MancheKid86's HillBilly Deluxe
1989 jeep comanche 4x4
Engine:
1993 4.5L HO stroker - built by robert bryce
Crane cam shaft
1977 4.2 crankshaft
5.0L Ford Mustang fuel inectors
49 PSI fuel pressure regulator
Ported and polished thermostat housing
performance 190 F theromostat
Flow Kooler water pump
Converted open cooling system
Aux Fan
Transmission/Transfercase Assembly:
External Slave AX-15 from 1990 YJ to achieve a flatbelly via transfer case clock angle
NP231 Doubler
NP241 internals and output inside a NP231 case for the second transfercase
Front Axle:
Spicer 44 out of a 1979 international scout II
re-tubed and sleeved to obtain drivers pumpkin.
all new brackets welded on
2.5" raised coil spring buckets (built in spacers)
Detroit locker
4.88 gears
RCV axles
Warn Premium locking hubs
1/4" thick walled front drive shaft
Rear Axle
Detroit locker
4.88 gears
Spring Over Axle
Relocated shock mounts
TSM MFG gm metric disc conversion with drilled and slotted rotors and Cadillac Eldorado e-brake calipers
Chromoly axle shafts
Suspension
Front
10" short arm lift
7.5 lift coils, 2.5" built into axle
custom lower control arms with dodge one ton bushings
custom upper control arms
Rear
3/4 eliptical
10" lift
Spring over axle
2011 chevy colorado shackles
Steering and linkages
Stock steering box
Full one ton over knuckle steering
Iron Man 4x4 Fab steering box brace with sector shaft support
Iron Man 4x4 Fab track bar and bracket with frame brace
Tires and rims
39.5x15x15 Grooved Bias super swamper tsl's
1977 ford bronco rims with weld on bead locks
MISC
warn 9000 XDI front winch
Black Diamond Synthetic winch line
warn 8000 VR rear winch
Onboard air regulated to 155 psi
relocated battery
train horn
138:1 crawl ratio
  • Replies 161
tried on my big boy shoes
and then this happened...
my steering knuckle failed on me on a hill climb, it was previously cracked (casting was more than oxidized in the break)
ejected my front coil as well and half my front drive shaft wasnt located,
back to the chopping block, I'm glad it failed on trail, and not on the highway
  • 3 months later...
. :MJ 2: . so, bout time for an update
started by swapping the tires from 33's to the 36's that are supposed to be on
then came some angry eyes ( i did not do a full shade, just enough to be seen, ****does not affect vision of headlights what so ever****)
some maint + hooking up wiper jets
then it was time for a Flex test, not even at full bump! hahahah
little while later after a bunch of snow wheeling i snapped 2 chromollys at the same time
so replacement shaft comes, without the necessary hole in the shaft's flange
drilling through chromolly
3 hours of straight drilling later!!!
the most recent is this,
36's tore a bead so for $600 for 5 40" tires i couldnt pass it up
moved onto 40's and ready for leaf pack swap!
40 vs 36!
after some trimming and hacking of bushwackers they fit higher!
torchin bushings out, will be putting these in next week
now some wheelin pics and carnage (havent tested the 40's out yet)
more to come!!  . :MJ 1: .
thanks guys!
and as for carnage, you stop when you break so thats when most pics are taken! lol
so far its always been something else, so I'm going through that repetitious cycle
more pics!
wheel spacers
leaf springs, metric ton packs with new bushings and my old ones
leaf pack swap done
adding balancing beads
went logging apparantly!
and some posers
  • 4 months later...
well i had three,
either i lost one in the bush or some one took it while stumbling by one night :rotfl2:
seems like i havent updated in for ever!
got over 100 photos to upload haha!
so lately, ive been super busy with my rig
here's a short list of all the things i have done since my last update
new clutch flywheel and pilot bushing,
new starter and a/c compressor for my onboard air
put a detroit lsd in until i get my detroit locker rebuild parts
finished off all the ball joints and ujoints
upgraded my cooling system to a hi-flow system flo kooler water pump, hi flow tstat, ported and polished a new tsat housing and convertted to an open cooling system as well
new power steering pump, steering box, and and steering stabilizer, will do hydro assist in the near future
swapped my 89 ax15 with a 99 ax 15 just cause, which i learnt the clock angle i changed on the output flange on the 99 ax-15 had shifted,
which than put my tcase hanging lower than my frame :\ no more flat belly
rebuilt my tcase doubler and 241/231 combo tcases,
updated the doubler internals from a 99 np231, they were worn and needed a refresh (it should be good to go for another 17 years now!)
resealed my engine, valve cover, oil filter adapter, rear main, front main, and oil pan
put a new harmonic balancer on and probably a few more things,
that is where i am at now, will be putting 4.88 gears in soon, just waiting for the gears and install kits to get to do my door step!
and now for pictures!
(some of them were taken from my old cell phone aka a potato most are good tho!)
over hauls
tcase and tcase doubler
random tcase assembly i built to show what is actually going on in a tcase (training aid)
engine and transmission
cooling system upgrade
  • 10 months later...
seems like i havent been on in forever,
trucks still alive, doing the 97+ swap soon aswell just waiting for buddy to pull the parts he wants and ill start stripping everything out
here's bit of an update
Regear & yet another transmission swap
-Regear
Had a pinion failure, back story on that.
Locker inner couplings were done so needed a carrier to get me to a 4x4 event that weekend so I swapped carriers and shimmed for backlash, on route to the event a bolt came loose and took out my pinion, these bolts I did not touch, so learns me to check if previous people remembered torque and Loctite
So I went with Yukon gear 4.88 gears for the front and rear to work better with the 40’s. at this time I took the time to rebuild my lockers for the front and rear as well, both of them had sheared couplings in them
-Transmission Swap
When I swapped the transmissions, I went to a 99 ax-15
My transfer case clocking angle was no good, it was sticking out lower than my cross member, so I no longer had the flat belly, and my rear bearing was shot as well, so out it came and the other one put back in, at that point I did more mods to my 2nd tcase and drilled and tapped for the 99 shift/lock mechanism
Vehicle inspection
So at one point I was taking a few friends out for a rip, I made the mistake of letting the police know how much my truck was able to flex in town, so I got a nice slip that told me I had 30 days to get a provincial inspection done, it took a bit of work, but nothing I couldn’t handle, the truck passed the inspection, in the department of transports eye it may be ugly, but it is safe, I did how ever lower the truck for the time being, just so my bumper level was closer to the ground, which meant I had to remove the ¾ elliptical setup at that time
Bumper straightening
So I ended up battling a telephone pole over the winter time, it was a stale mate, we both were still functional and both had battle scars from it, figured it was time to straighten it out again,I need to clean it up and weld it back together, at this time I'm rebuilding the front winch while its off.
Hand stuck in bumper, had to get my room mate to come out with some LPS to get it to slide out
Re lifting the truck
For my vehicle inspection, I had to remove my ¾ elliptical suspension. I wasn’t too happy about that because prior it has passed with it installed, but hey, not my stamp, so in went the big coils and 3/4 elliptical setup, plus new shackes and bushings (which I had to make on a lathe)
This truck from the ultimate adventure, I was his tour guide last year and actually got to drive it through whipsaw
Me in the rig!
part 2
Wheeling
here's a mix of wheeling photos! The ones in the winter are post lowering the truck 3 inches, and the ones in the summer are prior to lowering
Misc
some one thought it was funny to rebrand the heep
  • 2 months later...
time to unload some more photos!
ive taken my rig out a few times this year and am chasing things as i go!
i managed to do one of my two annual whipsaw trips this year,
was just too busy to do the second!
first few photos are last min prep for whipsaw,
welding my bumper back together, first time using stick
at this point I'm a grinder and not a welder, but with more practice id like to get better
here's some shots of part of my winch rebuild, no wonder i wasnt pulling the full 9000lbs,
at this time i replaced all 4 relays as well
i mounted the bumper and winch up, re ran all my air lines off the compressor, then cleaned a few things up
here's a shot at the relay center i wired in quickly for all my auxillary stuff,
the wiring i was replacing was horrendous, lots of but splices and termanted wires
fog lights, onboard air and aux cooling fan, cleaned up and sheilded the wires after
here was a test drive down the road for the first time in 7 months, too Lordco
the next set of photos are from my thunder mountain trip! which was a blast
and a side by side shot of my cherokee and comanche!
https://www.facebook.com/matt.dows.1/videos/10153401060808089
https://www.facebook.com/matt.dows.1/videos/10153401055083089
here's a few from my camping trip, i need a film crew because i don't take photos of everything i crawled
so these are the only two i got
the rest is all from whipsaw and a few misc photos, again i did all the fun stuff trying to catch up to my group so not too many action shots
https://www.facebook.com/devon.lepey/videos/982392481782702
