88mjsally Posted April 10, 2022 Author Share Posted April 10, 2022 Got a new windshield in finally. Just have to put the trim on. Needs an alignment then I can finally start driving it to work. Might end up putting buckets in it since I have an extra set of brackets and a few extra sets of seats Link to comment Share on other sites More sharing options...
88mjsally Posted April 12, 2022 Author Share Posted April 12, 2022 Trim is back on. Need to put the door panels back in and dash back together before it goes Friday for an alignment Link to comment Share on other sites More sharing options...
88mjsally Posted April 12, 2022 Author Share Posted April 12, 2022 Got the dash back together and everything working including the radio Link to comment Share on other sites More sharing options...
88mjsally Posted April 29, 2022 Author Share Posted April 29, 2022 Swapped out the starter because the old one had gotten really slow and I already had a new one on the shelf. Did a full tuneup as well with new plugs, msd wires and a cap and rotor. I’ve been driving it to work and it’s been doing well. Even put it to work cleaning out the yard Link to comment Share on other sites More sharing options...
Pete M Posted May 1, 2022 Share Posted May 1, 2022 that's a lot of tires Link to comment Share on other sites More sharing options...
88mjsally Posted May 1, 2022 Author Share Posted May 1, 2022 11 hours ago, Pete M said: that's a lot of tires Only 15😂 A lot more than I could fit in my short bed Link to comment Share on other sites More sharing options...
88mjsally Posted August 26, 2022 Author Share Posted August 26, 2022 Finally got the wipers working. Turned out to be a simple fix. The wiper delay module looked to have been submerged and very rusty inside. Changed that and the circuit breaker and now they work. Installed a trailer hitch too and haven’t done much else to this truck other than drive it Link to comment Share on other sites More sharing options...
Pete M Posted September 22, 2022 Share Posted September 22, 2022 On 8/26/2022 at 5:05 PM, 88mjsally said: haven’t done much else to this truck other than drive it driving it is the most important part. Link to comment Share on other sites More sharing options...
88mjsally Posted February 21 Author Share Posted February 21 It’s changed a little in three years….. Link to comment Share on other sites More sharing options...
neohic Posted February 22 Share Posted February 22 You know we need more information. Link to comment Share on other sites More sharing options...
89 MJ Posted February 22 Share Posted February 22 That’s awesome! Link to comment Share on other sites More sharing options...
watchamakalit Posted February 22 Share Posted February 22 Is that one of the old JCWhitney dually kits? I think it looks awesome. More info please. Link to comment Share on other sites More sharing options...
Gjeep Posted February 22 Share Posted February 22 Looks great Link to comment Share on other sites More sharing options...
88mjsally Posted February 22 Author Share Posted February 22 Probably easier to do this as a list of the parts I used since it’s not really a kit other than the fenders. Rear axle: sterling cab and chassis 10.5 from a 1995 ford f-350 7.3 dually Front axle: Dana 30 hp from a 1996 Jeep Cherokee. Front suspension: rough country 4.5” springs shocks and lower control arms. IRO adjustable track bar and rough country extended brake lines Rear suspension: stock mj springs and shocks with Barnes 4wd perches welded to the 10.5 spring over. Dually fenders: came out of Florida from a truck that was getting parted out. Unsure if they are JC Whitney or something else but they are for sure mj specific. Someone did fill in the fuel door so I used boat parts to add one back in. Front Bumper: arb from a 97-01 xj with a 12k badlands winch installed in it Wheels and tires: front wheels are from a newer jk with adapters. Rear wheels are just stock steelies with new but cheap mud tires. Brakes: 95-96 xj booster and master plumbed to mostly original lines with the rear prop valve deleted. I used a 91-96 xj brake pedal so I didn’t have to try to grind on the rod from the booster. that’s most of the details and I added all the pics I took so far. Eventual plans involve removing the worn out 4.0 and replacing it with a 5.3 lm7 and 4wd ax15 Link to comment Share on other sites More sharing options...
88mjsally Posted February 23 Author Share Posted February 23 I got the ROL fog lights wired up over the weekend and installed a 12k winch I had from a parts jeep in the bumper. Also fixed the blinker issues I was having and put in all new LED bulbs Link to comment Share on other sites More sharing options...
scguy Posted February 24 Share Posted February 24 What a beast! Link to comment Share on other sites More sharing options...
hgeranium Posted February 24 Share Posted February 24 My God… Link to comment Share on other sites More sharing options...
ThatJeepGuy Posted February 24 Share Posted February 24 Nice work, ive seen this lurking through some of Facebook lately. Nice to see it here as well! Link to comment Share on other sites More sharing options...
88mjsally Posted February 25 Author Share Posted February 25 Got some marker lights installed on the fenders. I don’t like drilling holes in impossible to find parts but I wanted them for safety and they make it look like a true dually Link to comment Share on other sites More sharing options...
88mjsally Posted Sunday at 04:38 PM Author Share Posted Sunday at 04:38 PM Finally made it outside and around the block. Just needs a little more tinkering Link to comment Share on other sites More sharing options...
88mjsally Posted 4 hours ago Author Share Posted 4 hours ago Got the interior looking better with some xj buckets and a console to replace the well worn bench Link to comment Share on other sites More sharing options...
