wheelsaz08 Posted January 6, 2017 Author Share Posted January 6, 2017 steering, suspension, and brakes are now complete. I'm going to keep the long hoses for now, maybe ill get shorter ones if these become a problem. i will get a solid mounting bracket for them at the frame end vs the temporary zip ties. xj brake booster installed, MC bled, rear brake lines made (pass side is ugly cause i literally had JUST enough tubing to make it) need to finish bleeding the rest of the brakes. i got new fine thread bolts for everything suspension/steering related, just need to finish swapping them out with the mock up hardware. i made the drag link a tad short and don't like how much of the rod end shafts are exposed so i got new inserts and a piece of 1.5x.25 dom to make a new one other than that all i have left to do is the floor pan(s), seats, and rear driveshaft. pretty bummed i didnt get this done before new years, but ive been busy. new "deadline" is the 21st of this month. we are going camping in the desert for my girlsfriends bday and it would make for a great shakedown here's some random pics Link to comment Share on other sites More sharing options...
wheelsaz08 Posted January 9, 2017 Author Share Posted January 9, 2017 got a little bit more done. picked up a set of mj buckets with brackets for $75! they are dirty but the brackets are rust free minus some surface rust. also got the main section of the floor pan welded in. hopefully get the rest of the floor/tunnel done after work this week Link to comment Share on other sites More sharing options...
wheelsaz08 Posted January 16, 2017 Author Share Posted January 16, 2017 Empty Post Link to comment Share on other sites More sharing options...
dragordie Posted January 16, 2017 Share Posted January 16, 2017 That's the only issue my MJ has is the drivers floor and most of the drivers side trans tunnel is rotted out. Are you going to stretch metal to form up the tunnel? or puzzle piece it? Nice steering set-up two thumbs up. Link to comment Share on other sites More sharing options...
wheelsaz08 Posted January 16, 2017 Author Share Posted January 16, 2017 thanks! ill probably just puzzle piece it together. i found a small chunk of 8-ish inch pipe in the dumpster at work so ill try to use that to shape it some. Link to comment Share on other sites More sharing options...
wheelsaz08 Posted January 25, 2017 Author Share Posted January 25, 2017 Empty Post Link to comment Share on other sites More sharing options...
DirtyComanche Posted January 25, 2017 Share Posted January 25, 2017 Looks good, glad to see it's out driving around. I rolled the edges of my cut fenders rather than using the trim material. It gave the fenders some rigidity back that way, otherwise they seem to flap in the breeze a bit. Link to comment Share on other sites More sharing options...
wheelsaz08 Posted January 28, 2017 Author Share Posted January 28, 2017 thanks! thats a good idea. i need to make supports for the bedsides, but the fronts are pretty rigid still Link to comment Share on other sites More sharing options...
Wiggilez Posted January 30, 2017 Share Posted January 30, 2017 I was going to ask what the weird shackle setup was, then I noticed it was a shopping cart. Link to comment Share on other sites More sharing options...
desbennett004 Posted January 30, 2017 Share Posted January 30, 2017 I was going to ask what the weird shackle setup was, then I noticed it was a shopping cart.Wheelie Bars. Really really short Wheelie bars. Sent from my SM-N900W8 using Tapatalk Link to comment Share on other sites More sharing options...
wheelsaz08 Posted January 31, 2017 Author Share Posted January 31, 2017 Empty Post Link to comment Share on other sites More sharing options...
wheelsaz08 Posted February 3, 2017 Author Share Posted February 3, 2017 Empty Post Link to comment Share on other sites More sharing options...
btipsword1 Posted February 4, 2017 Share Posted February 4, 2017 What's up with the paint over the JEEP logo on the tailgate? did I miss something in this thread? Link to comment Share on other sites More sharing options...
wheelsaz08 Posted February 4, 2017 Author Share Posted February 4, 2017 its not paint, its bare metal. i started stripping the house paint the PO had slapped on it, but never got around to finishing it Link to comment Share on other sites More sharing options...
wheelsaz08 Posted February 14, 2017 Author Share Posted February 14, 2017 Empty Post Link to comment Share on other sites More sharing options...
wheelsaz08 Posted February 25, 2017 Author Share Posted February 25, 2017 got another chance to take the manche out last weekend. before i left i built bumpstops. in the front I'm using the daystar extended bumps and 3 hockey pucks per side. the rear i got 4.5'' bumps and added a piece of 2x2x.25 square tube above them. didnt get finished pics but you get the idea. also did the h4 conversion with rampage housings and hella 80/100w bulbs, and a putco harness. I'm not at all impressed with the harness, and both hella bulbs burnt out in less than an hour... wheelin pics went to box canyon to meet a buddy but got there before him and decided to wheel around by myself for a while. found some awesome trails and did some great crawling. didnt get many cool pics cause i was having to much fun and then this happened... long story short, it was pouring rain and i couldnt see to well since my wipers don't work and apparently applying rainx in the RAIN doesnt work, i had no service and was heading back to an area where my hone would work so i could see where my buddy was, cam up to a small hill and i thought the road went over the hill, not to the left at the crest, tried everything i could to prevent it from rolling and it once i realized it was going over, i made sure it happened nice and easy. it was a very slow and controlled flop and the top passenger cab corner landed on a small pointed boulder which kept me from going all the way onto the roof. damage assessment: its not buffing out discovered a new use for my hi lift and like nothing ever happened lol the rear window broke when i tried to remove it, not from the roll Link to comment Share on other sites More sharing options...
wheelsaz08 Posted March 15, 2017 Author Share Posted March 15, 2017 picked up a 99 intake. bead blasted it, will be gasket matching and cleaning up the injector humps. hoping for some more low end torque out of the stroker. also the exhaust header (apn i think or knock off?) is cracked/rusted through somewhere... so since I'm pulling it all apart ill be building an entire 2.5" exhaust system. goal is to get all that done by mid next week so i can go wheel once more before i start the cage/slider/bumpers build hold my beer, watch this oh and this 100lb beauty showed up yesterday :brows: Link to comment Share on other sites More sharing options...
wheelsaz08 Posted March 31, 2017 Author Share Posted March 31, 2017 Empty Post Link to comment Share on other sites More sharing options...
wheelsaz08 Posted April 7, 2017 Author Share Posted April 7, 2017 i picked up a 63mm bored tb from Jeff Leigh and some stroker stickers! i was going to hold off on installing it till i was ready to swap intakes, but i had to send my old one back as a core so i put it on last night. i wouldnt say the seat-of-the-pants-dyno felt much but man did it help free up the top end. the motor used to fall on its face around 4k ish (not sure cause my tach doesnt work) but now it revs to the moon! haha can't wait to swap manifolds and see more improvement no installed pics cause it looks stock, but here's some comparison shots old (stock) tb dat new new Link to comment Share on other sites More sharing options...
wheelsaz08 Posted April 23, 2017 Author Share Posted April 23, 2017 Empty Post Link to comment Share on other sites More sharing options...
wheelsaz08 Posted May 22, 2017 Author Share Posted May 22, 2017 Empty Post Link to comment Share on other sites More sharing options...
neohic Posted May 22, 2017 Share Posted May 22, 2017 Whoa! Can't believe I've missed all this so far! Very nice, sir. Very nice! Link to comment Share on other sites More sharing options...
wheelsaz08 Posted May 23, 2017 Author Share Posted May 23, 2017 thank you much! Link to comment Share on other sites More sharing options...
wheelsaz08 Posted August 30, 2017 Author Share Posted August 30, 2017 been a while, havent done any wheeling lately, so i ripped out the interior and sawzall! took 16 inches out of the "frame" and cut the end of the bed off. I'm for sure bobbing it but may also dovetail, we'll see. last night i got the new rear crossmember and shackle hangers tacked and partially welded but didnt get pics, will tonight though Link to comment Share on other sites More sharing options...
wheelsaz08 Posted September 11, 2017 Author Share Posted September 11, 2017 the rear cross member is 4x4x0.25 wall square tube that i notched to fit the end of the frame from both the rear and the bottom so its plenty rigid. i then added ruffstuff shackle hangers and have been playing around with shackles. i started with 6" and i didnt like how tall the jeep was (one of the reasons I'm doing this is to lower it 2ish inches) then i made some 5"and 4" shackles out of 0.375 plate. the 5's were still a little tall but travel was perfect. the 4's sit just right but don't allow the travel i want. so i pulled the overload out of the spring pack and then tried each set again. i left the 4's in for now but think i may make some 4.5" ones and try those, we'll see. i still need to cut some pieces to fill gaps and finish welding but here's some pics. i ran into porosity issues (bad prep0 and ground some of these out and rewelded rolled the jeep outside, this is with the 4" shackles and no overload. I'm also thinking about hitting the junk yard to find some long flat springs to make a bastard pack Link to comment Share on other sites More sharing options...
