Does anyone know how much a 242 transfer case weighs? I need to pull the one in my wife's XJ to rebuild it, and I don't know if I can bench press it from under the vehicle in the driveway or if I'm going to have to have a shop pull it for me.
Harbor freight has a pretty nice transmission jack that I absolutely love.
Mine has seen better days for sure. It is an absolutely great thing to have. So for I have used it on the transmission, transfer case, gas tank, rear bumper, rear diff, and front diff. It will pick up the entire front end but the legs fold over. Woops!
When I get around to doing the diff's in the XJ I will be buying another one.
I pulled 3 the other day at the junkyard and its more like a holy $#!& holy $#!& holy $#!& holy $#!& until you get it down but definitely doabe
17 hours ago, fiatslug87 said:
The older I get, the more I appreciate mechanical “advantage.”
+1, Having my first child also made getting pinned under car parts less interesting to me.
I can recommend the Strongway tyranny jack from Northern Tool.  I didn't have to separate the transfer case from the AX-15 when I replaced the slave cylinder.  It handled both units still full of fluid.  The platform has tilt and roll articulation which is nice. Very sturdy and safe.
Buy it, use it, sell it.
Now that you mention it ... I own one of those.
I lent it to a friend several years ago ... hmmmmmm
It's crazy how that happens. My uncle used to have a sign out sheet in his garage. I'm just now realizing I need one.
I don't know about putting on TC cases. I will be in the same boat, as soon as I rebuild the 242 I have. I did use some bolts with the heads cut off to 'guide' a NV3550 to the motor. Worked real well. Might work for a TC case.
