guess who just scored an XJ wagoneer grille assembly?
Pete M
Had one of those on my MJ for a while. Was cool at first then the lack of light at night from the headlights got old. Swapped it back to the original. Nice find tho
Plenty of light, more than H4 singles, if you do an H4 conversion on the quad headlamps.
I hope you got the corner marker lights too. They are different than the regular ones as well and are near impossible to find.
yup :thumbsup: they had a couple minor cracks, but I have a good set I found earlier.
In your opinion it is. I did the H4 conversion to both the single and the quads and the quads didnt compare so i switched the panel back, my opinion and its the only one that matters.
Nice Find Pete :cheers:
I am doing this conversion, so I have to ask - Did you upgrade the wiring harness when you went to the H4 bulbs? I have already made the harness, so I guess I will know shortly.
  • 7 months later...
