neohic Posted May 10, 2020 Share Posted May 10, 2020 Beautiful! Do you have a part number for the sockets? Link to comment Share on other sites More sharing options...
Gjeep Posted May 11, 2020 Author Share Posted May 11, 2020 It depends what kind of condition your current sockets are in...AC Delco# LS7 if you need the entire socket and it's about $25 per socket. Gray in color like OEM. https://www.carid.com/acdelco/gm-original-equipment-side-marker-lamp-socket-mpn-ls7.html?view=236082&gclid=EAIaIQobChMI0NeB8vup6QIVTOztCh3c8g5jEAQYAiABEgIV3fD_BwE Or if you just need the backing, the less expensive way to go is through Wiring Depot. Their socket# 2583F is cream/ yellow color, but only $7 per socket. https://www.wiringdepot.com/store/p/494-JT-T-2583F-3-Wire-GM-Chrysler-AMC-90-Double-Contact-Back-Up-Stop-Tail-Turn-Light-Socket-Pigtail-1977-Newer-1-Pc.aspx Removing the terminals of your current MJ sockets are easy to remove and pop into a new connector. Link to comment Share on other sites More sharing options...
Gjeep Posted May 13, 2020 Author Share Posted May 13, 2020 My 6.5" Rockford woofers came today...they're about 2.5" deep and heavy as the 8" sub going in my '97 XJ. Looks like I'm going to need to rethink my subwoofer area. Either going to build a MJ specific fit-to-the-backwall enclosure and/or adapt the first gen XJ separate sound bar to hold those speakers, as that sound bar is plenty deep (unlike the '99+ XJ integrated sound bar). A little project to get to. Link to comment Share on other sites More sharing options...
Gjeep Posted May 13, 2020 Author Share Posted May 13, 2020 Also been freshening the fuel tank with new hoses, clamps, and roll-over safety valves. I was surprised to find both the seals on mine were cracked. Chances of fuel actually leaking out of these are slim, but while they are sill available from dealers I'm replacing both the seal and valve of both. Link to comment Share on other sites More sharing options...
Gjeep Posted May 15, 2020 Author Share Posted May 15, 2020 Chipping away and changing a few things as I go...Since I'm going to be running subs behind the seats now, I needed to go in yet again to the PDC and modify things so I could get 60W fused power to run the Rockford amplifier that will power these. With that, I need to bump the IPF relay harness power to just outside the PDC -- about where the cruise control servo cable attaches to the PDC/overflow reservoir bracket -- in a weatherproof fuse holder. Diagram and photo below. The Mega fuse holder for the 270A alternator now resides in front of the coolant jug for easy access (use to be in the mounting area of the DirtBound battery tray -- a nightmare to access). I also added a hose off the overflow so if coolant does flow out, it won't wet/damage any of the electric. With those changes engine-side, I was able to run the wiring inside and install the subwoofer amp opposite the main 4-speaker amplifier -- on the passenger side footwell panel. I needed to move around the power window relays and connector that powers the harness for the inner door passenger side to makes things work, and make sure the amp has enough breathing room. Eventually all loose wires will be organized here too... Link to comment Share on other sites More sharing options...
knever3 Posted May 16, 2020 Share Posted May 16, 2020 Very nice! I love seeing audio upgrades, that's my passion. Link to comment Share on other sites More sharing options...
Gjeep Posted May 16, 2020 Author Share Posted May 16, 2020 Thanks...I do what I can to make those sound system additions visually subtle. I want my enclosure set up to appear 'factory' Comanche somehow. Finally got the fuel, brake and breather lines in place. Came out nice and clean. I know most people do'n't notice chassis side, but I do. Nuts I know. And axle brake line attached. Link to comment Share on other sites More sharing options...
Red Mistress Posted May 16, 2020 Share Posted May 16, 2020 Top notch work as always. How is the amp behind kick panel going to breathe ? Maybe the latest generation of amps don't need as much fresh air as old style... I dunno. Link to comment Share on other sites More sharing options...
Gjeep Posted May 16, 2020 Author Share Posted May 16, 2020 Exactly. These amps need just under an inch breathing space all around to keep cool. Kick panel isn’t a fully enclosed area fortunately. Should be a-ok. Link to comment Share on other sites More sharing options...
Gjeep Posted May 21, 2020 Author Share Posted May 21, 2020 Plugging along finishing lots of details to the MJ's underside...Drilled a 1 3/8" access hole on either side of the frame so I can put a nut on all the bolts for the sway bar end link mounting bracket. Took my time measuring and all came out well. Once the brackets are mounted/ nuts in place I'll use these 'caplugs' to fill the holes. Mounted all hardware since chassis paint -- front and rear shocks, attached brake lines, bled system, etc. Link to comment Share on other sites More sharing options...
kansashogan Posted May 21, 2020 Share Posted May 21, 2020 Nice and clean. Link to comment Share on other sites More sharing options...
Gjeep Posted May 21, 2020 Author Share Posted May 21, 2020 Finishing up wires to the back of the MJ – 3rd brake light and interior light for camper shell. Also running optional 12V ignition-on cigarette lighter power for the bed. Did a masticated rubber cut-out for underside of the ‘X’ cross member for the tire contact. Cut, punched and push-pinned it into place. And finally, filled the taillight sockets with marine grade dielectric grease and snapped on the new backsides. Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 21, 2020 Share Posted May 21, 2020 Everything looks so clean. Where did you get the masticated rubber? Link to comment Share on other sites More sharing options...
Gjeep Posted May 21, 2020 Author Share Posted May 21, 2020 eBay...I have rolls and rolls of it. This is the guy I buy it from -- located in Santa Ana, CA https://www.ebay.com/itm/1936-1958-Pontiac-thick-masticated-rubber-sheet-1-8-C70064545/333580344687?fits=Year%3A1946|Make%3APontiac&hash=item4daaf01d6f:g:qjkAAOSwTglYmXFB Link to comment Share on other sites More sharing options...
SiXJaK Posted May 21, 2020 Share Posted May 21, 2020 Wow, excellent work. Link to comment Share on other sites More sharing options...
Gjeep Posted May 22, 2020 Author Share Posted May 22, 2020 Lots of cleaning today -- everything from fuel tank hoses, breather lines to an '87 XJ black horn hub. 25+ Q-tip to get it done. I'll be touching up the plastic torx of the hub also. Also painting a ton of nuts and bolts for re-assembly when the time comes... Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 22, 2020 Share Posted May 22, 2020 Looks great, you're one PATIENT man! I drilled out the plastic torx heads, put in stainless torx bolts of a similar size and painted the centers black, I know it's not OEM, but I never have to worry about the silver rubbing off. Just a thought. Link to comment Share on other sites More sharing options...
Gjeep Posted May 22, 2020 Author Share Posted May 22, 2020 Yep, actually crossed my mind too...but I think will keep as is. For now. Link to comment Share on other sites More sharing options...
Gjeep Posted May 25, 2020 Author Share Posted May 25, 2020 Long ago I had wired back to the camper shell interior lighting that goes on with the trucks interior lights; additionally, I fit a first gen Dodge Dakota 3rd brake light just above the rear glass of the SnugTop's shell. Worked great. This round, just in case I go camper-shell-less, I've wired cargo light and 3rd brake light wiring to the back top of the shell. Since my factory rocker switch locations are all occupied with fog light, auxiliary fan override, and winch on/off & in/out controls -- I wired the cargo light with the interior lights also. I though about using a 70's GM foot actuated hi-beam switch, but decided against it. As for the actual cargo/3rd brake light I'm using...I've poured through all years/ manufacturers that existed. Settled on 2 that look MJ appropriate. First gen Dodge Ram full size (top photo) and second gen Ford Ranger (bottom photo). Since I'm waiting on them to arrive, I'll need to hold them up to the MJ to see which looks best. I'm leaning towards the Dodge as it is Chryco. I also dug up some NOS upholstery I got 15+ years ago...1987 YJ black "Jeep" logo's denim vinyl and XJ black vinyl. I had also purchased a few years back some aftermarket non-logo'd (because they can't logo it without Jeep's permission) black denim vinyl. The aftermarket denim vinyl is a blue black color (top right color) versus a brown black color as the NOS denim and denim vinyl is...so I'll be going with the logo'd upholstery. Now to decide on the stitch pattern of the winged bucket seats I'm going to use. I think I'm going to go with a stitch blend between the Laredo and the old Wagoneer XJ Limited. When I have some time I'll play with Photoshop. Link to comment Share on other sites More sharing options...
Gjeep Posted May 28, 2020 Author Share Posted May 28, 2020 Been cleaning, prepping, painting, and sorting parts... Also took delivery of a well packaged Spectra fuel tank. Finally! These are made in Canada and are quality reproduction units -- but I will say their shipping box was paper thin with no protection/ padding around the tank whatsoever. I had taken delivery and shipped back 3 tanks prior because they had been bent and dented in transit. I contacted Spectra directly, explained I was restoring a couple Comanche's, and they sent me 5 well packaged tanks to choose from. I ended up keeping 2. Way to go Customer Service -- really appreciated it! Here's one of them cleaned up... Link to comment Share on other sites More sharing options...
Gjeep Posted May 30, 2020 Author Share Posted May 30, 2020 As far as the third brake/ cargo light goes -- it's going to have to be the Ford Ranger set up. I unfortunately can't trim the '95 Dodge Ram set up far enough back topside to make it work on the MJ. The Ranger light looks good though. I bought two of them...one a Dorman I was going to practice on and then a NOS Ford unit to perfect. I decided to start cutting on the Ford light and I'm glad I did. 3 hours of some dremel-ing and a whole lot of measuring and hand filing got me to the final product below. When I first looked at the Ford unit, the internet photo must have been an aftermarket -- you can see the difference. The Dorman looks like something off of the Dukes of Hazzard sheriff's car (they must be double-dipping with the old Ranger and Super Duty on this light), while the Ford light is clear across the front with the backside red plastic not being in your face. Similar to the Ram light. I'm going to change the huge electrical connector to something that MJ parts-bin. Link to comment Share on other sites More sharing options...
Gjeep Posted June 1, 2020 Author Share Posted June 1, 2020 The latest project is aimed at clearing the back wall of the cab...I've never been a fan of the MJ's spare tire junk up against the back wall -- plus I'm adding a couple small woofers and I want tat back cab wall area to look clean -- so I spent some quality time at the local wrecking yard trying to see what OEM options were out there from any manufacturer. I settled on Ford's inner fender mount bottle jack bracket. I removed it from a 1994 full-size Bronco, but as you can imagine that bracket can also be found on the F-series of that same generation. A few cuts, bends, and grinds got me to the final product below. I'm mounting it on the driver's side inner fender up high. My truck's a '92 and in that year the wash/wipe reservoir is on the passenger side above the blower motor. For those interested in this set up just use the '97+ XJ inner fender reservoir to get that item out of the way. As for the jack 'crank' arm, that's going on the passenger side with the 'Y' portion tucking near the inner fender side of the battery tray and the other end inner fender towards the firewall.. Again, I scoured the wrecking yard I was at to find some thing to clip that 'crank' to...and found that the '97 Ford F-150/ Expedition has 2 clips to either side of the radiator that worked near perfectly. I had to trim one and open up the clip portion to accept the MJ's crank as it was a slightly wider diameter over the Ford's. One clip I'm positioning near the battery tray and the other mid-inner fender up high. (Note: these clips are upside down in this pic.) Currently paint is drying but once I have everything mounted up I'll post a few pics...Also, the lug wrench I'll be using will be a telescoping Gorilla wrench that will reside under the passenger seat. Link to comment Share on other sites More sharing options...
Gjeep Posted June 3, 2020 Author Share Posted June 3, 2020 Some pics of the installed under the hood MJ spare tire tools...Remember there's a few modifications to my MJ's engine compartment that make this set up a little easier. I have relocated the washer bottle tank under the front fender ('97+ XJ), master cylinder brake lines were redone by me, and I added a '91 XJ ABS controller tray passenger side to mount the Warn winch solenoid. This setup can be done without some of these mods but I think they contributed to the ease of installation. And again my reason moved these items under the hood is for a clean back of cab area so I can set up a simple sub enclosure somewhat true to the MJ era interior. The passenger side crank stays in place thanks to two Ford first-gen Expedition retaining clips -- one mounted mid-inner fender and the other to the side of the battery tray (note: I'm running a Dirt Bound battery tray). I padded the Warn solenoid tray where it comes in contact with the crank so there is no vibrations/sounds coming from it. Driver's side has the slightly modified Bronco/F-150 bottle jack bracket...It's positioned so the retaining arm clears the master cylinder brake lines. Padding was also applied to both the back of the jack and the retainer so it would not vibrate/make sounds as the truck rides along. Finally on my quest of installing a new fuel tank, straps, etc...I was looking for new Comanche J-bolts which are not an easy find. I had read on this site that Freightliner battery tray hold-downs worked, so I ordered them. Not sure how they worked for that MJ owner because there was way to long a stretch of this bolt that was un-threaded. Just wouldn't work. The Spectra fuel tank straps came with new J-bolts but they were way to long and I'd be wrenching forever on that nut before it seated. They were Cherokee J-bolts...Close, but not quite right. Many an internet search finally brought me to Mopar 60's-70's muscle car era J-bolts -- the proper length, though a pinch smaller in diameter (standard versus MJ metric). Here's how they line up to my factory MJ J-bolts. Both of my original bolts are bent...the one not shown bent the worst. (Non-Mopar bolts are also available and are not green in color, but these are the one's I got...J-bolts). Link to comment Share on other sites More sharing options...
Gjeep Posted June 3, 2020 Author Share Posted June 3, 2020 Bouncing between projects as it is hot as hell here...I just took delivery of a clear finely textured tape that I will use as an overlay of my custom switch pod labels. The photo doesn't do the texture justice -- it's an exact match to the MJ/ XJ switch pod texture. Believe me, I went through quite a few to find the exact match. I found this product online at www.noskidding.com. The item# is NS4006C -- which is a 6"x60" roll of tape. For the lighting, I have purchased a light blue semi-transparent tape I can place over the backside white of my label or I have purchased blue light bulb covers for the small bulbs that illuminate the icon of the switch (similar to the XJ/ MJ gauge cluster bulbs). I think this should work best, with the blue tape as a fall-back. Link to comment Share on other sites More sharing options...
neohic Posted June 4, 2020 Share Posted June 4, 2020 I absolutely enjoy watching your attention to detail. How many of us would’ve thought to move the jack to under the hood with such beautiful execution? Tip of the cap, sir. Link to comment Share on other sites More sharing options...
