Crispy a 1989 Long Bed Dually
Got a new windshield in finally. Just have to put the trim on. Needs an alignment then I can finally start driving it to work. Might end up putting buckets in it since I have an extra set of brackets and a few extra sets of seats
Swapped out the starter because the old one had gotten really slow and I already had a new one on the shelf. Did a full tuneup as well with new plugs, msd wires and a cap and rotor. I’ve been driving it to work and it’s been doing well. Even put it to work cleaning out the yard
  • 3 months later...
Finally got the wipers working. Turned out to be a simple fix. The wiper delay module looked to have been submerged and very rusty inside. Changed that and the circuit breaker and now they work. Installed a trailer hitch too and haven’t done much else to this truck other than drive it
  • 4 weeks later...
  • 3 years later...
  • 88mjsally changed the title to Crispy a 89 Long bed (now with 2 extra rear tires)
Probably easier to do this as a list of the parts I used since it’s not really a kit other than the fenders.
Rear axle: sterling cab and chassis 10.5 from a 1995 ford f-350 7.3 dually
Front axle: Dana 30 hp from a 1996 Jeep Cherokee.
Front suspension: rough country 4.5” springs shocks and lower control arms. IRO adjustable track bar and rough country extended brake lines
Rear suspension: stock mj springs and shocks with Barnes 4wd perches welded to the 10.5 spring over.
Dually fenders: came out of Florida from a truck that was getting parted out. Unsure if they are JC Whitney or something else but they are for sure mj specific. Someone did fill in the fuel door so I used boat parts to add one back in.
Front Bumper: arb from a 97-01 xj with a 12k badlands winch installed in it
Wheels and tires: front wheels are from a newer jk with adapters. Rear wheels are just stock steelies with new but cheap mud tires.
Brakes: 95-96 xj booster and master plumbed to mostly original lines with the rear prop valve deleted. I used a 91-96 xj brake pedal so I didn’t have to try to grind on the rod from the booster.
that’s most of the details and I added all the pics I took so far. Eventual plans involve removing the worn out 4.0 and replacing it with a 5.3 lm7 and 4wd ax15
  • 88mjsally changed the title to Crispy a 1989 Long Bed Dually
