jeep.comanche88 Posted May 31, 2019 Share Posted May 31, 2019 Hi, I'm new to the club ! Here is my 88 Jeep Comanche Sportruck Engine : 2.5L Traction : 2x4 Odometer : 129 000 km (80 150 miles) Paint : Original Suspension : BDS (I don't know the high) Tires : 31x10.50 15 inches Location : Quebec, Canada Original location : Quebec, Canada Pictures below is when I bought it last summer. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted May 31, 2019 Author Share Posted May 31, 2019 Last summer when I decontaminate paint and wax it. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted May 31, 2019 Author Share Posted May 31, 2019 After hibernation. Oil change, installing old school lights on the roll bar and put brand new Hercules Tires on it. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted May 31, 2019 Author Share Posted May 31, 2019 Two weeks later... I put 1.5 inches wheels spacer on the rear and a 1 inch bloc to lift the rear. Alignment and ready for summer. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted May 31, 2019 Author Share Posted May 31, 2019 Last week-end. Decontaminate paint and wax it again. Link to comment Share on other sites More sharing options...
JMO413 Posted May 31, 2019 Share Posted May 31, 2019 Beautiful truck! Link to comment Share on other sites More sharing options...
SteveW155 Posted May 31, 2019 Share Posted May 31, 2019 That’s a beaut you have there! Good job!!! Link to comment Share on other sites More sharing options...
MJXJjeepguy Posted June 1, 2019 Share Posted June 1, 2019 On 5/31/2019 at 12:39 AM, Bmille24 said: Two weeks later... I put 1.5 inches wheels spacer on the rear and a 1 inch bloc to lift the rear. Alignment and ready for summer. Expand I'm wonder why did u put 1 inch block in rear to lift? From what i can see in pic ur leafspring under the axle so if u add 1 inch block that will lowered ur rear down. Do u really mean 1 inch longer shackle? Link to comment Share on other sites More sharing options...
13 Legion Posted June 1, 2019 Share Posted June 1, 2019 The paint and decals look excellent. Was this truck in Canada it’s whole life? It just looks so clean (body wise) and such low miles. Somebody took care of her. Link to comment Share on other sites More sharing options...
gogmorgo Posted June 1, 2019 Share Posted June 1, 2019 Very clean for a truck from the east... I wish mine were that nice. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted June 1, 2019 Author Share Posted June 1, 2019 On 6/1/2019 at 12:59 AM, MJXJjeepguy said: I'm wonder why did u put 1 inch block in rear to lift? From what i can see in pic ur leafspring under the axle so if u add 1 inch block that will lowered ur rear down. Do u really mean 1 inch longer shackle? Expand I mean 1 inch longer shackle yes. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted June 1, 2019 Author Share Posted June 1, 2019 On 6/1/2019 at 3:01 AM, 13 Legion said: The paint and decals look excellent. Was this truck in Canada it’s whole life? It just looks so clean (body wise) and such low miles. Somebody took care of her. Expand Yes it always been to Canada. The truck was bought in 1988 in Drummondville. I'm the 4th owner. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted September 18, 2019 Author Share Posted September 18, 2019 Still look good ! I'm now on instagram : jeep.comanche88 😁 Link to comment Share on other sites More sharing options...
89 MJ Posted September 18, 2019 Share Posted September 18, 2019 It does. Do you ever plan on making it 4x4? Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted September 18, 2019 Author Share Posted September 18, 2019 On 9/18/2019 at 2:31 AM, 89 MJ said: It does. Do you ever plan on making it 4x4? Expand Sometimes I think about making it 4x4. But I only use it on summer season and only to do some roadtrips. Maybee I'll do it when I want to camp in the wood. Link to comment Share on other sites More sharing options...
Pete M Posted October 17, 2019 Share Posted October 17, 2019 I did some gnarly things with my old truck when it was 2wd. the key is not going alone and having solid tow points front and rear. Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 5, 2020 Share Posted March 5, 2020 How did you install the middle two lights on your roll bar? Any close-up pictures of the mounting? Thanks. Link to comment Share on other sites More sharing options...
Gjeep Posted March 5, 2020 Share Posted March 5, 2020 Mopar had an add-on piece that gave you the option of running 4 lights across. My '89 MJ had it when i got it. It basically fit over the 2 original rollbar tabs. Mount 2 middle lights into the add-on piece and then mount the outer 2 lights and you're done. That's how it was done in Mopar aftermarket land. I think there's a pic of it in a Jeep accessory book 1990. Looks like this MJ owner mounted the middle lights differently. Link to comment Share on other sites More sharing options...
fiatslug87 Posted March 5, 2020 Share Posted March 5, 2020 Thanks G. Do you happen to have that accessory book and can send a pic? Or do your want to sell the one from your '89? I think it would be at home with it's original engine! I was thinking of cutting down a piece of angle iron or maybe flat stock to span the tabs. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted May 6, 2020 Author Share Posted May 6, 2020 On 3/5/2020 at 9:23 PM, fiatslug87 said: How did you install the middle two lights on your roll bar? Any close-up pictures of the mounting? Thanks. Expand I drilled two holes, then I intalled two threaded nuts inside the holes. Link to comment Share on other sites More sharing options...
jeep.comanche88 Posted May 6, 2020 Author Share Posted May 6, 2020 Quik update. I took the comanche out of winter storage early April. Engine oil change done, transmission oil change done and brake ajustement done. I also waxed it. Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 6, 2020 Share Posted May 6, 2020 That's a great looking truck! Link to comment Share on other sites More sharing options...
