jordan Posted September 23, 2023 Share Posted September 23, 2023 Hey all.Does anybody hear have a source for a headliner replacement on my 88 jeep comanche?.Thanks for any help Link to comment Share on other sites More sharing options...
yachmoo Posted September 23, 2023 Share Posted September 23, 2023 Hello, I am also looking for similar. so far all I've found is this site and it's not a direct replacement. More a can of adhesive and new cloth. https://www.stockinteriors.com/autoheadliner/6729 Link to comment Share on other sites More sharing options...
Pete M Posted September 23, 2023 Share Posted September 23, 2023 you can try SMS headliners and see if he's making them, or you can contact your local auto upholstery shop and they may be able to make you one. they can definitely make one if you have an old one to take a mold from. Link to comment Share on other sites More sharing options...
a1500ram Posted September 24, 2023 Share Posted September 24, 2023 I can provide a custom hand formed headliner backer board already covered and ready to install $425 includes shipping and extra material for the visors. I can provide a diy kit(material and instructions) for you to recover your existing headliner panel. $24 plus shipping. Includes 48”x60” for your headliner and 2each 20”x30” material for your visors so you can have those recovered locally. see attached photo chart. Note: Nutmeg is no longer available. Link to comment Share on other sites More sharing options...
AZJeff Posted September 24, 2023 Share Posted September 24, 2023 If your original headliner backer board is solid, removing the old headliner fabric and installing new stuff from the vendor of your choice is pretty straightforward. There are lots of YouTube videos on how to do it for a Cherokee, and an MJ is just a smaller version of that. There are also “how to” sites on how to recover the sun visors as well. The job doesn’t require lots of special tools, just clean hands and patience. Link to comment Share on other sites More sharing options...
Drahcir495 Posted September 28, 2023 Share Posted September 28, 2023 Are you missing yours completely or just damaged? I found a way to repair missing parts of the backing board using great stuff expanding foam. It’s not as hard as you think. Just take your time and it will turn out well. I have outlined the process I took in my build up pages. If you do plan on redoing it yourself and have questions, just pm me and I will tell you everything I know Link to comment Share on other sites More sharing options...
ja_racing Posted October 11, 2023 Share Posted October 11, 2023 I need a headliner diy kit but I'm not sure what shade of gray i have its a 88 with gray interior Link to comment Share on other sites More sharing options...
JZLAJeep Posted October 11, 2023 Share Posted October 11, 2023 12 minutes ago, ja_racing said: I need a headliner diy kit but I'm not sure what shade of gray i have its a 88 with gray interior We've been happy with using fleece purchased from a fabric store. It's also been our experience that close is good enough when it comes to the color of the headliner. We installed gray on the headliner of our dark blue interior MJ because we had some fabric left over from our gray interior XJ and the neutral color doesn't look out of place. Link to comment Share on other sites More sharing options...
PCO6 Posted October 12, 2023 Share Posted October 12, 2023 I covered the head liner of my XJ a few years ago. I bought enough material to do my MJ too and it's on the list of to do's. It's a pretty straight forward job. It took more time to get it out than it did to cover it. I purchased "Westminster Coating" from a fabric store. It's used a lining material for coats. It's a bit thicker than the original material (which wouldn't be hard!) and it is very easy to work with. My fabric store humour isn't very good. I asked the clerk if it would make my Jeeps warmer in the winter. With a serious look on her face she said ... "probably". Link to comment Share on other sites More sharing options...
VintageJC Posted May 9, 2025 Share Posted May 9, 2025 Link to comment Share on other sites More sharing options...
pizzaman09 Posted May 10, 2025 Share Posted May 10, 2025 I did my headliner with some generic grey headliner material purchased on eBay. It was pretty easy to do, my only tip is to purchase Permatex or 3M "headliner adhesive," it's far stickier than spray on contact adhesives like 3M Super 77. Link to comment Share on other sites More sharing options...
PIKE Posted May 12, 2025 Share Posted May 12, 2025 My headliner backer board and fabric are both in good shape. The fabric is starting to separate and is sagging on about half of it. Is there any way to spray some adhesive in there and press it back into shape? Sure would be a lot easier than taking every thing apart. I'm in the habit now of pushing it back in place every time i get in. It stays for awhile. Link to comment Share on other sites More sharing options...
AnotherOldJeepGuy Posted May 13, 2025 Share Posted May 13, 2025 Seems like you could just cut across the loose part and spray the adhesive in and push it back into shape. I am assuming the glue is tacky enough that it would cure before it came back loose, and also assuming you are OK with a line in the headliner where you cut it. Link to comment Share on other sites More sharing options...
