Swampy Posted August 28, 2017 Share Posted August 28, 2017 I love your truck I'm surprised I haven't seen you around. Once mine is on the road we should definitely meet up Link to comment Share on other sites More sharing options...
88whitemanche Posted August 28, 2017 Author Share Posted August 28, 2017 Most definitely, this year I haven't driven this truck that much as I should, my Cherokee has taken that toll.... but I'll be driving it more often as I can switch trucks week to week and take advantage of the current upgrades I have done to it... Link to comment Share on other sites More sharing options...
88whitemanche Posted September 4, 2017 Author Share Posted September 4, 2017 What's up everyone so I've always had a leaky oil filler cap and never found a solution, always heard about using an bicycle tube and cut to size and put it under the cap...then I came across a YouTube video to something similar to the same problem I had... ended using a spectre part # 4310 its in the accessories aisle in auto zone Worked like a charm, hasn't leaked yet... Link to comment Share on other sites More sharing options...
coolwind57 Posted September 8, 2017 Share Posted September 8, 2017 On 9/4/2017 at 7:09 PM, 88whitemanche said: What's up everyone so I've always had a leaky oil filler cap and never found a solution, always heard about using an bicycle tube and cut to size and put it under the cap...then I came across a YouTube video to something similar to the same problem I had... ended using a spectre part # 4310 its in the accessories aisle in auto zone Worked like a charm, hasn't leaked yet... Same issue here. Tried prying up on my old cap's seal and it snapped. Swinging by Autozone to try the 4310 cap. Thank you, Sir. Link to comment Share on other sites More sharing options...
coolwind57 Posted September 11, 2017 Share Posted September 11, 2017 On 9/8/2017 at 4:27 PM, coolwind57 said: Same issue here. Tried prying up on my old cap's seal and it snapped. Swinging by Autozone to try the 4310 cap. Thank you, Sir. Nope. Found out this doesn't work on my 1989 MJ. Instead, on these old-style caps one should consider just running to Napa for the $3.29 replacement = BK 7031366. Link to comment Share on other sites More sharing options...
88whitemanche Posted September 11, 2017 Author Share Posted September 11, 2017 3 hours ago, coolwind57 said: Nope. Found out this doesn't work on my 1989 MJ. Instead, on these old-style caps one should consider just running to Napa for the $3.29 replacement = BK 7031366. Good find, i totally forgot that my valve cover is the aluminum cover from a 93 4cyl Cherokee not the older Plastic cover it used to have Link to comment Share on other sites More sharing options...
88whitemanche Posted September 15, 2017 Author Share Posted September 15, 2017 Welp, the Ax15 is starting to show its age... well I already knew it had a bad 2nd gear synchro and I figured I could nuture it along (since I got the trans for $150) until it finally gives out but 3rd gear synchro is starting to show it's face and the used throwout bearing I threw in is starting to squeal, so I'll keep driving it until it finally goes then I'll drop the trans to get rebuilt and get new clutch parts to put in... does anyone know the part # to the all metal throwout bearing for the external slave ? Link to comment Share on other sites More sharing options...
88whitemanche Posted September 20, 2017 Author Share Posted September 20, 2017 Just ordered an nv3550 and the clutch parts needed... i didn't go with the centerforce clutch disk this time but I went with the 84 4cyl Camaro clutch disk from rockauto.com The ax15 I'll keep it laying around until I get a chance to try and rebuild it... Link to comment Share on other sites More sharing options...
Swampy Posted September 22, 2017 Share Posted September 22, 2017 I was going to do the same thing when my transmission went out, get a nv3550. Where did you find the bell hosuing for it? I was trying to look for the 4banger one but no luck Link to comment Share on other sites More sharing options...
88whitemanche Posted September 24, 2017 Author Share Posted September 24, 2017 On 9/22/2017 at 1:36 PM, Swampy said: I was going to do the same thing when my transmission went out, get a nv3550. Where did you find the bell hosuing for it? I was trying to look for the 4banger one but no luck Found mine off of a 96 dodge Dakota with the 2.5 engine....Dodge Dakotas from 96-98 models with the 2.5 had the ax15 backed behind it... I actually have a spare I wouldn't mind letting go when your ready to make that swap Link to comment Share on other sites More sharing options...
Swampy Posted September 24, 2017 Share Posted September 24, 2017 15 hours ago, 88whitemanche said: Found mine off of a 96 dodge Dakota with the 2.5 engine....Dodge Dakotas from 96-98 models with the 2.5 had the ax15 backed behind it... I actually have a spare I wouldn't mind letting go when your ready to make that swap I'll definitely keep it in mind. Thanks bud Link to comment Share on other sites More sharing options...
88whitemanche Posted October 22, 2017 Author Share Posted October 22, 2017 Well the nv3550 came in, I’ll get pics on that next time...started to remove the bolts that mate the trans to the engine I got everything off until I started getting to the driveshaft... the very last bolt greeted me with this with out a force of a turn... now either I got to either drill it out and put the original bolts back in or plan for ujoints straps Link to comment Share on other sites More sharing options...
88whitemanche Posted April 16, 2018 Author Share Posted April 16, 2018 So I did a thing I took out my old toolbox and put in an inbed toolbox I’m getting a Comanche specific topper in the coming weeks and I needed to do this mod to have it fit without taking my whole toolbox out... Link to comment Share on other sites More sharing options...
88whitemanche Posted April 16, 2018 Author Share Posted April 16, 2018 Also, I have a couple upgrades that need to be done dirtbound Offroad battery tray 4.0 radiator/97+ 2.5 fan shroud swap 4.0 power steering pump and reservoir swap i bought later model 2.5 exhaust headers thrush turbo muffler And a exhaust flex pipe And replace the freeze plugs off the engine block, might as well do them now that the exhaust manifold is coming off i have the boostwerks hidden winch comp mount I really want to install it on This Jeep but need a full size plain bumper to install it with but I have a soft core hidden winch bumper ready to install until I’m ready to swap over to that comp mount Also to add mean lemons battery cables and transmission mount Also the 4-link to the cavfab longarm Link to comment Share on other sites More sharing options...
Pete M Posted April 16, 2018 Share Posted April 16, 2018 love that box! Link to comment Share on other sites More sharing options...
88whitemanche Posted April 16, 2018 Author Share Posted April 16, 2018 11 hours ago, Pete M said: love that box! Thanks bud wasn’t too bad on price neither I like that it sits almost flush with the bed and can pack ALOT of stuff inside I think a bit more than the original one I had... Link to comment Share on other sites More sharing options...
88whitemanche Posted April 16, 2018 Author Share Posted April 16, 2018 Got this goodie coming soon won't be installing anytime soon but excited to find a rare piece Link to comment Share on other sites More sharing options...
Swampy Posted April 17, 2018 Share Posted April 17, 2018 Dang I want a cam for my jeep lucky. But I have a full plaint front bumper if you want it. Seems we both have some list of things to cross off our list Link to comment Share on other sites More sharing options...
88whitemanche Posted April 17, 2018 Author Share Posted April 17, 2018 6 hours ago, Swampy said: Dang I want a cam for my jeep lucky. But I have a full plaint front bumper if you want it. Seems we both have some list of things to cross off our list I currently have one on my Comanche i was looking more into the logans4x4 bumper this one http://www.logansmetal4x4.com/jechxjnonwib.html or the old style jcr bumper which they have as a diy style but I’m a long ways before I can start messing with the welder I was given Link to comment Share on other sites More sharing options...
Swampy Posted April 17, 2018 Share Posted April 17, 2018 3 hours ago, 88whitemanche said: I currently have one on my Comanche i was looking more into the logans4x4 bumper this one http://www.logansmetal4x4.com/jechxjnonwib.html or the old style jcr bumper which they have as a diy style but I’m a long ways before I can start messing with the welder I was given Oh okay. I thought you were looking for a plain stock bumper haha Link to comment Share on other sites More sharing options...
88whitemanche Posted April 18, 2018 Author Share Posted April 18, 2018 11 hours ago, Swampy said: Oh okay. I thought you were looking for a plain stock bumper haha Ah no sweat... did an upgrade that I’ve been putting off for a while my battery box had broken and had gotten 2 for my my and Xj pics (nothing special) Link to comment Share on other sites More sharing options...
88whitemanche Posted April 21, 2018 Author Share Posted April 21, 2018 Hmmmm Link to comment Share on other sites More sharing options...
Pete M Posted April 22, 2018 Share Posted April 22, 2018 love it just watch out for trees! Link to comment Share on other sites More sharing options...
88whitemanche Posted April 22, 2018 Author Share Posted April 22, 2018 51 minutes ago, Pete M said: love it just watch out for trees! Whoa! Will probably add some side supports to have full protection Link to comment Share on other sites More sharing options...
WyoCherokee Posted April 24, 2018 Share Posted April 24, 2018 On 4/21/2018 at 8:21 PM, 88whitemanche said: Whoa! Will probably add some side supports to have full protection This is why stubby's are useless on trail rig. never understood the craze. doesn't protect you from a tree, much less a deer! Link to comment Share on other sites More sharing options...
