Swampy Posted April 20, 2018 Posted April 20, 2018 Hey guys I was wrenching on the jepp today and nothing good happened. The plan was to go in and remove the oil pressure light switch in favor of the oil pressure sending unit I have for the gauge to read properly. As I was trying to take the old one out *SNAP* the 90° brass fitting snapped at the block. I am trying to figure out what to do. I have tried an extractor bit but the drill doesnt fit the the space and the engine mount is in the way. I will post up pics soon
DirtyComanche Posted April 20, 2018 Posted April 20, 2018 Take the engine mount off for access? Pound in a pipe extractor and turn it with a wrench?
Swampy Posted April 20, 2018 Author Posted April 20, 2018 3 hours ago, DirtyComanche said: Take the engine mount off for access? Pound in a pipe extractor and turn it with a wrench? These are some ideas I will look into tomorrow
DirtyComanche Posted April 20, 2018 Posted April 20, 2018 It looks thin enough you might be able to collapse an edge of it with a punch, then turn it out with a pair of pliers.
Swampy Posted April 20, 2018 Author Posted April 20, 2018 11 hours ago, DirtyComanche said: It looks thin enough you might be able to collapse an edge of it with a punch, then turn it out with a pair of pliers. I tried this to no avail. Maybe I'm not doing it right but I'm going to keep trying
HOrnbrod Posted April 20, 2018 Posted April 20, 2018 21 minutes ago, Swampy said: I tried this to no avail. Maybe I'm not doing it right but I'm going to keep trying The brass wall looks so thin it looks like you probably could run a tap in providing there's enough room to get a greased up short-length tap started. The thread would either 1/8 or 1/4 NPT; same size as the oil pressure sensor. Pipe thread taps are tapered so it should be easy to start.
Swampy Posted April 20, 2018 Author Posted April 20, 2018 28 minutes ago, HOrnbrod said: The brass wall looks so thin it looks like you probably could run a tap in providing there's enough room to get a greased up short-length tap started. The thread would either 1/8 or 1/4 NPT; same size as the oil pressure sensor. Pipe thread taps are tapered so it should be easy to start. I have taps and an excrator bit. They will go into the hole but I can't get a wrench, drill etc behind it because the motor mount is in the way. And I don't know how I would move that mount out of the way
rokinn Posted April 20, 2018 Posted April 20, 2018 Can you get a ratcheting box end wrench on the tap and just re-tap the hole threads? Or extractor, may work, but I've never had much luck extracting rusted broken parts. You could put a die on the new part to know what size the threads are! Just a thought, worth a shot, maybe?
HOrnbrod Posted April 20, 2018 Posted April 20, 2018 Yeah, bummer. Maybe unbolt the engine mounts and raise or lower the engine w. a jack & block of wood under the pan enough to clear?
DirtyComanche Posted April 20, 2018 Posted April 20, 2018 14 minutes ago, Swampy said: I have taps and an excrator bit. They will go into the hole but I can't get a wrench, drill etc behind it because the motor mount is in the way. And I don't know how I would move that mount out of the way Support the engine with a floor jack and pull the mount out piece by piece. The pipe nipple extractors are low profile and you should just be able to pound one in and put a wrench on it. Alternatively Snap-On sells some small extractors for not too much, Google search REX114A for an example.
DesertRat1991 Posted April 20, 2018 Posted April 20, 2018 The temperature sensor on top of the engine near the firewall is brass and hollow as well. I accidentally snapped it off and was pretty much left with your situation in the picture below. I was able to tap a short allen wrench into the hollow shell and the hex points were able to get enough bite in the brass to spin out what was left. Good luck.
HOrnbrod Posted April 20, 2018 Posted April 20, 2018 Not that it helps you Swampy, but the HO engines have the oil pressure sensor mounted on the oil filter adapter; real easy to get to. Sometimes I think the Renix design engineers were a bunch of sadists.
DirtyComanche Posted April 20, 2018 Posted April 20, 2018 2 minutes ago, HOrnbrod said: Not that it helps you Swampy, but the HO engines have the oil pressure sensor mounted on the oil filter adapter; real easy to get to. Sometimes I think the Renix design engineers were a bunch of sadists. He has a 2.5L. The Renix 4.0L has it in the same place as the HO.
HOrnbrod Posted April 20, 2018 Posted April 20, 2018 2 minutes ago, DirtyComanche said: He has a 2.5L. The Renix 4.0L has it in the same place as the HO. Roger. How 'bout the newer 2.5L location?
DirtyComanche Posted April 20, 2018 Posted April 20, 2018 2 minutes ago, HOrnbrod said: Roger. How 'bout the newer 2.5L location? I have no idea. I honestly believe I've never seen a post-Renix 2.5L in person.
Pete M Posted April 20, 2018 Posted April 20, 2018 7 minutes ago, HOrnbrod said: Not that it helps you Swampy, but the HO engines have the oil pressure sensor mounted on the oil filter adapter; real easy to get to. Sometimes I think the Renix design engineers were a bunch of sadists. when I invent that time machine I'll go back and remind then that just because it came out when new, doesn't mean that it'll do the same 30 years later. I'll also suggest some key stainless steel items. and coating the floor. and some extra paint in the bedsides. and...
sinkrun Posted April 20, 2018 Posted April 20, 2018 Are you using a old style long easyout/extractor? Snap on and mac have short ones around 1 inch maybe shorter easy outs that should do the trick. I can dig mine out and get you A pic if I can find them.
mjeff87 Posted April 20, 2018 Posted April 20, 2018 Long time ago I snapped off the MAT sensor flush with the intake manifold on my 2.5, much in the same way as your OPS there. I ended up using a set of flat fluted extractors to get the remnants out. I just pounded one into the remains and it spun right out using a small crescent wrench on the end of the extractor. You might try one of those if all else fails. Jeff edit: like these.....https://shop.tifco.com/Catalog/id/11836
Swampy Posted April 20, 2018 Author Posted April 20, 2018 1 hour ago, HOrnbrod said: Not that it helps you Swampy, but the HO engines have the oil pressure sensor mounted on the oil filter adapter; real easy to get to. Sometimes I think the Renix design engineers were a bunch of sadists. Yeah I feel like they were
omega_rugal Posted April 20, 2018 Posted April 20, 2018 i would use a thin saw to carefully cut it from inside, the use needle pliers to extract it...
Jeep Driver Posted April 20, 2018 Posted April 20, 2018 This is a oil passageway, anything but an extractor is asking for trouble. NAPA sells a decent 4pc extractor set for about $15, it's good.
Swampy Posted April 21, 2018 Author Posted April 21, 2018 So this is where I am at right now. I went to homedepot and bought the pipe nipple extractor set because they are shorter than the extractor I had. And I bought a new fitting being optimistic. But still no dice, the extractor set is perfect if I had enough room to hit it with my little hammer. So back to square one. I also tried to take the engine mount off but my ac compressor is in the way. Just in case people need part numbers (optimism) The brass fitting And some humor for my pain
Swampy Posted April 21, 2018 Author Posted April 21, 2018 Its frustrating because I can't get it out and I feel like I have tried everything
outlaw star Posted April 21, 2018 Posted April 21, 2018 Its frustrating because I can't get it out and I feel like I have tried everything Have you asked Walt for help? He's as handy as me with that stuff..Sent from my SM-J700P using Tapatalk
