Wounded_Fighter Posted May 14, 2019 Share Posted May 14, 2019 Is there a way to adjust the amount of fuel coming from the injectors? Like a way to shorten the burst of fuel? Link to comment Share on other sites More sharing options...
JMO413 Posted May 14, 2019 Share Posted May 14, 2019 No it's all controlled by the ecm Link to comment Share on other sites More sharing options...
cruiser54 Posted May 14, 2019 Share Posted May 14, 2019 What is your goal? Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted May 14, 2019 Author Share Posted May 14, 2019 Lower the amount used. Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 14, 2019 Share Posted May 14, 2019 39 minutes ago, Wounded_Fighter said: Lower the amount used. That's done with your right foot. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 14, 2019 Share Posted May 14, 2019 56 minutes ago, Wounded_Fighter said: Lower the amount used. Do you have an AF meter? Link to comment Share on other sites More sharing options...
WyoCherokee Posted May 14, 2019 Share Posted May 14, 2019 You can grab an adjustable Fuel Pressure Regulator. However, we must ask. What is your goal, symptoms, problem? If you are running rich, there are other items that will cause a rich condition in a Renix. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted May 14, 2019 Author Share Posted May 14, 2019 Goal is mpg. Logical thought was air/fuel mixture, add more air? So I threw more air into the system (bored throttlebody) she likes it, a lot, idles now at 1300ish? (No actual tachometer on truck) searched forum, found a few high idle topics. Grounds checked, c101 deleted already in past. Only difference for high (warm) idle is the throttlebody, ran normal before it. Still investigating and theorizing. I need to buy a REM too. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted May 14, 2019 Author Share Posted May 14, 2019 1 hour ago, fiatslug87 said: That's done with your right foot. But my right foot loves the floor. Link to comment Share on other sites More sharing options...
Ωhm Posted May 14, 2019 Share Posted May 14, 2019 More air, more fuel. O2S will always attempt to maintain a 14.7:1 air/fuel ratio, within its range of authority, otherwise ECU goes into open loop. High idle is vacuum leak or TPS adjustment. Link to comment Share on other sites More sharing options...
omega_rugal Posted May 15, 2019 Share Posted May 15, 2019 on a 4.0? sorry they are gas guzzlers go propane like i did... Link to comment Share on other sites More sharing options...
Eagle Posted May 15, 2019 Share Posted May 15, 2019 Adjustable MAP sensor. Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted May 15, 2019 Author Share Posted May 15, 2019 11 hours ago, Jeep Driver said: Do you have an AF meter? AF meter? Probably not. 52 minutes ago, omega_rugal said: on a 4.0? sorry they are gas guzzlers go propane like i did... Yes,... propane? How do you measure mpg or rather mpt (tank)? Worth it? @cruiser54I'm not sure how adjustments are made on the tps? Do I just wiggle it around and screw it in and pray, if it's off do it again? Edit, while measuring with the probes. Link to comment Share on other sites More sharing options...
omega_rugal Posted May 15, 2019 Share Posted May 15, 2019 my MJ on propane gives round 20-22 mpg on the highway, some less in the city, but propane is 40% cheaper, so you must take that into account the 4.0 is rated at 17 mpg when running on gasoline so i´m not doing bad you also save a lot in oil changes, i have not changed the oil in 2 f***ing years and still looks clean, i´m changing it the next weekend because the additives are probably long gone but 2 years? that´s like 5 or 6 oil changes if it was running on gas, all that money can go into propane instead... of course some sacrifices should be made, i´m running on the lean side most of the time, running at no more 2000 rpms, after that it starts losing power, but when it comes to torque i didn´t notice any change, even fully loaded it doesn´t sweat as long as i keep it in the 1600-1800 rpm range unless you install and tweak your lpg system yourself you´ll end up spending more, most lpg mechanics give the engine too much propane to mimic the response as if was running on gas Link to comment Share on other sites More sharing options...
13 Legion Posted May 15, 2019 Share Posted May 15, 2019 8 hours ago, omega_rugal said: you also save a lot in oil changes, i have not changed the oil in 2 f***ing years and still looks clean, i´m changing it the next weekend because the additives are probably long gone but I’m not following how running on propane means you have to change your oil less? There is still wear and tear( friction) happening while you are driving. I realize some oils are advertised as better or there are synthetics....am I missing something here? Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 15, 2019 Share Posted May 15, 2019 11 minutes ago, 13 Legion said: I’m not following how running on propane means you have to change your oil less? There is still wear and tear( friction) happening while you are driving. I realize some oils are advertised as better or there are synthetics....am I missing something here? Propane is a cleaner burn, less cylinder wash or fuel wash. Blowby allows unburned gasoline to inter the crankcase and contaminate the oil over time. No, not a fan of propane but whatever..... Link to comment Share on other sites More sharing options...
cruiser54 Posted May 15, 2019 Share Posted May 15, 2019 Propane enters the engine as a vapor, not a liquid. Link to comment Share on other sites More sharing options...
cruiser54 Posted May 15, 2019 Share Posted May 15, 2019 12 hours ago, Eagle said: Adjustable MAP sensor. This. And then you can lean burn your engine, get a new one, and not have saved a dime. Link to comment Share on other sites More sharing options...
omega_rugal Posted May 15, 2019 Share Posted May 15, 2019 10 hours ago, 13 Legion said: I’m not following how running on propane means you have to change your oil less? There is still wear and tear( friction) happening while you are driving. I realize some oils are advertised as better or there are synthetics....am I missing something here? gasoline burns dirty, leavesa alot of carbon residue and acids... my old ZJ turned the oil into tar in less than a week after everychange... i[ll show the oil when i[m doen changin it Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted May 16, 2019 Author Share Posted May 16, 2019 Current idle when warm.. approx 10mins of driving. Link to comment Share on other sites More sharing options...
Ωhm Posted May 16, 2019 Share Posted May 16, 2019 Sound too high. Link to comment Share on other sites More sharing options...
Ωhm Posted May 16, 2019 Share Posted May 16, 2019 Check Throttle Body Butterfly Adjustment using Cruiser tip #14. http://cruiser54.com/ Link to comment Share on other sites More sharing options...
benjy_26 Posted May 16, 2019 Share Posted May 16, 2019 Don't Jeep 6's run lean enough to eventually crack the exhaust manifolds? Link to comment Share on other sites More sharing options...
Ωhm Posted May 17, 2019 Share Posted May 17, 2019 8 hours ago, benjy_26 said: Don't Jeep 6's run lean enough to eventually crack the exhaust manifolds? Not in a Closed Loop condition. If vehicle ECU goes Open Loop, no one knows then (Rich or Lean). Link to comment Share on other sites More sharing options...
Wounded_Fighter Posted May 19, 2019 Author Share Posted May 19, 2019 So, I adjusted the idle air bleed screw...... (dumb me didn't know that was a thing) So far sitting in the driveway it sounds a lot better. And since I replaced the guage cluster and now have a tachometer! I can say prior it was idling arou d 1300rpm. Now its 700-900rpm in driveway. Once it goes down the road a bit it sits happy at 1k. Have to take it down some high speed still to see if I run that hesitation idle bit again like it was in the video. Link to comment Share on other sites More sharing options...
