3" SOA am I crazy?
Hey guys so I picked up a 90' MJ the other day. It's currently 2wd with a 3" lift up front and 0 lift in the rear. I'm looking to get ideas on a SOA rear without netting 5"
I'm swapping out the 35 rear for an 8.25 with 4.10s. (Yes I'm converting to 4wd as well) picked up an AX15, 231 and a set of 4.10 axles for 350$
If I make spring perches as low as possible, (machinist by trade) use XJ shackles and possibly take out a spring.. I'm thinking I may be close to where I want to be. Am I crazy? What am I missing?
I'll throw another curve ball and note I'm looking to gain load capacity too.. hmm
Egg -I think I'm thinking too much- head
Not possible.
 2 things to keep in mind:
-the packs have to be stiff enough to resist spring-wrap
-the shackle needs to be long enough or the leafs will bind upon full stuff.
why are you wanting to go SOA and not stick with new metric ton leafs and SUA?
Just exploring my options, I figured I'm going to be cutting off perches of the 8.25 already anyway.
I do have access to a set of XJ packs to build a "Bastard pack" and have a set of chevy drop shackles.
I'm unclear on where to pick up a set of metric ton packs?
I can tell you what works-
Standard GS leafs will give you 3", JKS shackles will give you 1"........reality is I'm at 3.75" over where I was 6 months ago. Depending on which direction you mount the JKS shackles........0-1" lift, I just swapped the direction on mine a couple of nights ago and gained the 1".
OME coils up front will gain you nearly 2" (+additional isolator= 3") . I just installed the JKS ACOS system and adjusted it for 1" more, now at 4" and level with rear.
I have had exactly 1100lbs in the back of mine (transfered marble from tractor trailer to job, known shipping weight) with virtually no sag.....the GS springs can handle weight.
2WD rear spring packs will net @ 1" less lift on an SOA compared to a stock 4WD pack, but you're still gonna be over 3".  XJ shackles would help keep you lower, but may invert.
Jeff
You are talking SUA correct? What are "GS" springs?
GS = General Springs.  I replaced my rear leaf springs with GS standard leaf springs because my stock ones had broken leaves.  Over a year later, and with some heavy stuff for more than half the time, they settled.  After they settled, with the stock shackles, the rear sits over 2 inches higher than the front.  They definitely sit higher than stock Comanche springs.
To be technical, a SOA will lift any MJ, 2WD or 4WD, about 5-1/2 inches. If a 2WD starts out 1" lower than a neighboring 4WD, after both undergo a SOA they will both be lifted by 5-1/2" (+/-) and the 2WD will still be 1" lower than the 4WD.
The amount of lift from a SOA is the sum of
  • 1x perch offset ~ 1/2"
  • 1x axle tube diameter ~ 2-3/4"
  • 1x leaf pack thickness ~ 1-1/4"
Add that up and you get 5 inches as a minimum lift.
Pretty much . I got 5.5" going SOA.
Great picture! Gave me a great visual. And made me just realize some things.
I've always wondered why some trucks had SOA, and some had SUA (all brands / types). Spring over axle never made sense to me. However, after seeing this image, I can see some design benefits of SUA.
Mainly, on a drive axle (powered axle, like a rear end), a SUA should have much less wheel hop. Cause the axle housing will have less leverage over the spring. And the spring eyelets will be near equal with the housing.
Humm. wondering if I should convert my Race RAM rear to SUA, to help control wheel hop under extreme acceleration...
my guess is that it's usually done for packaging reasons.  consider that the MJ is SUA and the XJ is SOA, but the Ranger is SOA and the Explorer is SUA.  Either design works just fine for a factory suspension.
