mpace6a Posted December 16, 2013 Share Posted December 16, 2013 Is there anything wrong with putting used gears in a d30? Obviously I'll be going over every gear to make sure there's no issues and what not, but assuming they're not chipped or cracked, should they be safe? And I can't find where I read it, but is it true that all 2.5/5spd xjs came with 4.10s? Hunting down a limited slip/4.10 8.8 for the mj and don't want to drop $500 on new d30 gears Link to comment Share on other sites More sharing options...
Jeep Driver Posted December 16, 2013 Share Posted December 16, 2013 Yes, the XJs came with 4.10s...........that's where I got mine from. If you find one, just swap the entire axle........but yes, I'd use used gears. I too am looking for another alternative for my D35 but will not use the 8.8 Link to comment Share on other sites More sharing options...
mpace6a Posted December 16, 2013 Author Share Posted December 16, 2013 Gears are cheaper, and it's the cad axle I already have in the mj. Why no 8.8 for you? Just because it's a ford axle or is there more to it? Link to comment Share on other sites More sharing options...
Blue88Comanche Posted December 16, 2013 Share Posted December 16, 2013 if i recall, the 8.8 is narrower and may require wheel spacers depending on the rims you use. The XJ Chrysler 8.25 is the same width as the D35 and D44 for the MJ. I say swap the entire axle. At my P&P its $90 out the door for an axle. all i would need to do is drop it in. Otherwise unless you can set gears, the getting the gears set up will cost about $250 or more per axle... part of my problem is my P&P does not seem to get 2.5 jeeps with 4wd... Link to comment Share on other sites More sharing options...
mpace6a Posted December 16, 2013 Author Share Posted December 16, 2013 The 8.8 is roughly 1.25" narrower Here an axle is $200 out the door, but that may be more worthwhile...I've been reading and youtubing gear changes and it doesn't seem like it should require any outside help. Link to comment Share on other sites More sharing options...
skidoo_j Posted December 16, 2013 Share Posted December 16, 2013 Setting up gears is not that bad. The biggest thing with used gears is you want the pattern as close to the exact set as before. Alot of times this is not possible but is optimal. What I did was paint the old gears i was re using for pattern and took lots of photos at different angles of the pattern so I could try my best to match it. It just adds one more thing to setting the backlash and pattern. I would suggest you get new bearings even with used gears. Take your old bearings and sand them so you can make some "setup bearings" It will make setting your shims much easier. Keep in mind the dana 30 is shimmed inside of the bearings, so the bearings have to be pulled each time from the carrier When setting the pinion don't install the baffle spacer until you're 100 percent sure, because it is a pita to get out with out damaging it. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted December 16, 2013 Share Posted December 16, 2013 I, too, would advise grabbing the whole axle, but the cards are in your hands so it's your choice. A C8.25 is a good choice and is readily available behind XJs. There is no carrier break for the 8.25 and 4.10's can be readily had if your XJ donor doesn't have a 8.25. I lucked out and got both front and rear axles with 4.10's for my XJ for about $250 at LKQ on a 50% day. Would have been cheaper if I had taken the brake assemblies of the rear since it got a ZJ disc brake conversion right after that. Mine came from a '94 with 2.5L/AX5 and thus the rear is 27 spline but still a huge improvement over the turdy-five. Link to comment Share on other sites More sharing options...
MrSimon Posted December 16, 2013 Share Posted December 16, 2013 Some folks will say that you should always use new gears .... and while I'm sure that's the best option, used gears can be set up well enough to be just fine. I also think that its even less of a problem in the front axle, where the gears get much less use. Link to comment Share on other sites More sharing options...
SW86 Posted December 16, 2013 Share Posted December 16, 2013 nothing wrong with using used gears at all but what i want to know is, what gears for the 30 cost 500 bucks..... i went with G2 gears and it was 150 with free shipping. not the best gears out there but with the people in my local club beating the $#!& out of them, they'll be fine. i also went 8.25. no 8.8 tube issues or weak carrier Link to comment Share on other sites More sharing options...
nitroxsteve Posted December 16, 2013 Share Posted December 16, 2013 Used gears are fine they just need to be set up correctly. I would look harder for a complete axle I picked up my D30 for $100. You can definitely swap the complete axle faster with less headache than setting up the gears, and if you don't need to turn in your old axle for a core then you have some spare parts. Link to comment Share on other sites More sharing options...
Pete M Posted December 16, 2013 Share Posted December 16, 2013 car-part.com can help finding used axles. Link to comment Share on other sites More sharing options...
Eagle Posted December 16, 2013 Share Posted December 16, 2013 Yes, the XJs came with 4.10s...........that's where I got mine from. But the question was whether ALL 2.5L 5-speeds came with 4.10 gears, and the answer is no. Chrysler standardized on 4.10s for the 2.5L somewhere in the 1990s, but AMC era 2.5L 5-speeds might have 3.73s or 4.56s. Link to comment Share on other sites More sharing options...
88whitemanche Posted December 16, 2013 Share Posted December 16, 2013 My 88 have 4.10/4.11 gears Link to comment Share on other sites More sharing options...
