llhat
Everything posted by llhat
  1. thank you my liner is solid up the sides, there are fairly large head screws that seem to retain the liner and the liner covers the rail. Installation based on you image would require large cuts in the liner for that type of clamp arrangement. response is appreciated.
  2. i have a ?? Pendaliner?? bed liner in my 1989, was in it when I purchased truck in 1997, the liner covers the top ledge of the bed sides.... would the cover you link and used fit? Installation is drilling the top ledge of the bed? think i have an aluminum top edge cover on my tailgate...
  3. pretty certain my 89 pioneer has a panel back there, not tilted the seat forward in a while ( bench seat)
  4. my 89 filter vertical, have always been able to use a regular strap wrench ( thin metal band) with a lever on it. you have to take small bites and position the handle in the 'right' place to apply pressure.. My "first" 4.0 filter in November 1990 on a cherokee... brand new, few thousand miles.. changed oil (early) just before a trip the following day to Hatteras Island I 'slipped' and the wrench i was using hit the distributor cap... OOPS... was lucky to have some really good contacts at local NAPA.. one fellow was in the store after hours restocking shelves.. He let me in and put a cap on my account.. took it home and installed.. never made 'that' mistake again on numerous oil changes ever since....
  5. do not think a hose large enough can be sent down the tube... I tried couple years ago, only thing i could get to pass was a piece of 1/4" OD nylon tubing.... "maybe" take off the pump/pickup fitting and then siphon from that location.. that does require working 'under' the vehicle.... does your electric pump in the tank work? perhaps using it by bypassing the relays and accessing under the hood to pump it out...
  6. clarification please AAL = Added Additional Leaf ?? would he unbolted spring clamp result in a smoother ride? letting the leaves function on their own? would it be advised to clamp the leaves back together to 'help' that relaxed main leaf ??
  7. checked for a clogged catalytic converter...
  8. i believe the Renix system relies on a variation in fuel pressure to perform, the standard regulator does just that... mine IIRC when just running is about 32psi, if the vacuum line is removed from the regulator, it increases to 39psi i think that is by design. confirmed with this entry from a manual i downloaded... renix regulator.pdf
  9. on the 'stock' regulator, it self adjusts by the connection of the vacuum line. IIRC, at low vacuum ( experienced during acceleration) the pressure to the injectors is increased for additional fuel flow. High vacuum the pressure is lowered. I'd have no idea on the differences between the two listings on RO those two listings... the specification table seems a bit confusing to me... with a lot of contradictions, especially on the PR21T part finish... chrome, then regulator finish, silver.. ?? material.. stainless steel ? boost vacuum reference port (no), then below stating 'reference port included (yes) connector type (pin)... there is no real connector on these. inlet quantity (1)... where PR21 shows (2)... hmmm think i procured mine off of evilbay and 'so far so good'...
  10. i would still plan on replacing the regulator, be sure to also source the 'kit' for the hard line "o" rings..... this 'could' be pressure related, as the pressure drops from engine off, the leak threshold is lowered. "Could" be temperature related.. waaay out in left field, porosity on the regulator housing... good luck!
  11. guidance on removing the lens?
  12. ok, thanks... so reapplying resources/load to help an anemic engine....
  13. educate a non-2.5 owner... what does this switch 'do'...
  14. it is already on the site...
  15. the IAC is a stepper motor, so you do have one. the 'steps' move the pintle in and out exposing or closing the idle air bypass. the IAC is in play at idle, adjusting air bypass to control the idle speed. the 2.5 has a electro-mechanical stepper acting on the throttle lever itself.. as it was a 2.5, i did not include.. all i posted was from the 1989 service manual. thanks OHM for posting an image of the tool.. i had never seen one, imagine scarce
  16. some instructions from manual... have NO idea what a stepper motor exerciser is... lot of reading text comanche.pdf p 584 is stepper.pdf
  17. i wanted to do this few years ago during a fuel pump failure and dang near full of gas... tried a piece of fuel hose ?(5/16 ID) and i could not get it down the filler neck... for a 'test' I took a smaller piece of hard nylon tubing that was like 1/4" and it was troublesome getting it down there... maybe doable, but not easy.
  18. dorman also makes a unit, get at you local FLAPS, or even evilbay...
  19. i'd guess the dye is a good process, as 'some' external coolant leaks will disperse and not puddle or accumulate in cavities
  20. IIRC, the pressure bottle on the firewall has connections on the water pump and thermostat housing... I'd expect some type of flow depending on how the connection on the thermostat housing is constructed ( "behind" the thermosat in the block or on the radiator side )... I also need to top my 89 off periodically, but "I" have some certainty that "I" have a weeping heater core, though my floor is dry as a bone.
  21. i believe a jpeg, save to computer and enlarge.. I see OHM has posted a link also thanks.
  22. only issue I have experienced on my 89 4.0 using these harness assemblies is the 'J' hose connecting to the air filter housing. original harness "J" hose had a increase in ID on one side to connect, new dorman are straight internal diameter both sides. I believe I have documented this in past threads.. finally took the suggestion of a poster here to 'press' a section of hard tube from old harness into the nipped existing on the air filter housing. that "j" hose now fits without being overly stretched and ultimately cracking. next 'project' in my instance is to perform the modification of the rear vacuum tube to valve cover... drilling out the plastic connector and using a larger internal diameter vacuum line.... procedure shown on boards here also.. as far as the rest of the vacuum fittings on these dorman units, mine have always appears secure with no need for zip ties or clamps
  23. was the 'height' of the pushrod checked with the new master cylinder and booster? If too short, full travel maybe not there, if too long, not enough stroke...
  24. been running a gutted housing for i can't remember how many years.... no inspection requirements for me either 'now' but during my life with it, would always pass a visual, did not have Gas testing here.
