Fuel pump still won’t work
Ok so I have replaced the fuel pump and redone the ground and it still won’t work. It’s a brand new pump and the relay is kicking on. And I can’t figure out what it is. The wiring in the cab looks brand new. I followed it as far into the foot well as I could see. Here is a pic of my fuse box maybe something is missing I can’t see and these 4 wires that aren’t connected to anything. Idk where they go to maybe someone can help.
3 hours ago, Pete M said:
have you checked for power at the pump?  have you supplied 12v straight to the pump to verify that it does indeed function?
No no power. I assumed it was the firing to the pump but it all looks good someone told me to redo the ground and it might work so I did and still no dice. I didn’t check the pump I’m kinda just assuming since it was brand new it would be good.
people have bought them DOA so it never hurts to check.
when are you checking for power?  the 12v is only sent for a few seconds after turning the key to run and then while the engine is cranking.  if you pull the starter relay so the engine doesn't crank, you can have someone turn the key to start and be sure power is being sent. :L:
I’m checking for power at the harness side of the pump connector. what are your recommendations on checking for power and checking if the pump is functional?
Just now, Pete M said:
the where is ok, but when are you checking for power?
I have my leads in when my friend turns the key so I’m reading from before the key is turned and then to the 3rd click of the key so right before you turn the key to start the engine.
I think you should pull the relay and check for constant power.  someone back me up on this, but I think if you jumper 30 to 87 then the fuel pump should get power.  30 is always hot and 87 goes to the pump.  I think.
THIRD click is START, IIRC. First click is from locked to OFF, second click is RUN, third click is START. You should be testing in the RUN position.
  • 6 months later...
   Howdy,  working on a 1990 MJ 4.0 . Fuel pumps work outside but only getting 6.5 volts best I can tell at harness. Learned a lot
here all ready and will be checking grounds.  One comment above stated a faulty ballast resistor would prevent the fuel pump from kicking on. My understanding was the resistor was not in play during the starting process, only after the engine was running.
 Was hoping someone could shed some light on this.    My problem seems intermittent. Through the harness, with the key the pump in
a Jug worked fine. 5 min later nothing. Just found this forum.  Probably because even as a farm truck it never stopped b4.
   Very helpful,good knowledge. Thanks.        Rich
Kinda of TRUE. Its in play only in the sense that it supplies ≈9-10vdc (voltage drop across ballast resistor) during engine RUN and CRANK (Fuel Pump Relay is ON). Now during engine CRANK the Starter Relay terminal (BAL) is wired to bypass the ballast resistor and supply direct battery voltage to fuel pump. During engine CRANK higher voltage wins.
