 on a cherokee... brand new, few thousand miles.. changed oil (early) just before a trip the following day to Hatteras Island I 'slipped' and the wrench i was using hit the distributor cap... OOPS... was lucky to have some really good contacts at local NAPA.. one fellow was in the store after hours restocking shelves.. He let me in and put a cap on my account.. took it home and installed.. never made 'that' mistake again on numerous oil changes ever since....
  5. do not think a hose large enough can be sent down the tube... I tried couple years ago, only thing i could get to pass was a piece of 1/4" OD nylon tubing.... "maybe" take off the pump/pickup fitting and then siphon from that location.. that does require working 'under' the vehicle.... does your electric pump in the tank work? perhaps using it by bypassing the relays and accessing under the hood to pump it out...
  6. clarification please AAL = Added Additional Leaf ?? would he unbolted spring clamp result in a smoother ride? letting the leaves function on their own? would it be advised to clamp the leaves back together to 'help' that relaxed main leaf ??
  7. checked for a clogged catalytic converter...
  8. i believe the Renix system relies on a variation in fuel pressure to perform, the standard regulator does just that... mine IIRC when just running is about 32psi, if the vacuum line is removed from the regulator, it increases to 39psi i think that is by design. confirmed with this entry from a manual i downloaded... renix regulator.pdf
  9. on the 'stock' regulator, it self adjusts by the connection of the vacuum line. IIRC, at low vacuum ( experienced during acceleration) the pressure to the injectors is increased for additional fuel flow. High vacuum the pressure is lowered. I'd have no idea on the differences between the two listings on RO those two listings... the specification table seems a bit confusing to me... with a lot of contradictions, especially on the PR21T part finish... chrome, then regulator finish, silver.. ?? material.. stainless steel ? boost vacuum reference port (no), then below stating 'reference port included (yes) connector type (pin)... there is no real connector on these. inlet quantity (1)... where PR21 shows (2)... hmmm think i procured mine off of evilbay and 'so far so good'...
  10. i would still plan on replacing the regulator, be sure to also source the 'kit' for the hard line "o" rings..... this 'could' be pressure related, as the pressure drops from engine off, the leak threshold is lowered. "Could" be temperature related.. waaay out in left field, porosity on the regulator housing... good luck!
  11. guidance on removing the lens?
  12. ok, thanks... so reapplying resources/load to help an anemic engine....
  13. educate a non-2.5 owner... what does this switch 'do'...
  14. it is already on the site...
  15. the IAC is a stepper motor, so you do have one. the 'steps' move the pintle in and out exposing or closing the idle air bypass. the IAC is in play at idle, adjusting air bypass to control the idle speed. the 2.5 has a electro-mechanical stepper acting on the throttle lever itself.. as it was a 2.5, i did not include.. all i posted was from the 1989 service manual. thanks OHM for posting an image of the tool.. i had never seen one, imagine scarce
