Performance parts
eaglescout526
Stage I Cam goes for $236. 1 left
Stage II Cam - $282 6 left
No Stage III-V Left
Tappets- $18 31 left.
Timing chain set-$165 7 left
Exhaust valve-$14 2 left
Valve seal package-$21 14 left
Cylindrical valve spring-$15 7 left
Conical valve spring-$10 145 left
Lots of Conical valve spring retainers left. $5-$10
Plenty of valve stem lock sets. $15
HD oil pump-$83 6 left
High Volume Oil Pump-$100 27 left
Head gasket-$83 2 left
Front end engine gasket pkg-$63 13 left
Exhaust/intake gasket-$15 1 left
That's it. Some are orderable still. Others at dealers. Ones I can order can be had for cheaper through me.
Why let me quote the catalogue
HD- "This heavy duty pump is made of cast iron for added strength and better rough cycle wear characteristics."
HV- "This high volume pump is similar to P4529227(above) except that it has larger rotors for a 25 percent increase in capacity."
Just now, Blaine.D said:
Just curious by any chance are there is still any of those performance ecu/ecms still floating around.
No..when that one stroker found surfaced, I immediately looked and see if there was any and there was not. All it does is increase spark advanced and fuel flow.
Did you search #P4529334 the HP ecu that was called out in my Jeep book, there was 26 in the US back when I got the book mid 90s
16 minutes ago, Manche757 said:
Eagle, what would you guess the condition of a 30 year old timimg chain is? Links still flexible? Metal pitted and rough?
I can tell you that somewhere around twenty years and 200,000 miles I replaced the timing chain in my '88 XJ as what I thought was a preemptive strike. I'm an AMC guy, and the AMC V8s had a cam sprocket that used nylon teeth. They weren't good for much more than 100,000 or so miles (maybe 150,000 if well cared for). Thinking the Jeep was the same, I thought I was living on borrowed time.
Once I got it apart, I found that the original timing chain was basically a roller chain, it was in perfect condition, and it hadn't stretched at all. I had the new parts so I installed them, but I saved the old parts and I wouldn't hesitate to use them to repair an older engine in a beater or trail rig. I would guess your 30-year old timing set is basically perfect.
14 hours ago, Warren Mohler said:
you can only hope they will show up. When the AMC dealership I worked at closed I helped clean out building, threw out a dumpster full of Studebaker parts I could have had them all. STUPID on my part
Sounds like the dealership I was able to pick , they took a lot of parts out of the boxes to burn the cardboard and then the parts were ruined.
