Jaime Posted October 15, 2017 Posted October 15, 2017 Hello, My speedometer cable broke, well the plastic tip that goes on the end. I have tried Auto Zone, O'Reilly's, Napa, and Car Quest. They all, except O'Reilly's, have the one that screws on both ends. O'Reilly's can't bring up a picture and when I did a search here somebody said that it was the wrong one. It was also mentioned that they lost the shipping cost. I also tried the build your own cable but the tip is too small and just spins in the speedometer hole. Can anyone point me in the right direction part number, brand, who to purchase it from etc.. Thank you.
IronManche87 Posted October 15, 2017 Posted October 15, 2017 What year? Cruise control? Lwb or short? Sent from my LGMS210 using Tapatalk
IronManche87 Posted October 15, 2017 Posted October 15, 2017 I got mine from oreillys for my 87 auto 2wd lwb PN# CA3116. Has that little plastic tab/hook that clips into Speedo correct?Sent from my LGMS210 using Tapatalk
Jaime Posted October 15, 2017 Author Posted October 15, 2017 It's an 88,4,0, lwb, 5 speed, not cruise control.
IronManche87 Posted October 15, 2017 Posted October 15, 2017 It's an 88,4,0, lwb, 5 speed, not cruise control. Happen to have a pic of the cluster side? Can almost guarantee it's the Pioneer ca3116. I ordered the other ca3068 and it was the one that's screws. It should be special order but available from oreillys I think like 30-something plus shipping. Not sure how much it was without my discount lolSent from my LGMS210 using Tapatalk
Jaime Posted October 15, 2017 Author Posted October 15, 2017 Here they are. I just don't want pay for something and it not be the correct one.
cruiser54 Posted October 16, 2017 Posted October 16, 2017 There's a wrangler one that works also. Let us know if the Pioneer one works so we can note it.
Jaime Posted October 17, 2017 Author Posted October 17, 2017 Will do. I went to Auto Zone and ordered pioneer #ca3068. It won't come in until later this week. I'll let you know.
SVPete Posted October 17, 2017 Posted October 17, 2017 34 minutes ago, Jaime said: Will do. I went to Auto Zone and ordered pioneer #ca3068. It won't come in until later this week. I'll let you know. What timing....I've been looking/researching for clarity on this too. I was going to order the same cable, CA-3068, from Summit Racing tonight. Please report back whether it is correct.
IronManche87 Posted October 17, 2017 Posted October 17, 2017 Not a great pic I can get a better one tomorrow but this is the 3068 I still have it laying around cuz it was special order and ended up being the 3116. I can pop my cluster out on lunch tomorrow and grab pics of the 3116 and grab pics of the 3068 after work.Sent from my LGMS210 using Tapatalk
IronManche87 Posted October 17, 2017 Posted October 17, 2017 However mine looked different from yours if I am correct but you also said you snapped the tab correct? Mine has a tab which locks onto a bevel on the cluster to lock. Sent from my LGMS210 using Tapatalk
mjeff87 Posted October 17, 2017 Posted October 17, 2017 Just an interesting tidbit......look at the screwheads on the face of the speedo. They will either be slotted or Phillips. The slotted screwhead speedo takes the plastic clip cable end, and the Phillips takes the metal one. Or visa-versa....it's been awhile and I'm going off my (failing) memory
Kyleinreallife Posted October 17, 2017 Posted October 17, 2017 Just an interesting tidbit......look at the screwheads on the face of the speedo. They will either be slotted or Phillips. The slotted screwhead speedo takes the plastic clip cable end, and the Phillips takes the metal one. Or visa-versa....it's been awhile and I'm going off my (failing) memory Non sequitur: Jeff, I'm working on a 87 2.5 base to 4.0 swap. Currently searching for the right donor xj (95? Or opinions appreciated) I had been looking at your swap write up which has been the best source of info I've found so far. However, the pictures broke thanks to photobucket, has there or will there be a remedy? Sent from my iPhone using Tapatalk
mjeff87 Posted October 17, 2017 Posted October 17, 2017 I PM'd you back (albeit very late.....). I'm done with PB, screwem. I still have some of the pics on my home PC.....shoot me a pm if yer looking for something specific. Email me at mjeff87@comcast.net too. edit: I stayed all renix with my swap....I went from 87-2.5 to 89-4.0 so I didn't change management systems. It's simpler that way. If you want to go OBDII (or later), I can't really comment
SVPete Posted October 18, 2017 Posted October 18, 2017 18 hours ago, IronManche87 said: Not a great pic I can get a better one tomorrow but this is the 3068 I still have it laying around cuz it was special order and ended up being the 3116. I can pop my cluster out on lunch tomorrow and grab pics of the 3116 and grab pics of the 3068 after work. Sent from my LGMS210 using Tapatalk If I understand your post above correctly, the cable you are holding is CA-3068, which has the plastic connector on the speedometer end.
IronManche87 Posted October 18, 2017 Posted October 18, 2017 If I understand your post above correctly, the cable you are holding is CA-3068, which has the plastic connector on the speedometer end. Correct. But the 3116 also has the plastic end but a tab that clips into a groove on the speedoSent from my LGMS210 using Tapatalk
SVPete Posted October 18, 2017 Posted October 18, 2017 I am more confused now. Edit: saw some pictures of the CA-3116, I'm pretty sure that is NOT what I have.
carnuck Posted October 18, 2017 Posted October 18, 2017 When XJS went to HO in ‘91, speedometer cables went away by ‘92. YJs in ‘91 only had a pass through sensor that could be adapted for speedo cable as well as the trans controller for the AW4 or electronic speedometer. Sent from my iPhone using Tapatalk
cruiser54 Posted October 18, 2017 Posted October 18, 2017 1 hour ago, carnuck said: When XJS went to HO in ‘91, speedometer cables went away by ‘92. YJs in ‘91 only had a pass through sensor that could be adapted for speedo cable as well as the trans controller for the AW4 or electronic speedometer. Sent from my iPhone using Tapatalk In 1991, XJ speedo cables went away. Here's the Wrangler cable I use on my MJs and XJs without cruise control. A little long but works well and has the white plastic clip at the speedo. https://www.morris4x4center.com/speedometer-cable-53005084.html
Rockfrog Posted October 21, 2017 Posted October 21, 2017 In 1991, XJ speedo cables went away. Here's the Wrangler cable I use on my MJs and XJs without cruise control. A little long but works well and has the white plastic clip at the speedo. https://www.morris4x4center.com/speedometer-cable-53005084.html Yeah, but the 91-early 92 were an adapted VSS, it screwed onto the same speedo cable drive base as the earlier ones used. It also had a direct wire line to the speedo. The late 92 up were Th one piece VSS and the signal passed through the ECM before being directed to the speedo.One of my pet projects is using the early VSS as a base for a wired speedo conversion (along with an HO fuel sender swap one day after). Sent from my SM-G930W8 using Tapatalk
HOrnbrod Posted October 21, 2017 Posted October 21, 2017 21 hours ago, Rockfrog said: One of my pet projects is using the early VSS as a base for a wired speedo conversion......... You would have to run a separate harness for the VSS signal, 12V, and ground, and figure out how to mount the HO speedo in the Renix case that would look right. That would be a real good mod for the Renix people.
cruiser54 Posted October 21, 2017 Posted October 21, 2017 26 minutes ago, Rockfrog said: Yeah, but the 91-early 92 were an adapted VSS, it screwed onto the same speedo cable drive base as the earlier ones used. It also had a direct wire line to the speedo. The late 92 up were Th one piece VSS and the signal passed through the ECM before being directed to the speedo. One of my pet projects is using the early VSS as a base for a wired speedo conversion (along with an HO fuel sender swap one day after). Sent from my SM-G930W8 using Tapatalk I guess I don't see your point. the cable I referred to works on 88 to 90 XJs and MJs.
87MJTIM Posted October 22, 2017 Posted October 22, 2017 Following this thread. My truck has cruise control and I have trouble with the cable. I was considering eliminating the cruise control. I look at Napa for a cable. The online store showed the cable for cruise. I thought the cruise control cables were NLA. I was wrong! Napa part #615-1604 (can’t attach photo) figured it out
Jaime Posted October 22, 2017 Author Posted October 22, 2017 Well I got the cable and installed it. I think my speedometer may also be bad. The speedometer works but the needle bounces a bit then settles down and doesn't bounce as much. The cable is 20" longer than the original and does not have the plastic tip. It is square cable just like the other end. The best that I could tell it is just the slightest bit smaller than the plastic tip which is why I installed it. I can only load 1 picture at a time so I'll have to send the other pictures one at a time.
