tarmac2dirt Posted July 7, 2025 Share Posted July 7, 2025 Will be building a new engine soon (4.0) for my 88 MJ. At the same time I'm going to replace the clutch. What are you guys using as a good upgrade clutch for an engine with very minor mods. LUK--Precision--MPAC--ECT. so many to pick from off rockauto. At this time, I'm just collecting some parts before i dig into the engine parts for pistons and cam. This will be a dd and not a stroker engine, just a good built 4.0. I had a clutch replaced in 2007. but don't know what brand it was. It served me well. Please let me know what you or your buddies believe is a good replacement. Thanks Paul Link to comment Share on other sites More sharing options...
89 MJ Posted July 7, 2025 Share Posted July 7, 2025 I like my Luk clutch kit. It has been perfect for daily driving without being too stiff, but it still doesn't slip when off roading, towing, or when I dump the clutch like an idiot (which is rare, but fun). Link to comment Share on other sites More sharing options...
ratrapp Posted July 7, 2025 Share Posted July 7, 2025 i second the luk clutchs.good clutchs if you use them for what there intended to be used for.thats the only clutch i use in my shop for the last 10 years and i havent a had single one die or fail prematurely. Link to comment Share on other sites More sharing options...
pizzaman09 Posted July 8, 2025 Share Posted July 8, 2025 I think every clutch I have ever changed in my life was an LUK, they all work great. According to the maintenance records for my MJ, the dealership that owned it put a LUK clutch in it, I've worked it harder than most people would with zero issues. My vote is LUK. Link to comment Share on other sites More sharing options...
derf Posted July 8, 2025 Share Posted July 8, 2025 I've had a couple of Centerforce clutches in my day. I get the CF or CF-II for stock replacement-ish applications and they perform well. I've heard good things about LUK as well. Stay away from the so-called high performance clutches. They tend to be less fun to drive every day. Good for performance driving, less so for daily use. Link to comment Share on other sites More sharing options...
ghetdjc320 Posted July 8, 2025 Share Posted July 8, 2025 Luk rep-set has been my go to. But chuck the throw out bearing and get a timken or skf unit Link to comment Share on other sites More sharing options...
Big Dan Posted November 11, 2025 Share Posted November 11, 2025 On 7/8/2025 at 6:28 PM, ghetdjc320 said: Luk rep-set has been my go to. But chuck the throw out bearing and get a timken or skf unit Thread revive here - I know the "throw away the Luk bearing" (or insert brand of composite bearing) is always said. I'll put one in for the camp of the provided bearing. I haven't had any issues with the Luk one. Currently going on 3 years. When I did my external slave swap, I actually bought a timken, and a national bearing, to compare to the provided one. National was gritty and off center. Luk and Timken looked fine. I ended up just trying the Luk. Point being - anecdotal, but, just check out what you have and make your decision from there. Link to comment Share on other sites More sharing options...
PIKE Posted November 11, 2025 Share Posted November 11, 2025 Another vote for LuK. I have one in my Ford 7.3 Powerstroke F350 and my Comanche 4.0 AX15. The one in my Comanche is the Pro Gold version. Link to comment Share on other sites More sharing options...
TheNerfsmith Posted November 11, 2025 Share Posted November 11, 2025 To add to this, I have a LUK in my AX-15. Works great, I haven't had any issues with it. Link to comment Share on other sites More sharing options...
rokinn Posted November 11, 2025 Share Posted November 11, 2025 I used the heavy duty Luk in my AX-15. I wasn't able to notice any difference between the original and the new one as far as stiffer action in the clutch pedal. Definitely smoother engagement from the old one. Bought a Timken throw out bearing. Switched from internal to external slave along with new master and converted to DOT 5 silicone brake fluid. Happy with the results. Link to comment Share on other sites More sharing options...
