Hi, I'm new to the club !
Here is my 88 Jeep Comanche Sportruck
Engine : 2.5L
Traction : 2x4
Odometer : 129 000 km (80 150 miles)
Paint : Original
Suspension : BDS (I don't know the high)
Tires : 31x10.50 15 inches
Original location : Quebec, Canada
Pictures below is when I bought it last summer.
On 5/30/2019 at 8:39 PM, Bmille24 said:
Two weeks later...
I put 1.5 inches wheels spacer on the rear and a 1 inch bloc to lift the rear.
Alignment and ready for summer.
:thinking: I'm wonder why did u put 1 inch block in rear to lift? From what i can see in pic ur leafspring under the axle so if u add 1 inch block that will lowered ur rear down. Do u really mean 1 inch longer shackle? :confused:
The paint and decals look excellent. Was this truck in Canada it’s whole life? It just looks so clean (body wise) and such low miles. Somebody took care of her.
I mean 1 inch longer shackle yes.
Yes it always been to Canada. The truck was bought in 1988 in Drummondville. I'm the 4th owner.
  • 3 months later...
14 hours ago, 89 MJ said:
It does. Do you ever plan on making it 4x4?
Sometimes I think about making it 4x4. But I only use it on summer season and only to do some roadtrips. Maybee I'll do it when I want to camp in the wood.
  • 5 weeks later...
I did some gnarly things with my old truck when it was 2wd. :D  the key is not going alone and having solid tow points front and rear. :L:
  • 4 months later...
Mopar had an add-on piece that gave you the option of running 4 lights across. My '89 MJ had it when i got it. It basically fit over the 2 original rollbar tabs. Mount 2 middle lights into the add-on piece and then mount the outer 2 lights and you're done. That's how it was done in Mopar aftermarket land. I think there's a pic of it in a Jeep accessory book 1990. Looks like this MJ owner mounted the middle lights differently.
Thanks G. Do you happen to have that accessory book and can send a pic?
Or do your want to sell the one from your '89? I think it would be at home with it's original engine!:brows:
I was thinking of cutting down a piece of angle iron or maybe flat stock to span the tabs.
  • 2 months later...
On 3/5/2020 at 4:23 PM, fiatslug87 said:
How did you install the middle two lights on your roll bar? Any close-up pictures of the mounting? Thanks.
I drilled two holes, then I intalled two threaded nuts inside the holes.
Quik update. I took the comanche out of winter storage early April. Engine oil change done, transmission oil change done and brake ajustement done. I also waxed it.
