Myles Cyncora Posted July 24, 2018 Share Posted July 24, 2018 Hey I'm new to this forum. I have a 1987 Jeep Comanche 2.5l and my battery gets way hotter then it should after driving 4 kms and the truck dies. Can anyone give me ideas on what's causing this and how to fix it. Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 24, 2018 Share Posted July 24, 2018 Got a voltage gauge? Or multimeter? What's it charging at? Does it restart? Or do you have to charge the battery first? Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 24, 2018 Author Share Posted July 24, 2018 Yeah I have a voltage gauge in the truck it reads about 13 or 14 volts until the truck dies obviously. I don't have a multimeter. Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 24, 2018 Share Posted July 24, 2018 Does it restart immediately after it dies? Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 24, 2018 Author Share Posted July 24, 2018 Sometimes yes. But the odd time it needs a boost or the battery charged. But the truck takes forever to start every single time if that changes anything. Quote Link to comment Share on other sites More sharing options...
Ωhm Posted July 24, 2018 Share Posted July 24, 2018 If its a new battery, may be faulty. Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 24, 2018 Author Share Posted July 24, 2018 The battery is now 4 years old and was taken out of the truck for the winters but always under a roof either in the house or in the cab of the truck. Quote Link to comment Share on other sites More sharing options...
omega_rugal Posted July 24, 2018 Share Posted July 24, 2018 bad battery Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 24, 2018 Author Share Posted July 24, 2018 You sure? I don't want to spend whatever it is to get a bettery and have it not be the battery. Quote Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 24, 2018 Share Posted July 24, 2018 Sounds like you're in Canada. Take the battery somewhere and get it load tested. Most battery resellers will do it for free. Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 24, 2018 Author Share Posted July 24, 2018 Yeah man Canadian born and raised! Quote Link to comment Share on other sites More sharing options...
Ωhm Posted July 24, 2018 Share Posted July 24, 2018 Welcome to the CC Forum. Quote Link to comment Share on other sites More sharing options...
omega_rugal Posted July 24, 2018 Share Posted July 24, 2018 15 hours ago, Myles Cyncora said: You sure? I don't want to spend whatever it is to get a bettery and have it not be the battery. a battery usually overheats when too much voltage is sent to it OR when 2 or more cells have a shortcircuit btw don´t use it again until you test it or it will blow up and relase acid and toxic fumes everywhere... Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 24, 2018 Author Share Posted July 24, 2018 Thanks man. I'm going to need as much help as I can get with this little truck but I love it Quote Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 24, 2018 Share Posted July 24, 2018 I'm betting on a sulfated cell or two since it's removed from the vehicle every winter, plus it's four years old. Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 24, 2018 Author Share Posted July 24, 2018 Ok thanks. I'll take the battery out as soon as I can. Quote Link to comment Share on other sites More sharing options...
Eagle Posted July 24, 2018 Share Posted July 24, 2018 THe voltmeter isn't telling you battery voltage when the truck is running anyway, it's telling you how much voltage the alternator is putting out. Around 13-1/2 volts is correct, but if it's trying to push 13-1/2 volts into a battery with an internal fault, that's why it's overheating. In theory you should be able to disconnect the battery after staring the engine and drive it all day. I found this out the hard way when I first attempted to install a kill switch in my race car. I thought I had it all figured out. Installed the box and switch where it was easily accessible when strapped in with a four point racing harness, connected all the wires, fired up the engine and hit the kill switch. It was night time, since I worked during the days, so I had the lights on. All that happened was that the engine kept running, but the headlights got brighter. All I had done was to remove the battery from the circuit, so the full output from the alternator was being fed to the lights without the damping effect of the battery in the circuit. Back to the drawing board. I got it figured out, finally, but I learned something that day (night). Quote Link to comment Share on other sites More sharing options...
Gene Posted July 24, 2018 Share Posted July 24, 2018 Hi Myles, You really, really, really need a voltmeter. You can get a cheap one for about $10. The voltmeter on the dash is notoriously unreliable. I agree with everyone so far, most likely this is a bad battery. I think the strategy of pulling it and taking it to be checked make sense. However, what does not make sense is that your vehicle dies. As Eagle pointed out, a bad battery, by itself, would not cause the vehicle to die. So there may be two separate things going on. I think it's possible that the vehicle is overcharging, and that the dash gauge is not registering properly. This could kill the battery, hence two problems. Voltage of a fully charged battery, engine off, should be around 12.8 V, give or take. When the vehicle is running, and the alternator is putting out electricity, the reading should be around 13.8 V. Please let us know how this turns out! Gene Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 24, 2018 Share Posted July 24, 2018 I'm with Gene. Get a real multimeter on it before jumping to conclusions. It does sound like a bad battery, but easily could be overcharging. Quote Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 24, 2018 Share Posted July 24, 2018 It IS a bad battery. But yeah, it's a slow night. Quote Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 24, 2018 Share Posted July 24, 2018 49 minutes ago, HOrnbrod said: It IS a bad battery. But yeah, it's a slow night. I agree his battery has coded. But I don't want to say "Throw a new one in" without determining that it is charging correctly first... But that's just me. Auto parts stores here don't typically offer to test your dead battery or charging system when you go in to get a new battery. My volt meter often reads 2V low, and that's typical on crusty old clusters and wires, throw 16.5V at a new battery for a while and it'll be as dead as his current one is. Storing batteries in decent conditions while charged does not cause them to die a terribly early death, and 4 years is a terribly early death. That said, we don't know how he charged it or abused it otherwise. Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 24, 2018 Author Share Posted July 24, 2018 Thanks guys. I greatly appreciate all the help but I am 45 minutes away from the truck right now but I will keep looking at this site everyday. Quote Link to comment Share on other sites More sharing options...
gogmorgo Posted July 24, 2018 Share Posted July 24, 2018 Whereabouts are ya? I'm guessing east somewhere cause 45mins is nothing anywhere I've lived, haha. I did an alternator in a Powerstroke a few weeks ago, but the new one came with a bad regulator. It put out reasonable voltage still (~13.5) but overcharged one of the batteries to the point it boiled. Strangely only the one of the two got overcharged, the other one stayed steady at 12.6V. Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 25, 2018 Author Share Posted July 25, 2018 I'm in Manitoba. I just got a new battery today. My buddy, where the truck is sitting, is going to put it in and give me an update. Quote Link to comment Share on other sites More sharing options...
Myles Cyncora Posted July 25, 2018 Author Share Posted July 25, 2018 So he put the battery in and the negative cable connector melted as he started it. Would that be a bad ground? Quote Link to comment Share on other sites More sharing options...
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
