llhat
Everything posted by llhat
HVAC Questions: Vacuum Actuators & Foam Insulation
llhat replied to NickyV's topic in MJ Tech: Modification and Repairs
if the actuator does not hold vacuum, some JB weld instead of bondo .... or replace it completely. -
Major oil leak from the rear passenger side
llhat replied to hgeranium's topic in MJ Tech: Modification and Repairs
my 89 was on large hex bolt thru the housing. IIRC used a 'kit' from Mahle, Felpro also has a 'kit'.... I'd watch out for off-brands as the o-ring material can be inferior. not finding Mahle kits on regular sources ( amazon, evay ) but fel pro is showing.... leery of some of the others. heat and time does a number on these.... for what it is woth... why not OEM Mopar kit? IF this is where your leak originates... -
good suggestion on the delay and chime modules, I had not considered those... but from the OP's post
would need to be between the horn switch and the appropriate terminal on the horn relay... (noted it still blows fuse with relay removed), inside a harness somewhere...........
yes, that is correct... just to clarify, this is eliminating the CPS connector... engine will not run with the CPS deleted completely...
many MJ stock with 3.54 gearing, what is your present front gearing?
Gas tank plastic/skid plates
this thread has a great image of an uninstalled front skid plate..(scroll down in the thread) as well as a couple of comments from Cruiser from the past on them... I will agree on getting in the way.... -
just noted this on another search, may be of help to you in regards to the studs, etc... -
mine had rubber, it was above the skid plate... it was a steel skid plate that connected to frame rails, extended from below radiator on an angle downwards ending before the tie rods. I recall when it was on there always had to wipe oil off of it from changing the oil filter ( or seem to recall.. been some years now) -
that ain't bad on hella... I used a Cibe set that were an over the counter GM application... had friend that was parts manager.. though no longer working, they are still mounted... need bulb assembly for them.... think bulb holder too...
Yeah.. hind site.. the front skid plate and that thick rubber shield below Radiator, etc also made that journey to the world of scrap after I removed it for something... second owner of this 89 since 1997, I may have it documented 'why' i took the front skid off.... maybe not... -
"years" ago my 89 long bed developed a fuel leak.. guessed it.. corrosion on bottom, dirt trapped tween tank and metal skid... replaced the tank 'then' but did not reinstall the skid... it laid around... "sometime" on a scrap metal run, my dad evidently tossed it.. ( 2010-2012 era).. so it is gone, I've come to terms with it. -
PSA: Exhaust gasses are HOTš¤£
llhat replied to fiatslug87's topic in MJ Tech: Modification and Repairs
my late father had locals to make up an exhaust... from cat back.. think flowmaster muffler and then pipe exiting to your location, never saw any damage to end cap..... before he bent the snit out of that side of bumper basically destroying the end cap and that side of bumper ( but NO body damage).... he went to jeep dealer ( we had friends in parts department) and he bought me a new rear bumper that I have YET to install... not even taken it out of package.... i think it was a chrome version... know also bought a new front chrome bumper also... this has now to be about 20 years or so... procrastination... and snitty faded grey paint, so why ?? -
Sluggish Forum Response since about Dec 20
llhat replied to AnotherOldJeepGuy's topic in Forum Issues, Ideas, Testing
and still occurring... this afternoon, 'ok' but this morning 502 gateway errors. -
increase extension of tip out of body line.... just increase distance... those end caps are not 'that' plentiful to melt away -
leaning on air in system... is my guess mine did it when cold, I suctioned some fluid off and put some lucas PS treat in it.. seemed to have helped... this was before a pressure line replacement by shop when doing other work, has not done it since... there was a line leaking.... so maybe allowing air into system? had similar issue on a dodge 3500 cummins, suctioned out fluid multiple times and replaced to effect a fluid change over time.. helped it a bunch... was some fancy arsed $$ fluid also...
cannot remember the brand, but did use some LED bulbs for backup... or tried... I had trouble with fitment in the socket, seemed like the pins were too shallow to engage, you just could not twist in the bulb to lock it... the solder "point" on the end of the bulb seemed like the place to modify, ruined one bulb trying that tactic... this was last fall, just cannot remember what I finally did... I was also repairing the housing from a broken tab holding the clip nut on the tailgate side of the housing... I made an entire metal clip to sandwich the plastic and allow the screw to bite... so far so good on that.... was cheeper than a housing!!! some others applaud the illumination difference
and still sluggish as times and also get the 502 screen at times... -
Need advice on turn signal troubles.
llhat replied to thejeepmanwithcrocs's topic in MJ Tech: Modification and Repairs
?? diagnosis ?? poor connection of the turn signal flasher in the body of the fuse block ?? -
is your formed tube leaking or something with the rubber lines? If tubing is OK, remove, cut the compressed ferrule acting as a hose clamp and use a clamp to reinstall the hoses.
Rookie Water Pump Replacement
llhat replied to AnotherOldJeepGuy's topic in MJ Tech: Modification and Repairs
I try to check the housing surface for 'flat'... usually take a sheet of emery paper and a known flat surface and lightly lap it 200 to 320 grit is 'ok' have even used a flat file lightly also... I can't recall, but if the housing bolts extend into the water passage, may need a touch of sealant... -
could the 'chirp' be the belt contaminated with coolant?... but if you've seen the drip, then the w p seal is probably gone. been too many years since I've done mine... I'll let someone else chime in... good luck. -
1990 Jeep mj column shift 2wd to 4wd swap
llhat replied to MattK's topic in MJ Tech: Modification and Repairs
no 100% sure but think the XJ tunnel may have a different contour than the MJ tunnel... Others can set me straight if wrong... -
Double vacuum? where's the engine block to get its air? i also think these engines are a bit temperamental when vacuum leaks are introduced.
not sure a catch can on rear tube would assist... vacuum flows from the orifice and to intake manifold... this tube must be kept clear for the CCV to work. The front tube and fitting on the valve cover 'should' have negative pressure, supplying clean air from air box to engine. When the 'flow' is disturbed by poor performance of the rear orifice and by excessive crankcase pressure, then the engine pushed air into the airbox, along with oil vapor in suspension where it accumulates on the filter. this side is where most put the catch can.... but as spoken, not a lot of room.. and the appropriate size hose does not conform well to the limited space. the later design is just a bit better, with a larger hose on the rear and a straight shot to the HO airbox... I think the large rear HO hose would be an improvement, but 'I' have yet to try it... my 89 has the case valve cover, I think it looks better than the later stamped steel... but that stamped steel valve cover has its advantages for certain... ( mainly IMHO) the larger rear hose
