SouthernComanche Posted August 23, 2019 Posted August 23, 2019 Well, I guess this is the start to my build thread! won't really be a build just the progress of my daily. I’ve had her for like 2 months now and so far ive: Replaced both window regulators Fixed a lower radiator hose leak Got a steal on new taillights Did front breaks New tires Window tint Right now I'm working on chasing down a TCU problem. My trans isnt shifting on its own so I have to go 1-3-4. I’ve got some big plans for this truck in the future its just a matter of saving up! If you want to follow the build closer follow my insta @ DannyD815 I will add more photos when I can!
mjeff87 Posted August 23, 2019 Posted August 23, 2019 Nice clean looking 87. You should have 4.56 gears in those axles too
MJXJjeepguy Posted August 23, 2019 Posted August 23, 2019 I had similar problem with shifting on it own like I have to shift to 1st gear to go off the shifting 3 to D but i got it fixed all I did was replace all 3 solenoid in the transmission after u remove pan, it not hard at all and BAM my jeep drive like new shifting smooth!!
SouthernComanche Posted August 24, 2019 Author Posted August 24, 2019 I had similar problem with shifting on it own like I have to shift to 1st gear to go off the shifting 3 to D but i got it fixed all I did was replace all 3 solenoid in the transmission after u remove pan, it not hard at all and BAM my jeep drive like new shifting smooth!! I'm gonna be replacing all of the solenoids shortly Sent from my iPhone using Tapatalk
SouthernComanche Posted August 24, 2019 Author Posted August 24, 2019 What are your long term plans for the truck? Trying to keep it all original but I sill want to take it on trails so 4x4 is a maybe. I gotta work out the leaks and get my trans figured out then I’ll have a good daily. There’s definitely a lot of work to be done under the hood Sent from my iPhone using Tapatalk
SouthernComanche Posted August 24, 2019 Author Posted August 24, 2019 Nice clean looking 87. You should have 4.56 gears in those axles too Yessir I do! Sent from my iPhone using Tapatalk
Pete M Posted August 27, 2019 Posted August 27, 2019 what types of trails? with a locker in back and tow points front/rear you can go to an awful lot of cool places. (never go alone of course)
SouthernComanche Posted August 27, 2019 Author Posted August 27, 2019 what types of trails? with a locker in back and tow points front/rear you can go to an awful lot of cool places. (never go alone of course) Ive been looking for just some easy beginners offroad courses somewhere near the San Antonio area but the closest one Ive been able to find is like an hour away, Ive been looking into going for a while now! 1987 Comanche 2.5L Aw4 automatic. 4.56 rear end. San Antonio Texas
SouthernComanche Posted August 27, 2019 Author Posted August 27, 2019 UPDATE: I finally got my TCU situation figured out, and it was of course the easiest solution. My TCU is bad. I went ahead and ordered a cheap 4.0Aw4 TCU and of course it works haha. Only problem is my shift points are terrible, shifts way to early and bogs down hard. So I do need to either fix mine or buy a proper 2.5 Aw4 TCU. If anyone has one for sale LMK! I'm sending mine out to Nickintimefilms (the guy who makes the awesome renix scanner) and hes gonna take a look and see what he can figure out. 1987 Comanche 2.5L Aw4 automatic. 4.56 rear end. San Antonio Texas
eaglescout526 Posted August 27, 2019 Posted August 27, 2019 So...I did some searching for your controller. There are two different part numbers. 53005101 is for the 2.5L auto. No one has one but this is what you want to look for. There’s an older part number still available from one dealer but it is worth an arm and a leg. Maybe half a brain. So a 4.0 controller won’t be direct plug and play for you because of the shift points the controller expects from the six cyl
SouthernComanche Posted August 27, 2019 Author Posted August 27, 2019 So...I did some searching for your controller. There are two different part numbers. 53005101 is for the 2.5L auto. No one has one but this is what you want to look for. There’s an older part number still available from one dealer but it is worth an arm and a leg. Maybe half a brain. So a 4.0 controller won’t be direct plug and play for you because of the shift points the controller expects from the six cyl Thankyou so much! Probably gonna end up having to get mine rebuilt but we will see, I'm really hoping someone has one ! 1987 Comanche 2.5L Aw4 automatic. 4.56 rear end. San Antonio Texas
eaglescout526 Posted August 27, 2019 Posted August 27, 2019 1 minute ago, SouthernComanche said: Thankyou so much! Probably gonna end up having to get mine rebuilt but we will see, I'm really hoping someone has one ! I wish you the best of luck. Best bet is to have it “rebuilt”. As far as anyone’s having one, they probably have a stash of platinum with that controller.
MJXJjeepguy Posted August 28, 2019 Posted August 28, 2019 On 8/27/2019 at 11:45 AM, eaglescout526 said: So...I did some searching for your controller. There are two different part numbers. 53005101 is for the 2.5L auto. No one has one but this is what you want to look for. There’s an older part number still available from one dealer but it is worth an arm and a leg. Maybe half a brain. So a 4.0 controller won’t be direct plug and play for you because of the shift points the controller expects from the six cyl Isnt 4 cyl with auto and 4.56 factory rare?
eaglescout526 Posted August 28, 2019 Posted August 28, 2019 9 minutes ago, MJXJjeepguy said: Isnt 4 cyl with auto and 4.56 factory rare? Damn rare. Even more so than the Chrysler A999/2.5L combo.
MJXJjeepguy Posted August 28, 2019 Posted August 28, 2019 Just now, eaglescout526 said: Damn rare. Even more so than the Chrysler A999/2.5L combo. No $#!&? Lol that what i though bec i never heard 2.5 auto with 4.56 before... Thanks for quick respond.
eaglescout526 Posted August 28, 2019 Posted August 28, 2019 3 minutes ago, MJXJjeepguy said: No $#!&? Lol that what i though bec i never heard 2.5 auto with 4.56 before... Thanks for quick respond. Lol. I’d imagine that the autos came with that gearing. Since it is an AW4 after all. I think the A999 was set up with a different ratio
SouthernComanche Posted August 28, 2019 Author Posted August 28, 2019 Damn rare. Even more so than the Chrysler A999/2.5L combo. Yeah definitely a one of a kind comanche, gotta keep it with no rust and maybe it will be worth something one day haha 1987 Comanche 2.5L Aw4 automatic. 4.56 rear end. San Antonio Texas
eaglescout526 Posted August 28, 2019 Posted August 28, 2019 It’s definitely neat. I’ll post your build sheet this afternoon.
SouthernComanche Posted August 28, 2019 Author Posted August 28, 2019 It’s definitely neat. I’ll post your build sheet this afternoon. You seriously are a legend, thankyou! Do you know possible a rough estimate of how many were made in my configuration? It would be cool to know how rare of a truck I’ve really got.1987 Comanche 2.5L Aw4 automatic. 4.56 rear end. San Antonio Texas
eaglescout526 Posted August 28, 2019 Posted August 28, 2019 I have no idea how many were made with your set up. All I know is auto 2.5L’s don’t pop up often. Maybe someone might know a source that has said numbers.
